Question about Panasonic Lands Phones
How to reset to original factory seting mocel KX-TG9331 home phohe
Base unit does not recor incoming callers message after greeting?
Noggin
  • 944 Answers
SOURCE: Hard reset of KX-TCD580 Base
Go to this link; http://panasonic.co.uk/customer-Support/download-centre.asp and input "KXTCD580" in the search box - after a few disclaimer screens you get to the manual for your phone. page 29 details reset for the handset Page 32 details base unit reset Page 48/49 details cancelling handsets to the base Hope this helps, please post again if you are still having problems with your phone :)
Posted on Apr 01, 2007
SOURCE: Panasonic KX-TG2740 Cordless Phone - Can I reset handset registration
press function button on handset, scroll to initial setting, select by pressing right arrow, scroll to registration, select, select hs registration, follow directions on handset display, pressing mute on "new" base station, and ok on handset(plugged in). If you like, you can unregister with the "old" base unit first.
Posted on Jan 16, 2008
SOURCE: panasonic cordless phone KX-TG9331, the
If you have listened to all messages on the answering machine, then this is the "tone" that the phone company sends out for those people who have paid voicemail with the carrier.
Page 41 of the manual - "if the handset still indicates there are new messages even after you ahve listened to all new messages, turn it off by pressing and holding [OFF] until the handset beeps.
Page 40 of the manual - "Turn VM tone detection on/off - the default setting is "ON" 1. [Menu], then press #332 then choose [OFF] - now when the phone company sends a tone out to your phone it will be ignored.
Posted on Jun 17, 2008
SOURCE: KX-TG6052 two handsets. Can't get Talking-Caller ID to turn off!
to turn the talking caller id off go to the menu press 0 then * then 4, then press 0 again to select off.
to turn the ringer on the handset back on, go to the menu, prees 1, 1, then press 1 for a low ringer, 2 for medium and 3 for high.
Posted on Jul 27, 2008
SOURCE: I have the kx-tg 4500
I had the same problem once, turned off the base unit from power cord and the phone line and all connected handset units, then turned it back on & it worked.
Posted on Oct 01, 2009
Just purchased Panasonic model #KX-TGF380 phone system. How do I turn off built in answering message and record my own message
Make sure that none of the handsets are in use. First, record your own message. Press Menu then # 3 0 2 from the base unit or any handset. Menu is the middle soft key below the LCD screen on the base unit. It's the right soft key below the LCD screen on the handsets. The # key is below the 9. Use the Up/Down arrows to highlight Yes and then press Select. See the screen for the appropriate soft key. After the beep, speak your message while you are 20 cm (8 inches) from the microphone on the handset or base unit. Press Stop when finished. (The phone will stop recording if your message is 2 minutes long.) Press Exit on the base or Off on the handset to leave the menu system.
Turn on the answering machine. Press the button with cassette tape symbol on the base. Press Menu # 3 2 7 on the handset. Your greeting should be heard by incoming callers unless the unit is set to Greeting Only or the memory is full. To check this, press Menu # 3 0 5 . Again, use the up/down arrows to highlight your choice. Press the appropriate soft key to Save the setting.
If you do not want to use the numbers, you can use the Up/Down arrows and Select. Press Menu, highlight Answering Device. Then highlight Greeting. Then select Record Greeting for the first step.
These steps are available in the manual. All except for the greeting length are on page 57. The last section is on page 63. This is available from the product site: http://shop.panasonic.com/cordless-corded-telephones/corded-telephones/KX-TGF38.html#q=KX-TGF380&start=1 . Click on the Support tab. The direct link to the manual is ftp://ftp.panasonic.com/telephone/om/kx-tgf380_en_om.pdf .
I hope this helps.
Jan 13, 2017 | Panasonic Lands Phones
My KX-TG2322 takes neither incoming messages nor outgoing ones` it says 'Memory Full', although no message is there.
Erasing all messages
All recorded messages, except the greeting
message, can be erased at one time.
1-Press [ERASE] while the base unit is not
being used.
• "To erase all messages, press ERASE again" is
heard.
2-Within 10 seconds, press [ERASE] again.
• The unit beeps, then announces "No
messages".
• The base unit display shows "0".
Mar 08, 2015 | Panasonic KX-TG2322B - 2.4ghz Digital...
My panasonic KX-TG5663B's screen says 9 and a little circle. The answering machine is not working. It just tells callers we are not available and hangs up. Can you assist us with this issue?
The answering system is set for the greeting mode. It will enter this state if the message memory is full or when the caller recording time is set to Greeting only.
