Question about Remote Start System
Remote error viper 5501
2006 ford escape limited Viper 5501 remote start displays remote start error when trying to start. Only used one season and worked fine and now it won't start. Also when I push lock it says locked and then gives me a chirp sound and says door is open. But no door is open when I check and it does lock. Any help is appreciated and yes I have read the instructions but I only was given the owners manual not installation guide.
4 Suggested Answers
SOURCE: Viper remote start system just
I don't know which remote starter you have, but I have a Viper 5101. To fix this problem, I started the ignition, then turned it off, leaving the key in the ignition. I pushed the Valet button (it has a blinking blue light, mine is near my rear view mirror) and held it. Then, I pushed it 3 times, then held it down a 4th time. Then, I pressed the lock button once. I pushed the Valet button again to take it out of programming mode, and it worked! I got this sequence of steps from the installation manual online: http://www.scribd.com/doc/45065156/Installation-Viper-5101 Hope that helps!
Posted on May 24, 2011
Boole5555
  • 160 Answers
SOURCE: Viper 5101 Manual Transmission - can't start
First off, is it in neutral? It can't engage the starter motor if it's in gear. Secondly, If it was professionally installed, why not just take it back and demand that they fix it?
Your wiring should somewhat match this.
Posted on Jan 13, 2010
  • 132 Answers
SOURCE: how to program viper 5701 remote
Unlock doors
Push and hold f button for 8-10 seconds until amber light is on solid
Push Remote start button for about 4 seconds till amber light flashes 3 times
Put key in to IGN position
Push valet (black button) one time and release
Push and hold valet button
Push either lock or unlock on viper remote
Key out of IGN
Test unit
The horn or siren may sound afterwards to indicate SUCCESS!!!!!!
Posted on Apr 04, 2010
Viper 7153v remote start. I had some work done to my 2005 Ford F250 and not when I use the remote start, the truck will start,shut off in about 15-20 seconds, then restart and continue the cycle.
Just had the same issue with my remote start. 2006 f-350 with a 6.0 powerstroke. Remote start module was in virtual tach mode and that does not work with diesel engines. Just had to have the remote start reprogrammed and put back into tach sense mode. Hope this helps.
Oct 07, 2016 | Remote Start System
Why won't it start vehicle?
[PDF]Responder LE Model 5701 Security and Remote Start ...
xtremetruck.net/file/1101-Viper+5701+Owner's+Guide.pdf
the year, make and model of the vehicle; vehicle license number and vehicleidentification number. All ..... One five-button/2-way Supercode Responder LE RemoteControl. ? .... Disarm. Unlock LED blink for one second with 2 Beeps. Remote. Start..... Long-time Viper system users will notice the following differences:.
Viper LED 2-Way Security + Remote Start System
https://www.viper.com/car/securityremotestart/.../viper-led-2-way-securit...
Viper's elegant new Responder LE transceivers mark a giant leap forward in 21st century vehicle security and remote start, and an evolutionary milestone for the ...
Viper 5901 remote start error fix - YouTube
? 2:38
https://www.youtube.com/watch?v=wsSorAf88nw
Jan 13, 2013 - Uploaded by Power2ThePeopleZ
5901 won't start vehicle; gives an error. ... or even try to open the hood. the door remains locked when you start the car with theviper alarm.
Help With Programming/Pairing Viper Remote - YouTube
? 2:49
https://www.youtube.com/watch?v=cgbQsZuVyt8
Dec 2, 2010 - Uploaded by Paul L
I have a two-way remote from my Viper 5901 system. ... The other car (one in video) has the Viper 5701 system in it. .... and then release 3) press the remote start button 2 times until pairremote is displayed 4)press and old ... I had the same problem that the remote won't pair with the system no matter what.
15964701 Viper 5701 2 way alarm w/ remote start won't
Jan 05, 2016 | 5701 VIPER 5701 2-WAY ALARM w/REMOTE START
Viper 5806V Remote Issue
Maybe the battery in the remote is getting low.
Jan 12, 2014 | 5701 VIPER 5701 2-WAY ALARM w/REMOTE START
Viper 5701 not remote starting or unlocking
It's possible that you may have inadvertently locked the remote. Press "F" then unlock to unlock the remote. Then attempt to send your command.
Oct 15, 2012 | 5701 VIPER 5701 2-WAY ALARM w/REMOTE START
I purchased a avital 4103 remote start kit.i also have a viper 300 esp alarm system installed. my question is can i use the avital remote control to activate the viper alarm and start the car along with...
Avital and viper remotes even though they look the same, they operate at different freqs. Im a retired alarm installer i could never get them to interchange.
Apr 09, 2017 | Remote Start System
Viper 5901, Ford 2008 6.4/ When I use the trucks door keypad
If you use the viper remote to arm the alarm, you MUST use the viper remote to disarm the alrm prior to opening the door. The only REAL solution is to add the keyless entry feature to the viper system, and quit using hte factory remote all together.
Aug 09, 2009 | 5701 VIPER 5701 2-WAY ALARM w/REMOTE START
Viper remote starter sets off alarm.
Whoever hooked up your system did not hook up the factory alarm disarm and arm wires. Your car thinks it is being stolen as a result of this. You need to get a wire diagram of your car and hook up the proper wires.
Dec 12, 2007 | Viper (VGC421) Remote Control
Remote Start System  Logo
151 people viewed this question
Top Viper Vehicle Parts & Accessories Experts
Kevin Daniels
oneStan
oneStan
jason
Are you a Viper Vehicle Part and Accessory Expert? Answer questions, earn points and help others
