Question about Badger 1 All Insinkerator 76039h 1/3 Hp Feed Garbage Disposal Black Opened
Kitchen sink won't drains only when garbage disposal is on
  • 5,245 Answers
Remove tubular pipes under sink and clean out disposal.
Copy following links for steps for clogged disposal:
http://waterheatertimer.org/How-to-repair-and-install-Garbage-disposal.html
Posted on Oct 31, 2012
Why does kitchen sink drain water from drain side to garbage disposal side
The two drains are connected, but below the disposal. Likely if it's not draining down, you still have a clog, and the person the "cleared" the drain didn't.
Sep 03, 2014 | Garbage Disposals
When dishwasher is emptying it is backing into sink
there is probably nothing wrong with Dishwasher itself.
Your Sink drain is stopped up or your Garbage disposal is clogged.
usually, dishwasher drain is connected to the Garbage Disposal, but if the dishwasher empties the water into the Garbage disposal, if its clogged then water will come out of the sink. Same if sink is clogged between sink and sewer.
If you fill up your sink and then water drains away, then you know your sink itself is not the problem. If its only the Garbage disposal side that does not drain, its the garbage disposal that is clogged.
Dec 22, 2013 | Dishwashers
I bought a new kitchen sink and pipes with a garbage disposal. Over night the smell in the garbage disposal is like rotten eggs! How can I make it smell good?
Use hydrogen peroxide and/ white vinegar to safely deodorize disposal.
Clean out drain line under sink, and bottom of disposal under cutter blade.
Copy following link for clogged disposal, and drain line tips.
Oct 18, 2012 | Swanstone KSLS-3322 Double Bowl Kitchen...
Whirpool built-in puddle of water in bottom, food on drain
see this causes and proceed according. God bless you
Belt, Water Pump Although few dishwashers have a water pump belt, if the dishwasher won't drain there might be a worn or broken water pump belt. After removing the lower kick panel the motor can be seen in the front, the water pump belt is on the bottom of the motor.
Drain Pump If the dishwasher won't drain, the drain pump might be defective. Test the pump motor with an Ohm meter. Drain pumps are not repairable, if it's defective it will need to be replaced.
Drain Impeller The drain impeller is attached to the pump and pushes the water out of the dishwasher, through the drain tube and into the garbage disposer or drain line. If the dishwasher won't drain, the drain impeller might be broken or worn out. Replace both the impeller and seal at the same time.
Drain Solenoid Kit If the dishwasher won't drain, the drain solenoid kit might need to be replaced. The drain solenoid is an actuator that opens a flap to allow the water to drain.
Drain Valve The drain valve can get clogged with debris and should be cleaned out if the dishwasher won't drain. If it seems clear of debris but won't actuate, it will need to be replaced. The drain valve is not repairable Pump and Motor Assembly If the dishwasher won't drain, the pump and motor assembly might be defective. If the motor runs during the drain cycle, check for a blockage in the drain line. If the motor won't run during the drain cycle or if it just hums when it should be running, the pump and motor assembly might need to be replaced.
Clogged or Improperly Installed Garbage Disposer If the dishwasher won't drain and the garbage disposer was installed recently, the installer might have forgotten to knock out the drain plug from this disposer. All garbage disposers are sold with a solid plug in the drain tube for situations where a dishwasher isn't connected. However, if the dishwasher is connected, the plug will need to be removed. If the disposer wasn't replaced recently, remove the dishwasher drain hose from the disposer and clean out both the fitting on the disposer and the end of the drain hose. These are the most common places to find an obstruction if the dishwasher won't drain.
Check Valve If the dishwasher won't drain the check valve might be stuck closed. The check valve is a small plastic device which prevents water from returning to the dishwasher after it has drained. If the valve gets stuck closed, it will prevent the water from draining. The check valve is the device that the drain hose is attached to on the dishwasher.
Check Ball If the dishwasher won't drain the check ball might be stuck. The check ball is a small plastic ball in the check valve which prevents water from returning to the dishwasher after it has drained. If the ball gets stuck, it will prevent the water from draining also. The check valve is the device that the drain hose is attached to on the dishwasher.
Oct 16, 2012 | Whirlpool Dishwashers
Our sink and garbage disposal was clogged up. We got the sink unclogged, but the dishwasher had dirty water in the bottom and won't drain.
Your dishwasher drains into the garbage disposal. It you tried to use a plunger to clear your clogged sink or run the disposal with to much junk in it you may have force debris into the dishwasher drain hose. With both the dishwasher and garbage disposal disconnect from power disconnect the dishwasher drain hose from the garbage disposal. This is usually about a one inch black hose. Clear out any debris in the hose and inlet nipple on the garbage disposal. If debris is compacted far down the hose it will need to be disconnected from the dishwasher end and remove to clear the blockage.
Steve
Feb 10, 2012 | Asko 1385 Dishwasher
I have a Badger 5xp & a double sink. When I turn the disposal on I get a small eruption of water, air and disposed of debris from the other drain.
Take apart the tubular drain pipes beneath sink and clean out everything.
Take photos before removing pipes so parts go back together easily.
Loosen 2 nuts on trap, and trap falls loose.
Remove 2 bolts/screws and remove tailpiece from side of disposal.
Then run snake down drain line leading away from sink to make sure blockage is removed.
I wrote ez disposal steps that give tips on reconnecting tubular drain pipes:
http://www.fixya.com/support/r7929008-replace_garbage_disposal
Sep 24, 2011 | Buck In-Sink-Erator BADGER 5XP BADGERVEXP...
My viking dishwasher won't complete it's cycle. The error code that flashes is the heavy pots and pans. We've checked the filter and drains and nothing is clogged. What else could it be?
Have you checked the kitchen sink drain and air gap if one is installed in your kitchen. If using the garbage disposal unit in kitchen then make sure it is clear.
provide model number of dishwasher for further diagnosis.
Aug 28, 2011 | Dishwashers
BADGER DISPOSAL UNIT 5-81 SEEMS TO WORK, IT'S NOT STUCK BUT THE WATER WON'T GO DOWN IN THE SINK. ANY SUGGESTIONS.
Clean out the p-trap and tubular drain under the sink:
I wrote ez disposal replacement steps that cover how to take apart tubular drain pipe and put it back.
Jun 11, 2011 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Garbage disposer drain pipe is lower than the p-trap
Sorry you are doomed. The only other way to install is to have a plumber come back out and lower the drain in the wall.
Sep 09, 2009 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Dishwasher draining into kitchen sink!
Is the water coming out the holes of the airgap "vent". If so, you have an obstruction from the hose that goes from the "vent" to the garbage disposer and is causing the drain water to back up. __________________
Jan 12, 2009 | Jenn-Air JDB6510 Built-in Dishwasher
Badger 1 All Insinkerator 76039h 1/3 Hp Feed Garbage Disposal Black Opened Logo
282 people viewed this question
Top Badger Home Experts
Donni Steen
Tom Chichester
Are you a Badger Home Expert? Answer questions, earn points and help others
