Question about Schwinn 420 Elliptical Trainer
My schwinn 420 elliptical won't increase in difficulty
Even when I increase the intensity on the screen the flywheel doesn't increase the difficulty of the pedaling
5 Suggested Answers
ercupa190
  • 12223 Answers
SOURCE: error code 1 on schwinn elliptical 420
Dear Sir:
adjust the speed sensor see the diagram attached.
2) the main board can be faulty.
3) Run the software calibration.
5_3_2012_12_02_47_am.gif sincerely. God bless you
Posted on May 03, 2012
ercupa190
  • 12223 Answers
SOURCE: The tension does not increase on my schwinn 220
adjust the magnet very well, tigh the bolts if there loose the tension will be not o.k
mendi593
  • 65 Answers
SOURCE: schwinn 450 elliptical not registering pedal movement
You will need to take the front stabalizer off before opening the machine.
http://www.treadmilldoctor.com/?utm_source=fixya&utm_medium=CPC&utm_campaign=Mendi
Posted on Jul 17, 2012
ercupa190
  • 12223 Answers
SOURCE: schwinn 220P no resistance
see this steps and fix it. God bless you
  • 1
    Check your owner's manual for diagrams and definitions. You'll need this information when you put the elliptical back together. You'll also want definitions in case you need to call the customer support line for assistance.
  • 2
    Be aware that the resistance is often the part that requires repair. Resistance is managed magnetically, so often if the machine is working, but the resistance isn't setting correctly or at all, check the bolts that secure the magnets. If they are loose, the resistance will slip. If the bolts are fine, check the magnets themselves by using a refrigerator magnet and see if it is attracted or repelled by the your fridge magnet. If not, the magnets have de-magnetized and need to be replaced.
  • 3
    Consider that if the foot pedals are attached with bolts, any slipping can be fixed with a quick use of the wrench. But if the foot pedals are damaged or breaking, order new foot pedals (see Resources below) rather than run the risk of a pedal breaking while you're on the machine.
  • 4
    Check the hand bars. While not all people use them, as they can elevate your heart rate by up to 20 percent, they can become worn, too. While loose hand bars typically need a simple tightening of the bolt, be sure not to overtighten as the bolts can break.
  • 5
    Know that if the axis is bent, it's likely you need a new machine. The axis is the central alignment of the elliptical. If the machine was used by a person who is over the maximum weight limit, it can be bent or damaged. It's not an easy fix and a better idea is to upgrade to a sturdier machine.
  • Posted on Nov 23, 2012
    On my shwinn 420 I can only get manual on program settings
    If you wish to get some details About elliptical; check the site linked here. Pull up older posts.....
    http://electro-medical.blogspot.com/
    Jul 15, 2016 | Schwinn Fitness 420 Elliptical
    My Schwinn 420 elliptical is not powering on. The breaker and outlet source are fine. When I plug the machine in nothing powers on. The console displays nothing, no lights, etc.
    test the power cord plug, in another device and see if working
    2) replace batteries if your system has( clean the contacts from oxide,corrosion with contacts cleaner) and try again when you have isolated the problem
    God bless you
    Nov 05, 2013 | Schwinn 420 Elliptical Trainer
    Error code 1 on schwinn elliptical 420
    Dear Sir:
    Apr 30, 2012 | Schwinn 420 Elliptical Trainer
    My Schwinn 431 Elliptical rpm sensor is not working. I talked to customer service and they sen me new parts and pictures. I'd call them today but they only work M-F. anyway, it looks like the flywheel...
    I took a magnet from a magnetix toy and secured it to the correct side of the flywheel. It's working now...I just finshed doing it. Hopefully it'll continue working. Thanks for pointing out the magnet was on the wrong side.
    Jan 08, 2011 | Schwinn 430 Elliptical Trainer
    Schwinn 431 Elliptical doesn't register rpm's, distance, etc.
    I have this same problem and called the customer service. The problem is that the rpm sensor is not working. It could be the sensor or something else. They had me check the connections first for the wiring harness at the top and middle and then sent me parts to work on the inside where I have my problem. I am still working on mine because the magnet was installed on the wrong side of the flywheel. Hope you don't have this issue.
    Jul 02, 2009 | Schwinn 430 Elliptical Trainer
    NOISEY SCHWINN 430 ELLIPTICAL
    Hi I'm Ryan, do you know where it is squeeking from? if you can find the squeek try 3 in 1 oil that should stop it.
    Dec 14, 2008 | Schwinn 430 Elliptical Trainer
    Schwinn 420 Elliptical Trainer Logo
    240 people viewed this question
    Top Schwinn Exercise & Fitness Experts
    Steve
    David Payne
    David Payne
    Matt Olenzek
    Matt Olenzek
    Are you a Schwinn Exercise and Fitnes Expert? Answer questions, earn points and help others
