Question about Proscan 26LA30Q 26 in. LCD Television
The TV was working fine but when I hooked up the converter box, the TV now has a hazy picture and very poor audio. Any writing on the screen is shadowed. I have tried removing the converter box and just use an indoor antenna w DT and analog. It has not changed the poor quality of the picture and audio.
  • 837 Answers
Did you make sure that the tv and converter box are on the same channel ?
Posted on Jan 03, 2009
Can not get to hook up ot tv
Your new TV is digital. Your VCR is for the obsolete analog NTSC broadcast standard. The two devices are totally incompatible. There are converter boxes available. The quality of the playback will be very poor compared to the picture you now see on your high definition digital TV. The NTSC picture is made up of 525 lines. The best home VCR reduced the resolution to about 350 lines. Your new TV is very high resolution by comparison with a much larger screen in all likelihood. The large screen will exaggerate the poor quality. The process of sending the signal through a converter box will reduce the resolution even more, although digital enhancement with a computer or a dedicated device can marginally improve the results. In the end, you will probably be very unhappy with the resulting picture. If you have video tapes you need to convert them to a digital format using DVD or BlueRay disks, for example. Once converted, you will need a a BlueRay or DVD player for playback to your TV. There are devices for making the conversion or you can send you tapes to a company that will covert the tapes for you. If you do a google search, for video to DVD conversion services, there are many choices. I would suggest that you just have your tapes converted to archival quality DVDs. The sooner you do it, the better because tape degrades in a relatively short time. The tape has a sync track along one edge and as the tape stretches (they always do) by just sitting on the shelf or being played, the player will no longer be able to play the tape and your memories will be lost forever.
Mar 11, 2014 | Televison & Video
Tv doesn't connect though coaxial hook up
Most of these TVs show a blank screen unless they are receiving a sinal?
Jan 28, 2014 | Hitachi 50HDA39 50 in. Plasma HDTV
Weak sound from TV after dvd/vcr hookup
Use the volume control of your converter box to increase the sound level.
Jul 25, 2009 | Samsung DVD-V9800 DVD Player/VCR
Magnavox DV220mw9 won't record from Tv, hard to connect
check out this diagram, paying close attention to the audio video cable hookups.
assume the cable tv box represents the converter box
you are going to come out of the converter box audio and video outputs into the new magnavox dvd/vcr combo audio and video inputs.
Then out of the new magnavox dvd/vcr combo outputs to the inputs on the tv if it has such inputs. The TV will have to operate on the video input 1 or 2 if the tv has such a thing, use the remote for the tv to adjust the input signal to line in 1 or 2 depending on what it has.
If the tv has no coaxial input or audio video inputs then you might have to use an adapter, you can get these from radio shack.
You say it will not record from the tv, but in all actuality the dvd vcr combo is getting the signal from the converter box not the tv, do you understand what I mean here?
So the dvd vcr combo gets input from the converter box so you will have to set it to view signal from the line input you have plugged in from the converter box. line 1 or 2 or whatever the input is.
the tv will have to be set on the line input to view the signal from the dvd vcr combo.
That is as easy as I can put it. Study the diagram closely. You will see what I mean.
Mar 07, 2009 | Philips Magnavox DVD/VCR Dual Player
Problem hooking up DVD player to TV thru my cable box
Chances are you've got your DVD player hooked to OUPUT jacks on the cable box, not inputs. I haven't yet seen a box that takes any kind of an input other than the cable line, but they will have RCA jacks for audio and video outputs on the back. So your cable channels are fine, but the DVD signal is hitting a dead end.
The only solution if your TV doesn't have RCA inputs for video and audio is to get an RF converter (around $10-$20). This takes the A/V signals from your DVD and turns them into a channel 3 or 4 signal that connects to your TV's antenna input.
The converter also has a connector on the back for the cable coming from the cable box, since you'll have to disconnect that from the TV. When the DVD player is off, the cable box signal gets passed to the TV as normal. Turn on the DVD player and the RF converter switches on; put your set on channel 3 or 4 and you'll see your video.
One final thing: The converter will need an AC outlet for its power adapter or power cord, so make sure you have a spare. If you don't already have your TV and DVD player connected to one, this would be a good time to pick up a surge-protector outlet strip. Then not only will you have enough outlets, you'll be protecting your equipment as well.
If this solution has given you what you need, please take a moment to rate it appropriately. And thanks for asking here!
Feb 01, 2009 | RCA DRC277 DVD Player
Poor picture quality & audio reception
If the input to a HD tv is not in HD format the tv won't display an image very well. Be sure your input to the tv is compatible with the tv's technology for optimum performance quality Also re-check the input source (such as converter box, dvd player, etc..) and be sure you have the correct input/output ports connected properly. Try to reset all yout tv settings back to manufacturers defult specs. When an input signal is sent to the tv most modern tv's have software built in to select the proper format to display the input image. There may have been a mismatch communication error when your tv software tried to "handshake" with your converter box input signals from its firmware. So try a reset solution and re-connect the tv without the converter and see if that helps. If not e-mail me and I'll determine if the tv needs technical servicing.
Jan 03, 2009 | Proscan 26LA30Q 26 in. LCD Television
Added dtv converter box and sound volumn drops!
some of those converter boxes have their own volume inside the box also. If your remote control for the converter box has its own volume control, try turning it up and then turn up the TV volume control use the TV remote. If this works you should see a volume indication on the screen of the TV for each of the attempts.
Jan 04, 2018 | Televison & Video
Female coax connector in tv bad?
If your cable converter box has audio/video connections on the back of it,you don't need to worry about using that RF coax connector. Just hook it up the same way your DVD is hooked to the TV input jack. Get a 3-wire cable (yellow-red-white)hook it to the same colors on the back of the cable box and hook the other end to an unused input on the back of the TV. Then select that input with your remote and watch TV.
Aug 30, 2007 | Sharp 27J-S100 TV
Proscan 26LA30Q 26 in. LCD Television Logo
143 people viewed this question
Top Proscan Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you a Proscan Televison and Video Expert? Answer questions, earn points and help others
