Question about Sewing Machines
Sewing machine manuel for Penncrest model 2500
I need a manuel on how to thread and adjust the tension, and also on any other details about the machine
SOURCE: Shark Euro-Pro Sewing Machine
I had the same problem with my Shark Euro Pro 7133. My problem was in threading the upper thread. The manual does not quite explain so I had to figure this out the hard way.
In threading the upper thread . the thread first goes down from the spool througt a groove. When it comes up it must catch a silver lever that moves up and down before moving it down againPlease let me know whether this helps.
Posted on Jul 26, 2008
SOURCE: Brother Window Matic Model HA3-B5
I believe this is the manual that you need.
http://gotoes.org/sales/BrotherSewingMachineManuals/ViewInfo.pl?Brother=1&Sewing_Machine_Model=window-matic
Posted on Jan 01, 2009
  • 96 Answers
SOURCE: My bobbin thread keeps getting tangled and
there is a screw on the side of the bobbin case, which needs to be turned to the left or counter clockwise to loosen the tension and also change the needle because a burr on the end will cause problems with bobbin thread
Posted on Dec 13, 2009
chrismyers67
  • 53 Answers
SOURCE: top thread keeps breaking
This sounds like a backwards needle. Take out the needle and when you re-insert it back in, make sure that put the flat side to the back.
Posted on Jun 07, 2010
  • 255 Answers
SOURCE: sewing machine tension
Hi. The upper tension is too loose (even tho it looks ok). If the upper thread is too loose, it can't pull the bobbin thread up to properly form the stitch and you get those messy 'birds nest' on the bottom side of the fabric. I posted a Tip on Adjusting Tension--read that and adjust your upper tension.
Thanks!
Robbie
Posted on Aug 02, 2010
Testimonial: "Thanks! That does help. Now I'll have to find your tip on Adjusting Tension =)"
How to adjust tension
Find your manual as it identifies specific parts related to adjusting tension. Here are some pictures of problematic stitches and suggestions on fixing sewing machine tension:
How to Adjust Sewing Machine Tension on Craftsy
https://www.wikihow.com/Adjust-the-Tension-on-a-Sewing-Machine
Sometimes you adjust something other than the tension:
Adjusting Sewing Machine Tension to Prevent Problems
How to Achieve Ideal Sewing Machine Thread Tension Threads
Dec 04, 2017 | Sewing Machines
Model 4075 white sewing machine problem with thread from bobbin
1. Replace thread with good thread. (Check by holding to light to see if there is fuzz).
2. Adjust the bobbin tension. The tension on top is set to three and the bobbin tension should be equal to this amount.
3. Replace needle.
4. Check the top tension with tension foot down to see if the thread can move or does it get stuck? If it gets stuck the tension control may need adjusted or cleaned.
5. Pull the bobbin thread above the throat plate and pull on the thread. It must have some tension but not get stuck.
TENSION TENSION TENSION IS THE PROBLEM!
Sep 30, 2016 | White Sewing Sewing Machines
With no manuel/thread tension solution?
tighten up the thread tension on the needle thread tension setting
what you describe is a result of the needle thread tension being too loose
to get manuals go google and type in -- workshop manual for ( make and model) sewing machine
there will be pdf version downloads if they are available
Oct 11, 2015 | Kenmore Sewing Machines
I have a Kenmore sewing machine - 12 stitch model which I bought in the 70's. I am having a tension problem and can't seem to fix it. What is the normal setting for the top, and bottom?
Hello
Load your Kenmore sewing machine with the right thread and bobbin thread for your project. If you use the wrong weight thread for your fabric or severely uneven weights of thread, this can cause the appearance of a tension problem when it is, in fact, a thread weight problem or a problem with your sewing speed. If you go too fast, you will break the thread. If you go too slow, you can cause loops. Uneven pressure can cause stitches to vary greatly.
Test your Kenmore sewing machine's tension by sewing on a piece of scrap fabric. If your tension is way off, then test on some basic cotton or a firm blend simply to get your tension right. Do not try to start adjusting your tension on silk or leather. Get a base adjustment on a more standard fabric first.
Look at the top threads and bottoms threads. If the tension is off on one side, it will usually affect the other side slightly. So select the side that looks more maladjusted to start adjusting the tension.
If the top thread is too loose or too tight, you will need to adjust the tension dial. This dial is usually located a few inches above the needle on the Kenmore machine body. Usually, your machine will have markings to indicate which direction tightens the tension. If these have worn off over the years, watch the dial as you turn it. If it appears to move toward the machine body, then it is tightening.
If the bottom thread is too loose or too tight, then you will need to open the door to the bobbin case. On some Kenmore models, there is a little screw near the bobbin case that can be adjusted slightly to adjust the tension. On other Kenmore models, there is a screw on the bobbin case itself--not on the bobbin, but on the bobbin's casing. This will also adjust the bottom thread tension. Adjust the bobbin thread tension to make slight changes.
