Question about Zyxel G-220 802.11g/b Wireless Adapter
Vista not recognizing driver from usb g220
Old computer crashed, loaded disc on new computer with vista and says vista will not load driver that is not digitally recognized??  went to zyxel website and downloaded drivers for vista 32 and 64 and put into zyxel folder on computer and still not working.  Anyone know what to do??
  • bruce_hardwi Jan 05, 2009
    Thanks tried this solution and restarted computer and plugged zyxel usb in (which is supposed to have the driver in it already) and now it just gives me the three low beeps cause its unable to recognize it.??
  • yefre Jan 18, 2009
    In my case it's not help. I've used v3.0 driver. Afrer first installation I have seen ZyXEL G200 in device manager, but late it desapiars and not willing to apear after UAC off and reinstallation.
    Scholar:
  • 96 Answers
Try turning off the Vista security feature known as User Account Control (UAC).
Go into Control Panel/Users. Select your own account then click the link on the left "turn UAC on or off". Disable UAC then click Apply/OK.
Now try installing the driver again. If you still get the "digital signature" warning choose the option to "install anyway".
The driver should then load. You would be best advised to re-enable UAC after you have finished loading the driver.
Posted on Jan 03, 2009
Do I load drivers to the bios or the hard drive ?
Since the windows was accustomed to loading the sata drivers from your old motherboard, its possible that it it can no longer use them due to the new motherboard having conflicting drivers. Since trying new drivers hasn't been working out for you, the best bet here is to just reinstall windows onto the hard drive again, either through a disc, bootable usb drive, or the recovery partition if you have it.
You can also attempt to manually download the drivers from your manufacturer if you haven't already tried this. I'm not sure exactly which drivers are conflicting but its possible it has to do with the SATA Controller on your motherboard. Search Sata Controller Drivers on your manufacturers webpage and copy it to your usb drive. This may not work in your case since you're having trouble getting them to show up at all, but this would most likely be what it is looking for.
Oct 18, 2017 | The Computers & Internet
Windows vista crashed. changed bios to load xp. worked. old files on hidden drive. problem is cant connect to internet. driver files on hidden drive. Now what? Try to find driver and load it?
it seems that correct network drivers are missing. Easiest way is to download the drivers from manufacturors site, transfer them with USB stick and install.
Sep 27, 2012 | Dell Dimension B110 PC Desktop
Won't load driver on vista home premium...
If you do mean the MP390, item code 9017A002, then you can download the Vista drivers and software from here:
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=334&modelid=9722
Just select your Operating System and click on the download that you want.
If you need me to clarify anything, please ask. If that helps, please rate.
Tim
Apr 21, 2009 | Canon MultiPASS MP390 All-In-One InkJet...
Computer won't recongnize printer
The problem is with the device driver. Every piece of hardware has a corresponding software program called a device driver to let Vista/XP know it is there and what it does and how to do it. If a disc came with your printer then that is what loads the device driver. However, with USB devices you must load the driver with the USB cable unplugged from the printer. Then once the driver loads then plug in the printer...nobody knows exactly why but that is with all USB devices. So unplug and load the disc, then plug and see if it works. You may have to reboot..if that does not work let me know as they are a couple of ways to get it to working. Good luck and keep me updated. Pls rate this solution.
Apr 05, 2009 | HP PSC 1210 All-In-One InkJet Printer
I tried to load the Lexmark x125 to windows vista and it would not print once it was loaded. I found on the internet to run C:/Drivers/printers/1200. I uninstalled Lexmark X125 then ran the program. It was...
Are you saying that the computer crashed? Try plugging in the printer without installing the driver. The computer should recognize that you plugged it in and search for a driver. Do you get that far?
Do you have the original installation CD? If not, then download the driver software from www.lexmark.com. Navigate to the support and drivers section and get the proper driver. Then try to install it that way.
Mar 15, 2009 | Lexmark X125M All-In-One Printer
Windows Vista installation of drivers.
i jus plugged mah concord eyeQ duo 2000 digital camera into mah usb port and it downloaded the drivers for me without usin mah disc on mah vista...
Feb 08, 2008 | Concord Camera Eye-Q Duo 2000 Digital...
New computer with vista
hey this sounds like vist needs updated drivers to recognize that piece of hardware you have to remember that not the things that worked with xp will work with vista go to the manufacture that made that usb hard drive and get updated drivers this will help
Nov 03, 2007 | Maxtor OneTouch II 300 GB Hard Drive
Driver
Try the manufactureres web site.
However if you computer is a Windoes machine[ME/2000/XP/Vista
No disc or sofrware is required.
Windows can do it all
Nov 03, 2007 | Vivitar ViviCam 3785 Digital Camera
Zyxel G-220 802.11g/b Wireless Adapter Logo
718 people viewed this question
Top Zyxel Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Zyxel Computer and Internet Expert? Answer questions, earn points and help others
