We have a Marantz 7500 receiver. We just moved our Runco TV and all the equipment to another area in the room. After hooking the cables, etc. up, everything works except the color on DVDs and our XBOX games. The color looks great on the TV. My husband tried three different cables (including Monster cable) for the output on the receiver and the colors are still off. We even brought in another TV and hooked it up. The problem was the same. Great color on the TV and crappy color on the DVDs and XBOX. Is something wrong with the receiver or are we missing something? Any suggestions? Thanks in advance for any help offered.
  • 4 more comments
  • mariacary Jan 03, 2009
    We tried to hook up three different sets of cables (including Monster cable) and the color was off with each set. We did this on two TVs and the color was off.
    We have a Marantz 7500 receiver. We just moved our Runco TV and all the equipment to another area in the room. After hooking the cables, etc. up, everything works except the color on DVDs and our XBOX games. The color looks great on the TV. My husband tried three different sets of cables (including Monster cable) for the output on the receiver and the colors are still off. We even brought in another TV and hooked it up. The problem was the same. Great color on the TV and crappy color on the DVDs and XBOX. Is something wrong with the receiver or are we missing something? Could it still be the cables even though we tried three different cables? Any suggestions? Thanks in advance for any help offered.
    We are certain that the cables are hooked up correctly (i.e. y to y, b to b and r to r).
    Convergence was suggested as a possible problem. Could convergence still be the issue since we tried hooking the cables on to two different TVs and got the same result in bad color?
    We have checked our cable connections at least twenty times.
    Sergeant:
    Champion:
  • 239 Answers
Recheck the cables conections from source xbox/dvd
Posted on Jan 03, 2009
  • Alvaro Domingues
    Alvaro Domingues Jan 03, 2009
    try connecting xbox/dvd direct on to tv !!
    Genius:
  • 1,142 Answers
Have you checked the cable connections
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Initially, a couple of ideas to explore/try:
  • bypass the Marantz 7500 receiver and connect the component video of the DVD and/or XBOX to the Runco TV;
  • if problem persists, settings/configuration of both the DVD and/or XBOX;
  • if color is correct, the Marantz 7500 receiver is faulty. Try unplugging the receiver for an extended period of time to revert to factory default or should a reset feature/button be available, engage/press;
  • try composite outputs of the DVD and/or XBOX to the Marantz 7500 receiver.
Good luck and Thank you for using FixYa.
  • Louie  Role
    Louie Role Jan 03, 2009
    that should read as:
    • if problem persists, settings/configuration of both the DVD, XBOX and/or the TV;
  • 818 Answers
The SR-7500 is capable of up-conversion from either the composite inputs or the s-video inputs.
Time based correction and anti-aliasing are applied to the lower resolution signals to ensure the best signal possible through the component monitor out. I tried this with a Game Cube and was pleasantly surprised with the results. I’d never been able to get the display from the GC to appear correctly formatted on my projector, until passed through the component out of the 7500.
  • Sergio Scalfaro
    Sergio Scalfaro Jan 03, 2009
    do you have prove with the RGB -> Component converter?
    Sergio
    Sergeant:
    Champion:
  • 201 Answers
For me it sounds if your NTC PALL settings on your tv needs to be udjust. Check it the dvd menu @ display if you can changes this or you can look @ your tv Settings for COL-SYS option you can put this to auto or just change it till you see colour do the same when your xbox is on. Look for NTC PAL NTC4.43
  • 470 Answers
I agree it's a convergence problem, as mentioned go into Settings in the TV menu and select Convergence if Auto it will do it when you select this. If not it will ask you to do "Multi-Point Convergence" which will bring up a huge grid on your screen. You must use the TV remote and using your up and down and left and right buttons to place the "curser" on each grid and adjust the Red and Blue on each point till you get a pure white "grid point" Think of the picture as split up into say 72 different puzzle pieces and when you adjust each piece it fixes that one piece of the puzzle or screen. You want all lines to be pure white and by looking at the grid if you see either blue or red on the side of the white line, you want to move the right, left, up or down button so that the blue or red line gets back on track with it's corresponding white line grid.
It sounds complicated but you will get it after a few seconds of playing around with it. Convergence should be done after the TV has been on for at least 30 minutes and should be done at least once a year (twice would be better at minimum) You see the problem with RPTV is they use three color lenses and as you watch TV, the lenses over time get out of alignemnt and need to be readjusted to get a clear sharp picture.
