Question about Blue Microphones Blue ICICLE USB Microphone Interface
When I use my icicle and blue bird microphone i hear a lot of static and cant get it to go away. sometimes it is clear, sometimes there is just tons and tons of terrible static. I recently replaced the icicle with a different one, and a different usb cable to try to fix the problem - it didn't work! what can i do?
The Clip Light and Static ?
I don't know what make & model of microphone or clip light you're using, but try unplugging the microphone cable from the preamp. That will tell you if the problem is in the microphone or the preamp/amplifier.
If you still get noise with microphone unplugged, try checking the power supply. You'll probably hear any hum from power supply. Make sure you're using one that's recommended or sold by the manufacturer.
Finally, try replacing the output cable. Any open circuits in the output cable could cause hum & noise.
That's all I can think of right now. Good luck.
May 01, 2014 | Rolls MP13 Mini Microphone 1-Channel...
LEFT SPEAKER HAVE STATIC SOUND AND NOT CLEAR
Hi what are you listening to like cds or tape or radio also are you using copy cds
Apr 02, 2008 | Kenwood KR-X1000
Mic receives a lot of static and then cuts out. After a few seconds it seems to repeat.
This could be due to interference from other devices.
You could try changing to a different frequency (there are 20 to choose from).
Also move the receiver away from any strong electro magnetic fields (hearing loop amplifiers, CD/DVD players, TVs) or large pieces of metal and in clear line of sight of the transmitter pack.
Set up the aerials so that they are at a similar angle as the aerial on the transmitter.
Only use xlr balanced cables with good quality screening to connect the receiver to the mixer / amplifier. Keep signal cables well away form mains electricity cables as far as possible.
Wherever possible use balanced xlr cables on all other equipment.
Feb 13, 2011 | Audio Technica ATW-R11 Microphone
When i transmit if the other vehicle is anything over a mile away they get a lot of static. I can receive them clearly at up to 5 miles. What do I do to get better transmission? I have a K40 antenna...
Well if they are not hearing you over a mile but you hear them over 5 miles that is a good indicator that your antenna is working properly but your radio is not getting out there. First go ahead and check the TX knob. Turn it all the way to the right so you modulate as much as the radio will allow. Next turn the squelch knob all the way to the left until you hear static and then turn it to the right slowly until the static noise goes away. Some don't mind the continual static but I like to squelch it out. The TX being turned to the right will allow your radio to work at full capacity. If you still don't get reports much over a mile then you can try a power mike to help you out a bit. Your microphone could have seen it's better days and can for sure mess up your transmit. Make sure your SWR is low 1:1.5 is the goal not to exceed 2. If all that checks out then have it peeked /tuned and aligned by a tech. Good luck to you.
Feb 06, 2011 | Cobra 29 WX NW ST 40-Channels Base CB...
I have a gxl 2200 mic and my computer acknowledges the mic but i cant record anything because when i play it back there is no sound
You'll need a phantom power source, like an interface or mixer. Otherwise, the mic is likely in need of repair.
Sep 19, 2010 | CAD Microphones GXL2200 Professional...
Static problem
Try using a headset or lower the volume.
Normal 0 Two things can cause static.
First, If you have your speakers turned up to high it will give you feedback causing distortion and static. I recommend using a headset when videoing.
Second reason is, if you are using a laptop and have added an external microphone between the two it will cause distortion and static.
Not knowing the configuration of your computer makes it harder to analyze the problem.
So hope this is of some help. Bud
Apr 11, 2009 | A4tech Viewcam PK335 Webcam
Static with playback on samson-gtrack with windows xp
i have the same problem with my g-track on a macbook im just going to take the thing back
it works for a feww min when i first start recording the is falls apart
Jan 10, 2009 | Samson G-TRACK USB RECORDING MICROPHONE...
Microphone problem
First, If you have your speakers turned up to high orthey do, it will give you feedback causing distortion and static. I recommend using a headset when videoing.
May 28, 2008 | Logitech QuickCam Communicate STX Personal...
Bluetooth headset static
BOOHOO - The phone needs to be diagnosed to determine the issue so take it to a mobile service center
RLECANDAR - from my experience the JAWBONE is an awful headset most customers that buy then replace them with another headset
May 22, 2008 | Samsung SCH-u740 Cellular Phone
Blue Microphones Blue ICICLE USB Microphone Interface Logo
101 people viewed this question
Top Blue Microphones Electronics - Others Experts
Are you a Blue Microphones Electronics - Other Expert? Answer questions, earn points and help others
