Question about Logitech 2.1 Speaker System Z313
Is there a driver for logitech z313 speakers for download?
Just hooked up used logitech z313 speakers and subwoofer to my computer and have no documentation. Attempted to install them, the wizard did list "logitech", however, when I selected this mfr, my only options were between 2 different micorphones (?). I want to be able to control the volume level of the sub. Is that possible?
Hello..
Click on this site Driver Update Software for XP Vista 7 8, download the software for free, scan, and update.
Posted on Nov 19, 2014
Open SKy
  • 619 Answers
SOURCE: Using headphones with Logitech X-230 speakers
Hi FOG-57
Happy HOlidays!
well, if volume is fixed, you have to see if in the control program for sound, you can disable and use the headphone sound program in windows.
good luck
Posted on Dec 26, 2007
bronk50
  • 27725 Answers
SOURCE: Logitech Z313 how to install it in your computer
plug these speakers
if your computer came with a motherboard disk the sound drivers could be on it
control panel sounds and audio,volume,advanced,speakers select appropriate speakers or
audio you will find 3 drop down lists make the necessary adjustments there or
control panel,administrive tools,computer management,device manager,sound video and game controllers could be a yellow question mark? right click to re-install drivers
hope this helps
Posted on Dec 11, 2010
  • 108 Answers
SOURCE: Subwoofer and center box problems with Logitech X530
Hi Sainty,
this is just a shot in the dark, but have you attempted to play around with your sound driver's configuration? I'm unfamiliar with the newer Nforce stuff, but try looking around in the sound manager Nvidia uses. It sounds like it's been configured to swap speakers. (As an example, I'm using the realtek audio manager on an asus p5k-vm board myself, and the option shows up as "Swap Center/ Subwoofer Output" in my configuration.)
Posted on Dec 30, 2007
SOURCE: Logitech Z-2300 speakers
maybe the first step could be checking the subwoofer's fuse.it is located over the power supply connector.
Posted on Jan 22, 2008
preachw996
  • 1179 Answers
SOURCE: One speaker is musch louder X-530
On the TV sound options see if there is a balance option. Adjust according to taste if there is that option. Hope this helps.
Posted on Dec 24, 2008
Schematic for logitech z313
I couldn't find a schematic but...
The red and black wires go to the subwoofer.
The white and black wires are main level inputs that go to the toroid.
The blue, green and black wires are the output from the rectifier.
Tthe green is your negative rail while the black is 0v and the blue is positive
Sep 05, 2016 | Logitech Audio Players & Recorders
Logitech Z313 Sound System Failure
On the basis of your description, you can conclude that your Logitech speaker system has failed.
Mar 18, 2014 | Sun -115H Computer Speakers
The volume on my z313 I hook it up to my computer is to low
There should be a volume level adjustment on the speakers.
Verify the master volume on the computer is turned up as well as the volume of the app in use is turned up.
Oct 21, 2013 | Logitech Z 313 - 2.1-channel PC multimedia...
How do i hookup logitech speakers #z313 to my emachine e202hl
The manual for your speakers can be found at http://www.logitech.com/repository/1411/pdf/27251.1.0.pdf. The Speakers should be conected to your computer as opposed to the moniter. Disconect the small wire from the moniter to the computer and insert the plug from the speakers where it came from.
Nov 14, 2012 | E-Machines Computers & Internet
How do i hook up logitech speakers #z313 to my desktop i need a diagram
Phone jack on woofer goes into computer tower (should be color coded green) and power cable on woofer plugs into 120VAC. Speaker phone jack plugs into back of woofer. The speaker cable has an on-off switch and volume control as well as a phone jack for your headset.
Nov 14, 2012 | Logitech SPEAKER SYSTEM Z313 PC Multimedia...
Z313 no sound
Phone plug on subwoofer plugs into phone jack on back of tower! Plug and jack are color coded green. If you plug into wrong jack you get no sound or intermittent sound. Also speaker cables have an on-off swith so make sure you are switched "on" or you will not get sound.
Oct 30, 2012 | Logitech SPEAKER SYSTEM Z313 PC Multimedia...
I am having trouble with the speakers making any sound when I hook the speakers into the Rear Panel (RL RR) of my computer but the speakers work if I use them in the headphone jack. The subwoofer works...
The main reason why the rear speakers are not working because the sound you are playing are not surround sound or a not a stereo sound and check the setting of your speaker. There is an output sound in your speaker but to low because of the set up of your speakers. Try to set it in Hall, Church, or any set up you will notice that there is difference with there volume in every set up.
Jul 26, 2011 | Logitech Z313
Connected up z313 speakers. have motherboard HD sound installed with my windows 7. no sound coming from sub or speakers. can plug head phones into the z313 controller and listen to music. plz help
if your computer came with a motherboard disc the sound drivers could be on it
you might have to uninstall then restart your computer then reinstall both the sound drivers and the sound card make sure you have both of these devices backed up to a disc before uninstalling
a yellow? question mark means you need to install/update driver to do this
right click to install driver also
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers select appropriate speakers also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar
if his does not fix the problem
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable)
hope this helps
Jan 31, 2011 | Logitech Z313
plug these speakers
hope this helps
Dec 11, 2010 | Logitech Z313
Logitech 2.1 Speaker System Z313 Logo
2,869 people viewed this question
Top Logitech Audio Players & Recorders Experts
Michial Gueffroy
Jerry Umali
Are you a Logitech Audio Player and Recorder Expert? Answer questions, earn points and help others