If the thread is looping severely on one side, the thread weights might be off. For instance, look to see if you have a lightweight thread on the bobbin and a heavyweight one on the top. If the thread keeps breaking, the top tension or bottom tension could be too tight or the thread is too lightweight for the material you have selected. Check your combination of threads and material. Also make sure you are using the right weight needle and the right foot for the sewing step or project you are working on.
If your Kenmore sewing machine's tension is off severely or if you have not used your Kenmore in a long time, then you might need to take your machine in to be serviced. Sometimes, the inner parts need to be oiled or the entire machine might need to be cleaned and calibrated by a professional. If you sew a great deal or if your machine sits idle a lot, both situations will usually require some servicing to keep your Kenmore sewing machine and its tension in perfect working condition.
Jul 11, 2011 | Kenmore 15358
I am trying to get a Penncrest Model 3150 manuel. Is there one available?
You could try e-bay. A quick search of E-bay turned up a listing for several sewing machine manuals, the Penncrest 3150 was included. Also, try this site : http://cgi.tias.com/cgi-bin/sqlsearch.fcgi?store=%2Fstores%2Frelics&resultPageTemplate=ResultPage.html&resultItemTemplate=ResultItem.txt&noResultPageTemplate=NoResultPage.html&case=no&primaryServer=www.tias.com&minPrice=0&max=20&matchAll=1&searchText=penncrest
I did not see a listing for your exact model, but there are several that are very close. Your model number might be included in one of the other manuals, or the information might be close enough to use for your machine.
One other option you could try is to use the serial number for a search along with the model number. The serial number is connected to more information than the model is, and this makes it easier to find information that applies to your machine. It could be helpful to know that your machine was distributed in the late 70's by JC Penny.
May 23, 2011 | Sewing Machines
Top thread too loose, brings up bobbin thread. Tried to adjust, but cant get it right. Have manuel, but cannot locate it currently I have The Omega model
Hi. If the bobbin thread is coming up on top, then the upper tension is too tight. Try loosening it.
Hi. The best way to adjust your tension is to use good-quality thread, a size 12 needle, and different color threads in the bobbin and on top. That way, it's easier to see which thread is loose. Sew a few inches, check, and adjust (make sure the pressure foot is DOWN). Stitch a few more inches, recheck, and adjust some more. Just move the adjustment knob a little bit each time.
You might also want to use a bit of unwaxed dental floss and floss the tension disks. That helps get rid of any old lint and pieces of thread that build up in there.
As a last resort, you might need to adjust your bobbin tension. There is a very small screw on the bobbin case that tightens/loosens the spring/lever. If you need to adjust it, only move the screw a tiny bit. But, like I said, this is only a last resort--almost all adjustments can be done by adjusting the upper tension.
Hope this helps!
Robbie
Aug 12, 2010 | Necchi 6015 Mechanical Sewing Machine
Need to thread machine-no manuel
most common machine have in threading process,I ve holding different brand sewing machine they only differ is in design but the process are commonly same,start bobbins winder to wind threads
  • pull thread from spool on top of machine insert bobbins winder disc then rotate on bobbins winder 4 to 6 times manualy put it on the shaft winder locate at top of machine near handwheel,push the latch against to bobbins winder to fit,then release clutch handwheel by pulling handwheel to disengage motio only winder will rotate when you press foot pedal and start winding thread on clockwise rotation.if this filled insert bobbins winder to bobbins case and pull the end of thread inserting to the slot of bobbins case observe should have tension on this.e5b8d97.jpgas shown and dirction of thread.inset this on the shuttle case.then start looping thread on top of machine as shown22d0eb9.jpgthen start adjusting tension on tension dial you can see in fig.Set dial at # 3 at start of set up ,Stich adjustment at #8 to 12 adjust gradually.
the hook up the lower thread bobbins from lower shuttle by threads on needle then insert cotton fabrics manualy rotate handwheel until needle the fabrics freely don't apply foot pedal let it shown if the neele sew freely w/o looping under bobbins let sew manualy until it appears stiches on fabrics,if ok continue now aply foot pedal
gradually until you familiarize again the sewing.
Mar 14, 2009 | Bernina Sewing Machines
Manuel
all machines thread the same. TTN tension,take up, needle.
Beginning with the spool, guide the thread through the thread guides to the tension assembly. Pull the thread through the tension assembly and test it to make sure the tension is working correctly.
(To do this test,adjust your tension setting to normal or medium or 5 or something in the middle. Raise the presser foot and pull the thread through the tension. It should pull easily!! Lower the presser foot and pull the thread. It should pull noticeably harder.) If it passes this test, continue up through the take up lever,then down through the thread guides to the needle. Make sure your needle is fully inserted and turned the correct way.( If you load your bobbin case from the left side,the needle rule is normally FLAT to the RIGHT is RIGHT. There are some exceptions. If you have a newer style drop in bobbin or your bobbin case loads in the front then the rule is FLAT to the BACK.
Sewman7
May 26, 2008 | Janome L-344 Mechanical Sewing Machine
Sewing Machines Logo
104 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
