Question about Braun Tassimo Espresso Machine/Coffee Maker
My Tassimo doesn't stop dispensing like it used to. I thought it read the bar code to know what to do but it doesn't seem like this is happening now. It now starts dispensing and just keeps dispensing like the directions called for two or three cups.
  • sphurley Jan 29, 2009
    I'm experiencing the same thing. I've cleaned the machine and still no luck. Sometimes it works fine and other times it will dipense the entire water tank if I don't turn it off first.
5 Suggested Answers
SOURCE: Braun Tassimo Coffee
Return it, I called Tassimo & it's a problem.
Posted on Dec 14, 2007
SOURCE: Braun Tassimo Machine willnot read the bar code on the T-discs
I have the same problem, I have been totally unable to clean the fog completely, instead I rub a tiny bit of cooking oil on it and it clears and will read barcodes again. Only a short term fix though.
Posted on Jul 03, 2009
SOURCE: lights keep flashing on my tassimo machine
if your lights are flashing on your mashine just keep your finger on the button untill its filter threw, willtake up to 2 mins. simon bernasconi
Posted on Oct 04, 2009
  • 35 Answers
SOURCE: hi,when my tassimo finishes filling the cup,it
For a Braun machine, unfortunately this is quite normal as it's part of the "purge" once it has finished brewing.
The new Bosch machines do not do this and finish their cycle with a steam purge instead.
Posted on Mar 25, 2010
The lid won't open to get the used coffee pod out. It seems to be stuck.
Customer questions and answers for Bosch TASSIMO T10
answers.tassimodirect.com/answers/.../bosch-tassimo.../questions.htm?...
The TASSIMO T10 Single Cup Brewing System by Bosch brings the artistry ... the machine made some funny noises and now I cant open the lid to remove pod. ... When I went to remove the T-disc, the tassimo won't open so I cannot get it out.Missing: tas5542gb
Bosch Tassimo TAS4511UC Coffee Maker Open ... - Fixya
www.fixya.com > ... > Bosch Tassimo TAS4511UC Coffee Maker
Question about Bosch TASSIMO Coffee Makers & Espresso Machines ... colors, openthe lid, put disc with the cream in the machine and the green light won't come on, only the . ... Bosch Tassimo Tas5542gb Multi Hot Drinks Machine, Black.
Why has my Tassimo brewer stopped working?
www.coffeedetective.com/why-has-my-tassimo-brewer-stopped-working...
QUESTION: I have a problem with my Bosch Tassimo brewer. ... Now when I close the machine, I open it and remove that litte tin foil circle. ... Opened my new Tassimobrewer and won't brew and water dispenser leaking all over... an ... I have a problem with my tassimo coffee maker the lid wont lift up seems stuck any ideas ...Missing: tas5542gb
Jan 19, 2016 | Bosch Tassimo Tas5542gb Multi Hot Drinks...
Yellow and red light on but nothing happening?
I have a Tassimo. The machine reads a bar code on the coffee cartridge that you put in before pressing brew button. You open the dispenser lid, place a cartridge in with the printing facing down. If you notice, the label has a bar code on it. There is a small rectangular window on the machine that you can see when you open up the dispenser lid. Make sure that the window is clean. If there is debris covering it, the machine wont be able to read the bar code and therefore will not know how to dispense for the specific cartridge you put in.
As for the manual, I found one on the Bosch website to download.
Good luck.
Jan 09, 2014 | Bosch Tassimo TAS4011GB Coffee Maker
Yellow light keep coming on when i try to make a cu of coffee
the optical sensor that reads the bar code could be dirty. My Tassimo sensor also needs to be "wet" before the disc is inserted to work properly. Seems that the plastic of the sensor has started to degrade and clouded over. When you clean the sensor just use soap and water. Nothing abrasive.
Feb 22, 2011 | Bosch Tassimo TAS4511UC Coffee Maker
All the lights on my machine are flashing. What
I had flashing lights in my braun tassimo and tried all previous solutions
Cleaned the barcode reader
Seated the water container properly
The problem was down to the flosting magnet in the water container (which was floating when filled)
The magnet had lost its strength somehow, so i held a strong magnet from from a fish tank cleaner at the back whilst the water container was in and it worked perfect
Inside the machine is a sensor which detects the magnet that floats in the water container
I am looking for a new magnet and will keep you informed if it worked when i get one
Good luck from Ash
Feb 05, 2010 | Braun Tassimo Coffee Maker
My Tasssimo coffee maker is 11 months old and isnt functioning.
Possibly all you need is to clean off the bar code reader window. It's right under where the bar code on the t-disc ends up. A little dried milk, etc., can cause your symptom.
Dec 18, 2009 | Braun Tassimo Espresso Machine/Coffee...
All the lights are flashing on my Braun Tassimo TA1200 and will not make coffee
Several possibilities: (1) No water in tank.
(2) Tank not inserted properly. Try removing tank and then replacing it, making sure that the hook-tab at the back of the tassimo body engages the matching slot at the front of the tank.
(3) Tank not seated properly. Try pressing down on the tank and twisting left or right. If this stops the blinking and allows your drink to brew, at least you know where the problem is. If you have to do this all the time, consider exchanging the unit.
(4) The lights will all also blink if there is residue (coffee, milk, etc) on the bar code reader window. The residue is usually plainly visible. The bar code reader window is a horizontal rectangel directly under where the bar code of the T-Disc sits in the Tassimo. To fix this, just wipe the window clean (no need to scrub), close the lid again and check for blinking.
Aug 07, 2009 | Braun Tassimo TA1200 Espresso Machine
Machine won't go to auto
Try cleaning the part on the machine that reads the bar code on your t-disc. This was happening to me. . . I cleaned that piece, and it started working properly again.
Jul 27, 2009 | Braun Tassimo Espresso Machine/Coffee...
Braun Tassimo 3107 or 3701
Yessir, you need a t-disc to use it, because the machine reads the bar code that is imprinted on the aluminum lid of the t-disc to get instructions of how hot the water should be, and how much water should be used for the beverage you're qnting to prepare. no t-disc, no drink, no working machine. it's that simple.
Oct 23, 2008 | Braun Tassimo Espresso Machine/Coffee...
Automatic dispenser
Clean it, especially the window for the barcode reader
Aug 08, 2008 | Braun Tassimo Espresso Machine/Coffee...
Braun Tassimo Espresso Machine/Coffee Maker Logo
60 people viewed this question
Top Braun Coffee Makers & Espresso Machines Experts
Henry  Thomas
Henry Thomas
Are you a Braun Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
