Question about Water Heaters
Thermostat for tpi 23r40-2 heater
Need to find replacement thermostat for 23r40-2 wall heater
The thermostat on the wall is not working-no response to pressing any keys
Hi John:
I'm confused. Thermostats on walls typically control room temperature, and the thermostats for water heater tyemperature are typically set where they can not be easily adjusted. Can you tell us what make and model of heater you have, and what you are trying to do? We'll try to help.
Apr 03, 2015 | Water Heaters
How do i reset my honeywell thermostat
Remove thermostat from wall, leaving base plate on wall.
Model number appears on back of device.
Google search thermostat model in following format: Honeywell xxxx32 thermostat .pdf
Adding .pdf to search parameter will yield product manual.
Also while thermostat is off the wall, change batteries located in compartment on back of thermostat. These batteries must be changed periodically, for example each 3-4 years.
Jul 17, 2013 | Honeywell TH3110D1008 Pro3000 Thermostat
Reliant 40 gallon tall electric water heater replaced both thermostats upper and lower elements flushed tank hot water very hot temp turned down lowest possible keeps tripping reset button what else could...
Problem has to be bad element or bad thermostat.
Test elements for short to ground through metal tank wall:
http://waterheatertimer.org/How-to-test-water-heater-element.html
Make sure factory-installed insulation and cover are re-installed over new thermostats so they do not misread tank temperature.
If problem does not show with elements, then replace thermostats again.
Oct 06, 2012 | Reliance & 40 Gal Electric Mobile Home...
I'm getting hot water for 2 minutes , then it gets cold
Most electric hot water heaters have two thermostats, one near the top of the tank and one near the bottom, and are covered by removable metal cover plates. The thermostats are pressed firmly against the bare metal wall of the hot water heaters tank.
The top thermostat usually has a high limit switch that will trip if the water gets too hot. When it trips it shuts off the electricity to both the upper and lower heating elements.
To reset the high limit switch there is usually a red button that you must press. When the upper limit switch trips it is often an indication that something else has gone wrong with the heater.
When the top of the tank is hot the upper thermostat removes power from the upper heating element and transfers the power to the lower thermostat and heating element. If the lower thermostat is defective, then the lower portion of the tank will not be heated and the supply will be greatly reduced.
Check for power at the upper thermostat terminals where the power is sent to the lower thermostat and heating element. If there is no power then the upper thermostat should be replaced. If there is power then check for power at the lower heating element. If there is no power at the lower heating element then replace the lower thermostat.
If there is power to the lower heating element then it should be getting hot. If it is not, replace it. Another possibility is a broken dip tube. Check for a broken dip tube and replace if necessary.
Hope this helps out
Feb 02, 2011 | General Electric GE SmartWater Household...
My aquastar 125b ng froze in cold weather and spewed water everywhere. when installes I was told it was ok to have this unit on outside wall. ... any suggestions
Generally speaking, tankless water heaters should not be installed on an outside wall, especially if they are masonary (which lose more heat to the outside) - regardless of what the installer told you. If the wall reaches & goes below the freezing point, so will the water pipes supplying the heater. However I am somewhat surprised that the heating element did not compensate, if indeed it was the heater that froze. I would recommend moving the heater to an interior wall if possible. You may also want to check the thermostat setting as well.
Dec 09, 2010 | Bosch Water Heaters AquaStar 125 series...
I awoke to no hot water, my heater is three yrs old and i just changed my upper and lower element and upper thermostat, still no hot water then i checked to see if i was getting power and i am, is there...
Your water heater has 2 elements so its 240Volts.
1) If breaker is delivering power on one leg of the 240Volt circuit, then water heater can appear to have electricity, but tank is receiving 120V. Both 120Volt legs are needed to complete the 240V circuit. Double check for 240Volts.
2) Review electric Load.
Water heater label shows wattage of tank.
If tank is 4500Watts for example, you installed 3500 or 4500 watt elements.
With 5500 Watt elements you need 30 amp breaker and orange-colored 10 gauge wire
With 4500 Watt elements you can get by on 20 amp breaker and 12 gauge wire up to 75 feet away.
3) Check ECO red reset button on upper thermostat. If reset is tripped, then ECO is reading high temperatures. Suspects at this point are defective upper thermostat, shorted wire or bad lower element.
4) Also note that insulation and cover must be re-installed over thermostat. Thermostat reads temperature through wall of tank. If outside air circulates around thermostat, that can cause a mis-read and cause tank to overheat and ECO trips.
If you don't want to test the heater, replace both thermostats for about $25. Return the upper thermostat for a refund. Then see of problem persists.
Here's what I would do.
1. Check breaker for 240
2. Check water heater for 240 across 1 and 3 screws on upper thermostat
3. Note wiring and breaker size.
4. Note label on side of tank.
5. Look at end of new element to see wattage printed on each element. Look for sings of high heat and burning. Tighten screws on elements.
6. Check ECO reset button. Look for high-heat and burning. Tighten screws on thermostat.
7. Test upper thermostat as follows:
http://waterheatertimer.org/images/Electric-diagram-water-800.jpg
Test left-side #1 screw to right-side middle #4 screw. Test should read 240V at all times. If not, then ECO is tripped, thermostat is bad, or electricity is OFF
8) Water heater is cold so upper element should be ON. Test upper thermostat.
Test right-side #3 screw to left-side bottom #2 screw and it should read 240V
Test right-side #3 screw to right-side bottom #4 screw and it should read 0 volts
8. If upper thermostat checks out. Test upper element for 240 across both screws. If upper element does not read 240 when water is cold, then element is bad or there is a shorted wire between element and upper thermostat.
How to test element:
9. Do a full troubleshoot on electric water heater
http://waterheatertimer.org/How-to-troubleshoot-electric-problems-with-water-heater.html
Dec 07, 2010 | General Electric GE SmartWater Household...
Replace thermostat and heater element get to hot have to reset
Your question is a bit hard to understand.
You need to replace elements and thermostats because water heater is tripping reset button.
Make sure you put factory insulation back in place after working on water heater, or the heater can overheat and trip reset button.
Here's how to replace electric water heater thermostats:
http://waterheatertimer.org/How-to-replace-thermostat-on-electric-water-heater.html
Here's how to replace water heater elements (except for Rheem bolt-in elements)
http://waterheatertimer.org/How-to-clean-sediment-out-of-electric-water-heater.html
If heater still has problems, add a comment
Nov 18, 2010 | Water Heaters
Water Heaters Logo
123 people viewed this question
Top Water Heaters Experts
Donni Steen
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