To change the caller recording time from the handset, press Menu 0 6 2 then select the desired length of the recording. Then Save the setting and press Off.
If the phone is in this state, then delete messages from the unit. Then reset the caller recording time.
The manual for the phone is available here: http://www2.panasonic.com/consumer-electronics/support/Phones-Fax/Telephones/5-8-GHz-Phones/Operating-Instructions/model.KX-TG5653B.O#ts .
I hope this helps.
Mar 30, 2011 | Panasonic KX-TG5653B Trio Cordless Phone
How to reset voice record on my panasonic KXTG9331T?
Greeting message
When the unit answers a call, callers are
greeted by a greeting message. You can
record your own greeting message or
use a pre-recorded greeting message.
Recording your greeting
message
You can record your own greeting
message (2 minutes max.).
1 {GREETING REC}
2 Within 10 seconds, press
{GREETING REC} again.
3 After the base unit beeps, speak
clearly about 20 cm (8 inches) away
from the MIC.
4 Press {?} (STOP) to stop recording.
Using a pre-recorded greeting
message
If you erase or do not record your own
greeting message, the unit plays a prerecorded
greeting message for callers
and asks them to leave messages. If the
message recording time (page 39) is set
to “Greeting only”, caller messages
are not recorded and the unit plays a
different pre-recorded greeting message
asking callers to call again.
Playing back the greeting
message
Press {GREETING CHECK}.
Erasing your greeting
message
If you erase your own greeting message,
the unit plays a pre-recorded greeting
message for callers.
Press {GREETING CHECK}, and then
press {ERASE} while your greeting
message is playing.
Listening to messages
using the base unit
When new messages have been
recorded, the message indicator on the
base unit flashes.
Press {6}.
L If new messages have been recorded,
the base unit plays back new
messages.
L If there are no new messages, the
base unit plays back all messages.
Operating the answering
system
Key Operation
{^} or {V} Adjust the speaker
volume
{7} Repeat message
(during playback)*1
{8} Skip message
(during playback)
(STOP)
Pause message
– To resume playback,
press {6}.
– To stop playback
completely, press
{?} (STOP) again.
{ERASE} Erase currently playing
message
*1 If pressed within the first 5 seconds of
a message, the previous message is
played.
check if this works and tell me if any issues
Apr 30, 2010 | Panasonic KX-TG1033S Cordless Phone
Can you set the answering machine to answer with a greeting, but not record an incoming message? I just want to leave a greeting, but with no option for the incoming caller to leave a message.
On page 42 or so of your manual, there is a Greeting Only option MENU 0 6 2, where you can adjust the message length or set the G.O. option.
Carl
Nov 07, 2009 | Panasonic KX-TG5632 Phone
How do you set up the message for the answering machine? Lost the instructions that came with the unit. I know the phone has a menu, but not sure if this is where I would program the answering machine.
Greeting message
are greeted by a greeting message. You
can record your own greeting message
or use a prerecorded greeting
message.
message
message (max. 2 minutes and 30
seconds). If you do not record a
greeting message, a prerecorded
greeting message is used.
1 {MENU}
2 {V}/{^}: “Answering device” i
{OK}
3 {V}/{^}: “Record greeting” i
{OK}
4 After the handset beeps, speak
from the microphone.
5 To stop recording, press {OK}.
6 {OFF}
Using a prerecorded greeting
message
prerecorded greeting message for
callers and ask them to leave
messages.
Sep 11, 2009 | Panasonic KX-TG1033S Cordless Phone
Configuring caller IDfor India
Were those other instruments purchased in India? The problem is that the U.S .uses a different"signal" to send caller ID than India.
May 28, 2009 | Panasonic KX-TG9331T Cordless Phone
The pre recorded message on the answering machine has been lost.
I read thru the manual. There is nothing bout recovery of factory messages. If you recorded your own, try deleting it. Or unplug the base from power and try a reset. This is from the manual. At the end, I gave you a link to the manual!
message
http://service.us.panasonic.com/OPERMANPDF/KXTG9331.PDF
Nov 21, 2008 | Panasonic KX-TG9331T Cordless Phone
Volume of incoming calls
Press the down arrow under 'Volume' on the base unit. The handset volume is in the middle and has a down arrow on the bottom of the large silver button.
Aug 24, 2008 | Panasonic (KX-TG1032S) Phone
Lands Phones Logo
59 people viewed this question
Top Panasonic Lands Phones Experts
john milligan
george  peters
george peters
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
