I have a LG washing machine , model is WD-8074FHB it's flashing an error code "IE" does anyone no what it means ?
    Top Expert:
  • Washing Mach... Master
  • 9,472 Answers
Take a look at this page.
Posted on Oct 29, 2012
SOURCE: LG washing machine Model WD 1433RD
I had the same problem. I thought it was the motor it turned out I had a nickle wedged in the filter (bottom left behind panel) the nickle blocked the water pump makeing the pump overload.
Posted on Jan 10, 2008
geemarie
  • 876 Answers
SOURCE: Error code SE on LG washing machine means what?
It probably means System Error. Have you tried a simple reset. Pull the machine away from the wall carefully, make sure you do not have wet hands or feet, etc and unplug it from the wall. Leave it unplugged for 20 minutes. (Also check to see if it is plugged into an outlet with a little red button on it? is the button pushed in? It should be? ) After the wait, plug the washer back in and see what you have. I hope this helps.
Posted on Aug 15, 2008
SOURCE: LG washing machine error codes
I have today the same error code on model WD-11155FB. This code means that the speed of the electrical motor can no longer be controlled. The velocity sensor placed just behind the motor is probably damaged but it can be also the electronic board where is connected this sensor, or the wiring between these two items.
Posted on Aug 16, 2008
Brussels
  • 16 Answers
SE is a sensor problem as per LG support. I will post a follow up after I have recieved the technician in 2 days
Posted on Nov 03, 2008
MNTECH
  • 1543 Answers
SOURCE: WHAT DOES ERROR CODE IE MEAN ON LG DIRECT DRIVE
IE = Inlet Error. Check for plugged screens where hoses screw onto machine (especially the cold side). Other possibilies are kinked hoses, valve shut off where hose goes to washer, or a bad inlet water valve (the part the hose screws onto), or even a bad control board or bad wire to water valve.
Posted on Nov 27, 2009
My lg intello wd 8074fhb washer will be in the middle of wash cycle and an error message comes up se ..Can you tell me what this error message means..
LG's 'SE' means 'sensor error'. Sorry but you will need a repair visit I fear ;-0(
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C.
Jun 12, 2011 | Washing Machines
Can you provide a link to a LG Front Loader WD-8074FHB service manual
checked this site for your LG washing machines..
http://www.manualsonline.com/ex/thread/view/idThread/1035082
Mar 05, 2011 | LG Washing Machines
I own a lg fully automatic washing machine front loader (model:WD-8074FHB)i dont have an owners manual. My question: There are 3 sections. 1st section is for washing detergent. Which of the other 2 are...
Hi Anna, As you face the machine the left section of the draw is for the main load washing powder, the middle section is for fabric softener and the right section is for the pre wash powde.
Hope this helped :-)
May 21, 2010 | Washing Machines
LG-INTELLO WASHER 7kg WD-8074FHB
"de" means door is open you have to close the door titly then press the start bottom or check door switch if its out of order or not with digital multi meter.
Apr 10, 2010 | LG WM1812C Front Load Washer
LG Intellowasher 7kg, Model WD-8074FHB - noisy spin cycle
You are right!
Bearings have to be replaced. Replace with the same type and design. All the bearings connected to the washer center shaft has to be replaced at the same time with new set.
Replace the water seals also connected to this. Check the shaft where the bearing sits, for any abrasions or metal damage.
Check the bearing housing also. While carrying out these repairs check the drive belt also. If needed replace it.
If you are happy with the machine outer body and other aspects repair it and re-use it.
Apr 07, 2010 | Washing Machines
IE problem
This is a water inlet error. Shut the water off and remove the hoses. Look ito the valves where the hoses screw on with a flashlite. If the filter screens are obstructed pull them with needle nose pliers. Clean them and replace them into the valves. Re attach hoses and try machine. If it still shows the code you have a bad valve.
Jan 27, 2010 | LG WD-16115FD Front Load Washer
LG FRONT LOAD WASHER ERROR CODE IE
LG has general error codes for all there appliances and the "ie" error code is for the water supply. You either have a kink in your hose, water vavle shut off, or the bad problem your pump is bad.
Jul 30, 2008 | LG WD-1045FH Front Load Washer
LG Tromm 8/4 WD R8012
The manual suggests to shut the water off ,
remove the inlet hose and check the screen for blockage.
The ie message is the inlet water is insufficient.
May 22, 2008 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Washing Machines Logo
241 people viewed this question
Top Washing Machines Experts
