Question about Panasonic RQ-CR07V Personal Cassette Player
Doesn't play cassettes
My AWIA HS-TX426 can't play cassette tapes
John Check if the capstan is rotating This is a shaft that touch the rubber wheel in the cassette Does the motor run properly? You say it is new then it should be under warranty take it back to the supplier and they should repair or replace it. If it was standing for a very long time i.e. 20 or more years then the mechanism is bound and if you know what you do then lubricate with sewing machine oil on all levers and shafts the motor can also do with a single drop ( 1 millimeter wire dipped for 25 mm in the oil and the oil that drops off, is the size of a measured drop of oil) I did get some Revox machines that were standing for such a long time and I had to use a pump pliers to get those wheel to turn they were BOUND but after playing it for a while they became working again
Apr 24, 2013 | Audio Players & Recorders
The slot of the cassette in my sony CCD-TR705E video Hi8 doesn't close
Possibly faulty cassette eject mech as the click locking is mechanical before it latches the cassette in switch
Apr 17, 2013 | Video Cameras
Used isuzu radio/cd/cassette will not work in my vehichle, does it need a code?
If it works @ all it doesn't need a code - it's a bad CD player.
td
Nov 05, 2012 | 1998 Isuzu Rodeo
How do i replace radio cassette player with a cd player mazda 6 2002
Don't replace it. Go to Walmart and buy an adapter. It is usally at the check out somewhere and It cost about $5.00. It has a cassette that goes into the cassette player. Then you plug your ipod or whatever into the attached wire. Doesn't look cool but it works and it is inexpensive. The adapters with the cd player attached skip (we had one 20 years ago) so just buy the new kind of adapter for less and play all your up to date gadgets. Put your cd songs on your ipod or iphone. Our son uses one in his truck with his little ipod shuffle. No cd player needed.
Sep 12, 2012 | Mazda Cars & Trucks
Power goes off when a cassette is inserted. Tried cleaning heads but it won't even run that. When power is turned back on the cassette is immediately ejected.
Good day!!!
Most common problems
  • VCR refuses to FF or REW and shuts off.
  • VCR shuts off entering PLAY or REC or at random during PLAY or REC.
  • VCR eats tapes.
  • VCR doesn't accept tapes or ejects them without cause.
  • Sound is wavery, fluctuating, or muddy.
The cause for all of these is very often a bad idler tire or other dirty, worn, or tired rubber parts
Sep 12, 2011 | Philips Magnavox DVD/VCR Dual Player
Need detailed description of cassette removal tool for Schwinn cassette. (manuf. name, model no. etc.)
Schwinn doesn't make cassettes. You want details but don't provide any.
A simple web search for "cassette removal tool" leads eventully to http://www.parktool.com/blog/repair-help/categories/cassette-and-freewheel-service
Aug 13, 2011 | Schwinn Cycling
Panasonic RQ-CR07V Personal Cassette Player Logo
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Michael Kovalik III
Michael Kovalik III
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
