Question about Bernina Sewing Machines
Hook race bernina 1001
When I sew it my machine makes a grinding noise within the bobbin area. I think I need to clean around the hook race but I have no idea how to remove the hook. There is a lever but I can't see how it does anything... I have no idea how to remove this so i can clean it. Please help!
3 Suggested Answers
  • 6 Answers
SOURCE: Bobbin Carriage clanking noise, yet the machine sews fine??
If your bobbin area is making a noise, then do NOT sew with the machine until a reputable technician looks at it. You may have thrown something just a little off line - not enough to affect sewing NOW, but it could easily cause troubles down the line.
I suggest you call ahead and talk directly to the repair person - not to the sales person. Ask if you can bring in the machine while he/she is in the shop so they can listen while you run it.
You aren't trying to cheat the store out of the repair charge, just ensuring that the problem is diagnosed correctly.
You paid lots of money for this machine - it deserves good care.
Posted on Dec 30, 2007
  • 166 Answers
SOURCE: There is a noise when I sew in the bobbin case
Sounds to me as though you're not pressing the hook retainer back into place properly, or that the spring retainer is not properly engaging with the metal 'pip' on the left-hand-side of the 'U'-shaped hook retainer. You should press the hook retainer back until there is a definite 'click' and you should see the spring clip on the left just move a little bit when it clicks. You definitely shouldn't be able to 'loosen the hook race cover' at all - if you can, the hook will be able to rattle-around in the hook race causing noise and (probably) inconsistent stitch formation. The other thing you mention is that you 'cleaned-out' the hook race, but you didn't mention oiling it. If your machine has got the lightweight hook/shuttle that is black plastic with a metal hook around the outside, Bernina claims these dont need oiling, however, I've found that a small drop of oil will improve the performance of these machines immensely (note a SMALL drop of oil !). If you have an all-metal hook, you most-definitely need to oil it after cleaning ... lack of oil is probably the biggest cause of noise in machines of this type.
Posted on Oct 27, 2011
Bernina 1080 Solution for "back spin"? Top thread suddenly becomes very loose. Top thread forms loops under cloth being sewn.
Try these suggestions
1. Change the needle--use a needle that's for the fabric being sewed
2. Rethread the machine--top --make sure to use every thread guide
3. try a different bobbin--make sure bobbin is inserted correctly into the bobbin case
& make sure the bobbin is turned the correct way in the bobbin case
4. make sure the thread has not come off the thread take up lever
5. Clean under the needle plate & in the bobbin area for lint or threads
6. Check to make sure the bobbin is not warped or damaged
7. Make sure the bobbin case is correctly in the machine,, if it's a top loading bobbin you may need to have the bobbin case checked to see if it's damaged or see if the hook and hook race has a problem
8. Make sure the top thread tension is on the correct setting for the fabric being sewed.
9.Also could be a timing problem, and the machine would need to be checked.
Jun 05, 2014 | White Sewing 915
Sewing machine wheel won't turn, motor whirrs also the wheel seems to be jammed, it cannot be turned either clockwise or anticlockwise
Make sure your bobbin winder is not engaged. Ten check to see if you have thread stuck in the bobbin race area. That's where I would look first.
Sep 12, 2013 | Bernina Sewing Machines
My mother has a bernina 1008 and now that we have taken the bobbin casing out to clean it won't catch when threaded. Any ideas?
Are you threading the bobbin case correctly - the bobbin should rotate clockwise when pulling the thread out under the tension spring. Are you ensuring that the bobbin case is firmly clicked back into position when replacing it. Check your needle is OK. Did you remove the hook from the hook race when cleaning out - have you oiled the hook race ?
Jan 22, 2012 | Bernina Sewing Machines
My Activa 130 makes a clacking sound when I sew. It is 10 years old. What do you think is wrong? Can I repair this or do I need to take it to be serviced?
I would take it to a Bernina repairman, nice machine and well worth getting it serviced by a qualified technician.
