Question about 1995 Altima Gxe Egr Valve Vacuum Switch
I have to tap the a.c. compressure to get 1995 nissan altima to start sometimes why?
    Master:
  • 416 Answers
Is the car hard to start or the AC?? if you hitting the compressor to get it to start, the clutch maybe worn out or is coming loose, check the nut in the center of the clutch and see if it is tight,
if the engine is hard to start, fallow the directions that Kenneth White gave you! Note: if you have to hit the starter to make it work, it needs to be replaced.
Posted on Mar 26, 2015
    Problem Solver:
  • 9 Answers
Sounds like it is starting to lock up. Take the accessary belt off and try to turn the compressor by hand and see if it feels rough. If not, try the starter, if it still wont crank , hit the starter lightly with a hammer. Then if it starts, thats the problem. By hitting the ac compressor you may have been jolting it enough that it shook the starter enough to make contact.
Posted on Oct 29, 2012
My 1995 Nissan Altima won't start. It has new head, radiator, coil, distributor, throttle sensor, it's been timed. It start for a few days and now won't start. There's spark, everythi
may be you should make a diagnostic and you can do it in a garage or you can do it by yourself if you want to do it by yourself you need some tools and you can find some good ones here: diyobd2.fr
Jan 28, 2013 | 1995 Nissan Altima
1995 Nissan Altima isn't starting. has power
No start is like having no battery The battery is new
Dec 11, 2012 | Cars & Trucks
1995 nissan altima starters bad how hard 2 replace
Not really easy.
It's under intake manifold , you need a lift.
May 25, 2010 | 1995 Nissan Altima
Where is the fuel pump for 1995 nissan altima located
The fuel pump for these is in the fuel tank. Lift up the rear seat and you will find an acess panel with 4 screws and some wires going through it. From there, gently remove the wiring harness and fuel lines. Take a screw driver abd a hammer and lightly tap the ring to the left(to unscrew) changing positions as to not put to much pressure on one area.
Mar 15, 2010 | 1995 Nissan Altima
Broken bolt for park brake cable on 1995 nissan altima?
Yes you could do that however it would probably be easier to drill them out and use new bolts. Might be a pain in the A trying to drill a self tapper into a car frame while lying on the ground.
Dec 30, 2009 | 1995 Nissan Altima
1995 Nissan Altima will not stay on
Change the cranksahft sensor, it hapend to my car and I solve this problem with it.
Jan 20, 2009 | 1995 Nissan Altima
1995 Nissan Altima starts rough, will not idle, shuts off
code 55 generally means no stored faults on nissan ecu's
Jan 06, 2009 | 1995 Nissan Altima
1995 Altima Gxe Egr Valve Vacuum Switch Logo
83 people viewed this question
Top Nissan Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Jim Y
Jim Y
Are you a Nissan Vehicle Part and Accessory Expert? Answer questions, earn points and help others
