Question about Swift Ultra-Lite 762 Binocular
I fell and now the two eye pieces are out of alignment.
It is like seeing double. What should I do? Is this easy to fix? Or should I consider buying a new pair? I really love these and hate to loose them.
  • 30 Answers
This a problem with the prisms in the main body of the binoculars. It would seem that one or more have moved (there are four). Realigning is a difficult job but not impossible. Depending on the design, it should be possible to gain access to two of them, and hopefully you will see which one has moved. When aligned at factory, the prisms are usually held in place with a flat or “leaf” spring, and spots of paint/glue. This may give you a clue when you examine the prisms, and compare both sides.
To gain access to the bottom two prisms, try unscrewing the objective lens tube (the conical bit) from the main body, You may also need to remove one or two tiny screws that hold the protector plate in place. Do both sides at the same time so you can compare. With any luck, you might be able to re-seat the jarred prism to its original place. The top two prisms are harder to get to requiring the dissasembly of the focus mechanism, but if you go carefuly, you may get lucky, after all you have nothing to loose. Remember that binocular alignment does not need to be perfect, if it’s pretty close, the brain will compensate for any minor inaccuracies.
Please contact for further information
Kind Regards….Dave
Posted on Jan 03, 2009
  • 32 Answers
Collimation errors, as Dave talks about, can be repaired by a service workshop with a collimator if you can not get it right yourself. This is not something I'd normally recommend someone trying for themselves.
Posted on Mar 25, 2009
I can't see through the eye piece! The finderscope has been adjusted to view the moon but when I looked through the eye piece I could only see black :( its a tasco galaxsee 45-076280
Align the finder to the main scope during the day before using it at night. Use the lowest power (biggest number) eyepiece first.
Mar 10, 2014 | Optics
One image is slightly above the other at all distances. After using the binoculars for even a couple of moments, my eyes are strained. The problem was present when the binoculars were purchased, however...
The oculars are not aligned properly causing double vision. Check on the binoculars to see if there is a place to adjust the alignment of either of the oculars. Look for any loose screws that may cause the two oculars to be out of alignment.
If this is not the case try adding some torque to the binoculars to see if the will adjust to where they will both point in the same direction. The eyes can fuse disparate images slightly but there is a very small range that they can handle. If the two images are separated by more than this small amount it will cause eye strain and double vision.
Feb 13, 2011 | Minolta 10x25 Activa D WP XL Pocket...
I have a newtonian telescope 76mm with SR4, H12.5 and H20. I have aligned the crosses up and can see through the viewfinder but nothing through the eye piece. Ive placed all the other lenses into the eye...
YOU MUST align the small finder scope with the main tube.
Point the scope at a distant object like the top of a telephone pole. GET the top in the center of the eyepiece in the main scope.
Then without moving the scope-- adjust the cross-hairs in the small finder scope so they line up on the same object.
Feb 09, 2011 | Bushnell Deep Space 78-9003 (525 x 76mm)...
I have a pair of Plastimo military binoculars which have been fine up to now, but suddenly, despite being able to focus using the two eye piece controls, I cannot get anything other than a double image, no...
Hello - I never had Plastimo before but I have had a similar problem with double vision on a very similar looking pair of binoculars.
The eye piece movement just re-aligns eye focus differences , a double image usually means one of the lenses has moved inside the main tube. (usually from a knock/fall etc)
Can you rotate either one of the tubes ? On my pair I had to rotate anti-clockwide and found a prism inside that had slipped after a fall -
Close one eye and try to gauge which side is the best side -- Ray
Feb 05, 2011 | Plastimo Optics
Problem with alignment of Meade LX90 8" telescope
Start from scratch-
RESET the hand controller.
Calibrate motors using the same power source you will use outside.
Re-train the drives
Calibrate sensors on Polaris
Use either the 110 volt power cord, or buy a 12 volt power pack and the proper Meade 12 volt cable. (www.scopestuff.com carries the right 12 volt cable)
If your scope is NOT the LNT or GPS model you must level the tripod before you align. Go to home depot and buy the $3 small plastic two way bubble level, or the bulls-eye style bubble level.
Further trouble, I suggest going to the LX90 Yahoo group forum, and asking questions there.
Good Luck
Aug 30, 2009 | Meade 8" LX90 LNT Schmidt Cassegrain...
Mirror fell out and broke I've got the 25 mm eye piece and lost the others
Not worth fixing-- next time you buy a telescope look at a small Dobsonian like this one--
http://www.telescope.com/control/product/~category_id=dobsonians/~pcategory=telescopes/~product_id=09804
or the 6 inch version of the same scope--
Feb 19, 2009 | Meade Polaris 60EQ-D (36 x 60mm) Telescope
55' Magnavox Big Screen
Projection televisions do NOT generally offer easy DIY (do it yourself) solutions to problems. If they are telling you that the projectors need to be adjusted, you probably are better off buying a television elsewhere because they don't sound like they know what they are talking about. If the television uses CRT technology, you may notice color halos and bad color mixes if the red, green, and blue projection tubes are not aligned. Alignment should (in most cases) be done by a professional.
Have you turned on the television and seen for yourself what the problems are? If you know of a good repair center, get a quote from them after you have seen the issue(s) first hand, then make your final purchasing decision. It is terribly difficult to diagnose without seeing the condition of the television and images it produces in person.
Mar 28, 2008 | Philips Magnavox 55P9271 55" Rear...
Alpine dvd stereo double din
Your laser eye might be dirty or tired(out of alignment). Buy a cleaning kit, if it does not help try have someone who knows how to re-align it.
Mar 06, 2008 | Car Audio & Video
Front vent fell off
This should be a very easy fix. I assume you are talking about the plastic vent grill on the top of the oven above the door. There should only be a couple of screws holding it in from the top. The grill then should tilt out from the top first then from the bottom to remove. Since you said that it had fallen off, it sounds like the tabs where the screw holes are have broken off. This is a common problem. You can buy the part by ordering from the manufacturer, or from most repair websites. All you need is the model number from the microwave. Good luck.
Jun 19, 2007 | GE JVM3670 Microwave Oven
Swift Ultra-Lite 762 Binocular Logo
499 people viewed this question
Top Swift Optics Experts
Joe Lalumia aka...
Joe Lalumia aka...
Greg Cann
Greg Cann
Tom Chichester
Are you a Swift Optic Expert? Answer questions, earn points and help others
