Question about NEC MultiSync LCD4010-BK TFT 40" Flat panel Monitor
Ultra Brand 40# LCD Tv. (model# LCD-40-500
I have a picture problem my picture wil black out with line through it it looks like signal problem going in and out. But i just signed up for Direct T v and hocked up my dvd and it still is going in and out.
  • 185 Answers
Make sure all your cables connected are connected correctly first.then try it with another t.v if you can because it could be the T.v that is faulty and needs to be fixed or replaced.
Posted on Jan 05, 2009
Samsung 40"tv LCD HD got lines and black patches on screen model LA40A330J1XXA version ACO3 can it be fix Rasool
Look very like display panel fault. If you wish to get some details; visit the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Jan 18, 2017 | Samsung Televison & Video
Outputting aux audio
the unit has 2 audio out ports
that you can send to your amp
plug rca cables to the correct aux inputs on your amp and switch the amp to the correct input on the controller and you will hear sound
ps we needed to more about your amp in this case but if it has a red fiber connection for audio that is better because it is digital between the TV and the amp
http://www.digimetroonline.com/tv/2006/03/02/famous-brand-ultra-lcd40-500-40-inch-lcd-tv-wspeakers-refurbished
Feb 09, 2018 | Ultra LCD30-500 Television
HI, I have a 40" Samsung Flat Screen TV (Model:
This will not be easy to be 100% correct as to what part is bad as you can see in my pictures here.
It can be bad main board, T-CON board, Bad LCD panel.
http://s807.photobucket.com/albums/yy352/budm/LCD%20panel/
I would try new T-CON since it is the cheapest part, not worth to repalce LCD panel.
Basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Parts: www.interliquidparts.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Oct 10, 2011 | Samsung LN-T4061F 40 in. LCD HDTV
Black screen w/ my sony bravia KDL-40V4100 and it will turn on, but there is no picture or sound. I was told it could be a possible issue w/ the kdl 40s4100 board, but I'm not entirely sure. I've...
Search the site by type in the "BRAND NAME" of your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Apr 10, 2017 | Sony Bravia KDL-40S4100 40 in. LCD TV
I have a Polaroid 40" TLX-04011C. The screen resolution is fine except for about a 4" area along the right side from top to bottom. This area is lighter than the rest of the screen. The picture is still...
I have not repaired this particular model. But I have repaired another polaroid flat screen TV. I can tell you for sure, the biggest problem here are bad capacitors in the signal board. You may find 15 or 20 bad caps. On the power supply there may be a two or three caps that need replaced as they will be weak but not real bad. Yes,the majority of the caps will be found in the signal board. You will need a good capacitor checker to locate these. It will require patience and skill to remove and replace these caps. I cannot say enough of bad capacitors in this TV. Find a TV tech to help you! Thanks for asking, show me a few hands of appreciation. This answer is your best effort for repair!
Sep 19, 2010 | Polaroid TLA-04011C 40 in. LCD TV
Ultra LCD 30-500 TV, audio but no video. Worked fine for 4 years until 3 days ago when the screen would go black intermittently. Now there is no video period, only audio. Does anyone have a solution or...
The problem can be bad backlight inverter board or the 24vdc power supply for the backlight inverter is not working, it is easier to look at the power supply module than to get to the inverter board, These are the two most failure parts in LCD TV. Look for bad capacitors in the power supply first or burnt parts.
Please leave a feedback on what you find.
Nov 11, 2009 | Ultra LCD30-500 Television
Ultra 40" LCD40-500--- Need power supply for this LCD TV--- see below for spec's
Hi!
If anyone would like a Power adapter for their Ultra LCD30-500 and LCD40-500 - please email me Acosta.cal@gmail.com... And I’ll be able to order one…
I too own a Ultra Lcd40-500 HDTV. Bought it from HSN.com back in 2006.
My power adapter burned out 2 weeks ago, and to my dismay PWW, or should I say POS has gone bankrupt.
I looked everywhere online and here in San Jose,CA thinking I would find a replacement or at least someone that could repair the blown capacitor( 630v vpmm), thermitors(IRFD460A) and varistor( SCK206).
After calling every power supply company, distributor, and retailer, had no luck finding a match to this crazy looking 9din pin adapter. Disappointed I gave up on a replacement and took it to various repair shops for repair and was told without schematic would be nearly impossible to replicate the power Output. Finally this one shop was able to replace the burned out components and it seem to work at the store. When I got home with it..no luck..red light would come on…but no light on screen. L
Not wanting to give up or trash my LCD. It was time to dig further…I did some research through my employer; a SemiConductor company here in Santa Clara, CA.
Needless to say this power adapter has driven me crazy….It has been exhausting... But finally just yesterday I got the break needed…I found a manufacturer in Taiwan that has these power supplies for both the Ultra lcd 30" and 40". I was told they only sell to Component or Electronic Suppliers. I’ve asked my employer to see if I would be able to order one on their behalf using their account.
Happy ending! My power supply is on it’s way. I was told it could take up to 4weeks for delivery. But I’m just glad to have a replacement.
Mar 16, 2009 | Televison & Video
Hi!
Oct 18, 2008 | NEC MultiSync LCD4010-BK TFT 40" Flat...
Computers & Internet Logo
186 people viewed this question
Top NEC Computers & Internet Experts
parusdi rusdi
Level 1 Expert
Steven Wander
Steven Wander
Alun Cox
Are you a NEC Computer and Internet Expert? Answer questions, earn points and help others
