Question about Whirlpool Cabrio 7.0 Cu. Ft. Super Capacity Plus Electric Dryer
How would i truoble shoot on how to fix the bering to my cabrio dryer
  • Whirlpool Master
  • 8,220 Answers
I am getting an error code of AF when my Whirlpool Cabrio wed7300xw0 dryer is in operation. How can I fix this problem?
This is fairly common most of the time the blower drive belt or pulley has fallen off. This video should get you headed in the right direction. Although the video below shows a maytag dryer it is the same cabrio style dryer you have.
Sep 08, 2015 | Whirlpool Dryers
Squeaking Cabrio dryer when running
The squeaking is due to the drum glides or as some people call them slides, being worn or broken. Easy fix and very inexpensive part
Mar 25, 2014 | Whirlpool WGD8800YW Cabrio Platinum High...
Sensoring stays on and dryer will not work on Cabrio dryer
there is a fuse in the back of the dryer next to the bottom on the left hand side it has wires plugged into it cost $11.00 to fix don't call whirlpool they don't have a clue
Sep 05, 2011 | Whirlpool Cabrio 7.0 Cu. Ft. Super...
My ge dryer is hanging clothes around the drum and leaving them black. mostly wash cloths at a corner. it has a squeak like a cricket.
Hello darrellandru, the problem is most likely going to be the drum slides. On the top drum bering, there are four plastic strips, the drum sits on these strips and those strips are what the drum rides on. You may also have problems with the drum gasgket (the felt that is on the bottom plastic drum bering).
Sep 23, 2010 | GE Profile DPSR473EW Dryer
I have a cabrio dryer and it will not start. It
control panel is bad, use your warranty and get it fixed for free since it is only 2 weeks old
Jun 15, 2009 | Whirlpool Cabrio 7.0 Cu. Ft. Super...
Whirlpool cabrio steam electric dryer has sensor light on and does not work
have a problem with my cabrio dryer its powered on but when i push start the sense like comes on and does nother whats the problem
Apr 18, 2009 | Whirlpool ET8CHEXSQ Dryer
Crankshaft position sensor
go to autozone .com they have site that will help you right away with componet locations and truoble shooting and how to fix it all you do is enter your f 250 on how to fix it top left of there site you will be happy frm hoggharley@comcast.net
Feb 21, 2009 | 2005 Ford F 250 Super Duty
Sears Dryer 417.80042990
What is happening here, is that the front bering (the area between the front and the drum) has become worn. Its not a very expensive or time consuming job really. Remove the top, then remove the front. You will tilt down the front and door assembly. Dont worry about the drum falling out, Frigidaire uses a ball and hitch rear bering that will hold it in place. On the very top of the door opening indise the front cover (where the drum rides on that felt) you should see a felt like covering with like 4 or 5 plastic type drum glides. Replace the top half of this felt with those plastic glides attached (should be attached). Just re-glue the felt to the drum (glue should come with part, and watch it, this glue is for real if you get it on you). If you wanted to be a real explorer, its always a good idea the lube or grease the rear bering of these Frigidaire's while your this far into it. If you want to, just remove the belt (remembering how it went back on the idler pully), then, with two towels around your hands, grasp the drum at around the 10 o'clock position and tug upwards to remove the drum from the rear bering. Also be sure to remove the drum upper support (yellow looking clip thing front center that will hold the drum until you remove it). Use a good quality-high temp grease inside the bering and the ball on the back of the drum. This will ensure you wont have to go back in there again normally for the rest of your dryers lifetime. Enclosed a picture of the front bering glides and felt:
And a small break down of the front section. Your part will be #20 that you will be replacing.
http://www3.sears.com/imaging/ImagePageJava.shtml?productTypeID=0151200&brandID=0582&modelDesc=DRYER&modelNumber=41780042990&documentID=P0010402&documentTypeID=PLDM&documentClassCode=PM&titleType=DOOR&titleID=00002&
Let me know if you need any further assistance or have any other concerns or needs. Good Luck!!!! Jim
Dec 06, 2007 | Frigidaire FEQ332E Electric Dryer
DRUM RUBBING
It could be a number of things to cause drag on the drum. A rear bering or front slides sounds like the most common. The front slides are small plastic like parts that the drum rides on around the door area (GE Part Number GHPWE1M333). The rear bering is located on a stud that protrudes from the center of the rear of the drum. Remove the belt and slide the drum straight out. You will see the bering stud mounted to the drum. The bering will either be on the stud or still inside the bering holder in the rear of the dryer itself. Look for signs of wear or a torn bering. Grease shaft very well when replacing. Also, look for signs of wear inside the dryer to where the drum would be rubbing the case or cabinet. Both these berings are pretty inexpensive and if you have the know-how, easy to replace as well. Good Luck!!!! Jim
Sep 08, 2007 | GE DCSR483EA Electric Dryer
Whirlpool Cabrio 7.0 Cu. Ft. Super Capacity Plus Electric Dryer Logo
75 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
