I need to replace the gasket on my intake manifold, but i don't know the torque that the bolts should be torqued to.. please help, and is there any specific sequence each bolt should be tightened?
SOURCE: Front caliper securing bolts torque
I know that it's a jag, and I know you are trying to be perfect, but in over thirty years, I've never seen a tech put a torque wrench on a caliper bolt. If you really want to I'd use about 35-40 foot pounds. (I go by bolt diameter) You don't have to slam them down but you don't want them to back out either. A bit over 35 is reasonable and should not damage anything and will keep them secure!
I have no idea what nm conversion is..
SOURCE: 2001 jaguar S type v 6. I need to replace the Valve cover gasket.
Felpro brand gaskets are the best in the world, not sure about the intake, if it is in the way then yes remove it.
DeVille, Eldorado, Seville 1999-2005
Removal & Installation
Left Side
Fig. Left cylinder head bolt torque sequence-4.6L engine
Fig. Right cylinder head bolt torque sequence- 4.6L engine
Fig. Intake manifold bolt torque sequence 2.7L engine
Upper intake manifold with a new gasket on the lower intake
manifold and torque the bolts, in sequence, to: 105 inch lbs. (12 Nm)
Hope helps (remember to rate this answer). Good job.