I adjusted a TV once that had never been converged in ten years and it took me over two hours to get all 72 points back on track, once done you will notice a way sharper picture and the colors won't be off kilter.
  • Antonio Buenafe Jr.
    Antonio Buenafe Jr. Jan 03, 2009
    Check for bent or broken pins on the cable connectors.
    Is your problem that the projector is displaying the wrong color or is it a color purity issue?
    How long of a cable are you running to the projector?
    What kind of cable are you using? VGA, RGB, S-Video?
    The reason I'm asking is that if you are running through a long cable you may get some color purity issues. This is caused by losses in the long cable. If this is your problem, then a simple VGA booster amp will help.
    If you are using S-Video from your computer, I would suggest going to the VGA output instead. The VGA output is a higher resolution output and it will support higher refresh rates.
    If you are using the VGA output, then you might want to try different refresh rates. You may get better color at a higher refresh rate.
    You will also get the best results if the VGA output is set to the native resolution of the projector. While some projectors will still show a picture at higher resolutions than the projectors native resolution, this isn't recommended. The reason is that the projector is simply scaling the higer resolution signal back down to its native resolution. The scalers in most projectors are not not very good. It is better to let the signal go through to the LCD or DLP of the projector without scaling. The specifications of the projector should indicate what the native resolution is. Set the output of the computer to this resolution.
  • 10,594 Answers
Just placing the system on another place and lost colors on those 2 units shows its problem of hooking wires incorrectly.
If you are using component video then recheck pin colors of each wire should be same on other unit, i.e red to red, green to green and blue to blue.
  • Shahid Electronics
    Shahid Electronics Jan 03, 2009
    OK, if cables are hooked correctly then play dvd and check TV color system. Set tvt color system to Auto, if TV has that option.
    Genius:
  • 1,550 Answers
There is nothing wrong with receiver . Have you tried connecting with different cable .Some times faulty cable can cause this problem .
How do i connect marantz rs2252. To tv
Do you have an audio out or headphone jack on the TV? If not you'll need a digital TV tuner converter box that does. If you remember, these are the "digital conversion" boxes the government provided when the USA switched from analog to digital TV. They sell for $50 - $60, have a input for TV system (antenna, cable, etc) and analog outputs that will connect to your Marantz via the "Aux" input. Purchase shielded "RCA male to RCA male" connection cables at Radio Shack, connect "Audio Out" from converter box to "Aux In" on Marantz and you're done.
Mar 28, 2015 | Marantz Audio Players & Recorders
I moved the box to another room and now I get a message light and cannot get the power button to work
Especially with newer systems (ie MoCA) you can't just move a receiver from one room to the next, they are set up more like a computer network with one receiver performing most actions and other receivers accessing the main receiver for content. Find the area where the cables all meet and make switch the cable that is going to the room the receiver was in with the cable going to the room the receiver is. If you can't tell which cable is which, you can get cable tracers for a few bucks, but it may be easier to call your provider for a technician.
Feb 28, 2015 | Televison & Video
Marantz SR4003
Hip shot: No one let's you record digital audio onto analog equipment (yet).
On looking at Page 26 of the manual, that is verified. (See the Notes). Use only the analog audio and it will probably work for you. The A/D switch decides which you will use.
Jan 28, 2010 | Marantz SR4003 Receiver
I just connected my new ps3 to my marantz 7500. my tv picture is fine but no sound same goes for me ps3 picture but no sound... my fm works sirius radio works cd player works i think i messed...
http://us.marantz.com/DFU_SR7500_Final_Eng.pdf
Page 18 of the manual will walk you thru the audio setup. It has Digital auto, Digital, Analog auto, Analog. Once this is set you should be fine, if you still have an issue, post a comment and I will help you further. Hope this helps
Dec 24, 2009 | Marantz SR7500
What is the error POW 5 on a marantz sr 7500
I have a POW 5 failure on a marantz sr 7500. Anybody know how to fix?
Jun 02, 2009 | Marantz SR-7400 Receiver
Need a user manual
here is a link for youe manual:
http://www.manualnguide.com/dl/5582/
please dont forget to rate this solution
thanks
tom
Dec 21, 2008 | Marantz SR-9200 Receiver
Televison & Video Logo
19 people viewed this question
Top Televison & Video Experts
