Question about ATN Aries MK6500 Weapon Sight
Laser site in at 150yrds first shot good after that its off the board
I need to download free driver Canon LASER SHOT LBP-2900 Printer
You can download the Canon printer drivers from their support WEB site. Please click on this link and select your model printer to download : - http://www.usa.canon.com/consumer/controller?act=DownloadIndexAct
Jan 26, 2013 | Canon LASER SHOT LBP-2900 Printer
Topcon rl-60b
Hopefully it's the simple answer. The bubble vial may be out. start where the level vial says is level, and move outwards in slow circles to try and find a place the laser thinks is level. if you find a spot, use the 3 adjustment screws on the bottom of the bubble vial to make that your new center.
Otherwise, it's a not good news. A couple things could be gone wrong. The oil bath compensator could have leaked. If you open the laser, and it's oily inside, throw it away.
It could be the peep site could need adjusting, or the laser diode could be blown. If the laser diode is dead, same solution as the compensator leaking. There are no parts available for these anymore, chuck it out.
The peep site isn't a write off, per se. The laser operates by shooting the beam through a oil bath, which compensates for the instrument not being perfectly level, and then through a splitting lens. part of the beam travels up, and through the rotating head. And the rest goes through a peep site, to a light reflecting area of the main circuit board. if the board or peep site is no longer aligned, the laser will never think it's level. The bad news about that, it is a very tricky and time consuming repair, that few technicians know how to do, or if they do know how are most aren't comfortable doing it.
You can try taking the cover off, leveling the instrument, powering it up and trying to move the circuit board until the laser thinks it's level, but i wouldn't waste much time on it.
Aug 27, 2012 | Topcon Rl-60b Rotating Laser Level C/w...
Toner Refill for Canon LASER SHOT LBP-2900 Printer
you need Canon Cartridge 703
if you asking about it ofc...
Dec 14, 2010 | Canon LASER SHOT LBP-2900 Printer
How i can open the cartrigde 103/303/703 for refilling ....
Hi Good day!!! Turn off your laser shot and then open up the cover and then remove the ink toner. after you replace the toner put it back and then close the cover be sure to close it. Turn back on your laser shot 2900.
Thank you for using FixYa
Don't forget to vote thanks!!!
Nov 05, 2010 | Canon LASER SHOT LBP-2900 Printer
I have lasersot lbp 2900 canon printer but it does
Try the drivers here>
http://www.canon.com.au/en-AU/Support-Services/Support-News/Windows-7
or find your local canon site and look for a similar thing
Jan 19, 2010 | Canon LASER SHOT LBP-2900 Printer
Driver for cannon lbp 2900
go to france canon site web and download the driver. Good Luck
Jan 18, 2010 | Canon LASER SHOT LBP-2900 Printer
How to install the software from which website
sir, i had loost my printer cd of Canon LASER SHOT LBP-2900 please get me the site or best solution available
Jul 30, 2008 | Canon LASER SHOT LBP-2900 Printer
ATN Aries MK6500 Weapon Sight Logo
Top ATN Optics Experts
Joe Lalumia aka...
Joe Lalumia aka...
Tony Parsons
Tony Parsons
Frank Hunter
Frank Hunter
Level 1 Expert
Are you an ATN Optic Expert? Answer questions, earn points and help others
