Question about Lexmark Optra T610 Laser Printer
Optra t610 error 935/933/934
I don't speak english I'm brasilian I am the from Brazil
My lex optra t610 not working
have message error service 935 for printhead
  • 85 Answers
Replace printhead - scanner assembly. The scanner motor is not working correctly. Need to remove side covers, back of printer assembly, the top cover. Printhead is below the top cover
Posted on Mar 13, 2009
Printhead error 935
A Printhead Error message indicates that the printhead (laser scanner) unit inside the printer is not working correctly. Make sure the printer is plugged straight into the wall and not through a surge device or power strip. Power strips and uninterruptible power supplies can cause a low amperage problem, which can trigger a false printhead error.
Aug 13, 2013 | Lexmark Optra S 1625 Laser Printer
935 service printer head error. how do I fix it?
The Mirror Motor of the printhead is unable to reach operating speed. This means you have to replace the printhead.
Mar 08, 2011 | Lexmark Optra M412 Laser Printer
Lex E450 Fehlercode:935.xx
935 ERROR IS A LASER/PRINTHEAD ERROR. It belongs to the common problems of E350/352/450. UNFORTUNATELY THE ONLY SOLUTION IS TO REPLACE τηε LASER WITH A NEW ONE.. IN MY OPINION, IT IS AN Uneconomic repair..
Feb 03, 2011 | Lexmark E450dn Laser Printer
935 Service Print Error
935 - Mirror Motor unable to reach operating speed.
This error code indicates a problem with the mirror motor in the laser unit, the cable to the engine board cable or engine board itself.
Check the continuity of the mirror motor cable connected to J3 on the engine board.
If incorrect, replace the cable.
The voltage at J3-7 measures approximately +24 V dc.
If incorrect, replace the engine board.
If correct, replace the FRUs in the following order: engine board -> printhead assembly
Or you could try if a power cycle resolves the error (at least temporarily)
Dec 28, 2010 | Lexmark Optra T612n Laser Printer
I have an error on my Lexmark T632 printer saying 933 service printhead error, can you tell me what this means
Printhead error message indicates that the printhead (laser scanner) unit inside the printer is not working correctly.
First step trying to fix this is to turn printer off, and back on after 10 seconds. If this won't clear it, try and plug the printer in a different power point straight into the wall. If the error does not clear, the printer will probably require service to correct the issue.
Sep 28, 2010 | Lexmark Optra T610 Laser Printer
935 service printhead error
hello
check this link out
you will get aal the answers for all the printer issue s
http://www.all-laser.com/cgi-bin/webc.cgi/error_lex.html
let me know if you need any assistance
Mar 08, 2010 | Lexmark Optra T610 Laser Printer
PRINT HEAD ERROR
there are several different printhead errors 931 933 scanner motor died scanners bad. 932 934 935 are loose lock errors these can be caused by either the scanner or the engine board
Nov 09, 2009 | Lexmark Optra T614 Laser Printer
935 Service Printhead Error
This error indicates that the Printhead ( Laser Scanner ) is defective. Sometimes turning the printer off for a little & then turning it back on, gets rid of the error but it will usually return. The printhead is situated at the top of the printer under the top cover. It will need to be replaced.
Aug 06, 2009 | Lexmark Optra T612 Laser Printer
LEXMARK
That error indicates that you need to replace the Engine board. The part number is 11K1416, a service tech would need to replace it due to settings needing to be reset.
Jul 15, 2008 | Lexmark Optra T610 Laser Printer
Lexmark Optra T610 Laser Printer Logo
1,277 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
