Question about GE DBSR453EBWW Electric Dryer
My DBSR453EBww dryer shuts off before the clothes are dry.
It has to cool before it will restart.
  • GE Master
  • 3,463 Answers
Possibly the motor is overheating due to lack of ventilation, or the lint filter requires cleaning, make sure the outlet is clear at the rear of dryer, and that the vent hose (if fitted) is not kinked.
You could also have a problem with the motor itself which is causing it to overheat and the cutout is stopping the motor from working until it cools down enough to start again.
Plz rate my solution.
Thanks.
Posted on Jan 03, 2009
Dryer shuts off before cloths are dry,then then you have to wait about 10 mim before you can restrat dryer..cleaned vent duck to out side2 times to besure it was clean..cleaned venting back of...
Check motor for lint build up around motor. Will cause motor to overheat and shutdown on motor
overheat switch and will restart after cooling down.
Feb 11, 2011 | Dryers
Clothes taking a long time to dry
check your vent pipe for clugs there needs to be air flow for cloths to dry faster
Sep 10, 2009 | GE DBSR453EBWW Electric Dryer
Loud Squeaking noise when drying clothes
Might be the issue with the rotor bearings.
2.Might be there is some dust or other thing in rotor drum so please check and clean.
Aug 11, 2009 | GE DBSR453EBWW Electric Dryer
Heats and runs, but not long enough to dry clothes; then would not turn on and run at all. maybe dryer ''thinks'' clothes are dry?
Hi, After the dryer shuts off, can you restart it right away or does it need to cool down before restarting? If it needs to cool down for a bit, the motor is going bad. If the dryer is running a full cycle but not completely dry, check your venting to the outside and make sure it is clean.
If this is a gas dryer, the coils on top the gas valve might be shutting down early and not reopening later in the heat cycle.
I hope this gives you some direction. Please let me knwo if I can assist you further on this problem
Vic
Jun 13, 2009 | Dryers
My dryer used to shut off before the clothes are dry - now it wont start at all
Ok, the light will not come on if the door pressure swicth is damaged and, the dryer will not start if this switch is damaged as well. replace the door pressure switch asap.
Ok, concerning the interuppted drying cycle due to high heat, this can be cuased by two issue. It coudl be a venalation issue. if the dryers vent duct and exuast hoses are clogged, thsi will cuased the element to reach unsafe tempreturs, in return, tripping the high limit thermostsat and shutting the dryer off in the middle of the load cycle.
Another problme spot woul dbe a fualty high limit thermaostae. Although this is highly unlikey, this coudl be your issue.
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Note: It is recommended by most dryer manufacturers to replace a hi-limit thermostat when replacing a thermal fuse.
Jun 02, 2009 | GE DBSR453EBWW Electric Dryer
Dryer is not drying clothes.
well im not going to look up the model # to see if its gas or electric,but check the exhaust tube for blockages
Apr 21, 2009 | GE DBSR453EBWW Electric Dryer
Dryer takes many cycles to get clothes dry
While researching my problem I did find that the dryer vent hose could be partially clogged. The hose should be short and horizontal.
Mar 25, 2009 | GE DBSR453EBWW Electric Dryer
Intelli sensor doesn't read that clothes are wet,just damp.does not get clothes dry in intelli cycle.does get them dry in timed cycle.already replaced sensor.
do you stack clothes on top? If so take them off and try another load and never ever put anything on top. It insulates it and makes the dryer not run right. Good Luck
Feb 27, 2009 | GE DBSR453EBWW Electric Dryer
My dryer shuts off before the clothes are dry.
when the dryer shuts off immediately check all 3 sensors w/a ohm-meter to see which one is open. That will be the one causing your problem.
Jan 03, 2009 | GE DBSR453EBWW Electric Dryer
GE clothes dryer,model DPXR483EA1WW
Well this morning I got up and pressed the start button on my dryer and it's been working eversince. Thank-you I will contact you if I have any more problems. Jessica
Jul 18, 2008 | GE DBSR453EBWW Electric Dryer
GE DBSR453EBWW Electric Dryer Logo
98 people viewed this question
Top GE Dryers Experts
Dave Harrison
John Tripp
John Tripp
vince
Are you a GE Dryer Expert? Answer questions, earn points and help others