I presume that you've tried the obvious things like a new needle and checking the bobbin case is in correctly.
Sep 03, 2011 | Bernina Activa 130
The needle shaft wont go up or down when I step on the foot pedal and I cannot turn the wheel to try to do it manually.
If you can not turn the handwheel at all there is a bind in the machine somewere. The most comon place that this will happen is in the hook/bobbin/race area. Follow these steps and it may fix your problem.
Remove needle and bobbin case.
We need to open the race and remove the hook. (The race is the black round part that the bobbin goes inside.)
On the left part of the race there is a small steel clip that you push to the left and it should fall open.
Then remove the hook, it may have fallen out alreay. (It is just right behind the race.)
Clean out that area and make sure there is no broken needle/lint/ ect.
Test to see if handwheel is moving freely with the parts out.
If so lubricate the hook and put it all back together. Should be ready to sew.
Hook needs to be lubricated every 2-3 bobbins
If this does not fix it probably will need to take it in for repair.
Also check to make sure your bobbin winder is not on (I dont think that is it but ill mention it).
Hope this helps
Apr 05, 2011 | Bernina Virtuosa 150
I have two maintenance questions: 1) Is it okay to clean it using canned air? 2) Should I oil it periodically and if so where? I have a Virtuosa 160. Thanks for your assistance. Becky
I'd advise against using canned air, because unless you aim it very carefully, you'll most-likely blow the fluff and lint into the machine rather than out, which will lead to long-term poor performance. Use the provided brush to brush out fluff and lint and always make sure you brush it towards you so that it comes-out through the open bobbin door ... never brush away from you otherwise you'll just brush it into the machine. To oil, remove the hook/shuttle, clean the hook race thoroughly and preferably with a cotton bud, making sure that the groove that runs around the inside of the hook race is clean and not full of debris. Put a single drop of the correct Bernina oil into the hook race so that the oil runs around in that groove, replace the hook/shuttle and give the handwheel a turn to distribute the oil. Replace the bobbin case and job done. Now, remember this ... dont wait until your machine comes-up with the 'oil' symbol before you do it again ... you should be cleaning and oiling the hook race every 3-5 bobbins-worth of thread - if you do that, your machine will sound quieter, will produce much better quality stitch formation and will last a great deal longer between services (you do have it serviced dont you ???!!!).
Mar 05, 2011 | Bernina Virtuosa 160
Where is the shuttle race on a Bernina Artista 180? I'd like to be exact as to where to put the drop of oil.
Just to the left of the bobbin case you will see a small lever. Remove the bobbin case and push the lever and that will release the latch which holds the race cover and shuttle (hook).
Clean well with a toothbrush and place one small drop of oil on the edge of the hook where it makes contact with the raceway. Place the hook back and snap the race cover back on.
Oct 01, 2009 | Bernina Artista 180
General up-keep and maintenance for activia 140?
Clean, clean, clean the bobbin race area, oil the designated oiling spots (if there are any), and change the needle for each new project (or 6 hours of sewing). I'm not a Bernina user but have sold another swiss brand and in our training the need to clean and CHANGE THE NEEDLE was stressed heavily. Many users will leave the needle in place until it breaks, sewing through thick and thin, knits and wovens. And there is always going to be lint building up in the bobbin race area which will eventually "felt" up into a wad if left. Simple cleaning is lifting the needle plate, (or opening the front flap if front loading), removing the bobbin case, and brushing around the whole area carefully with a small soft bristled brush. Then oiling (with quality light machine oil), running gently for a few seconds unthreaded, then reassembling. Also wipe down the exterior of the machine with a damp cloth and clean between the tension disks by sliding a single layer of fabric into them.
Jan 27, 2009 | Bernina Activa 140
Dec 30, 2007 | Bernina Activa 130
Sewing Machines Logo
Top Bernina Sewing Machines Experts
Tally Girl
Tally Girl
jnissen
Level 1 Expert
Derek Massey
Are you a Bernina Sewing Machine Expert? Answer questions, earn points and help others
