Question about Ingersoll Rand 1/2" Super Duty Air Impact Wrench
Runs untill you try to remove a bolt
When holding the tool before putting on bolt. runs and sounds fine both forward and reverse. However when you put on a bolt it has no power. I'm stumped any ideas? Older IR231
    Problem Solver:
  • 11 Answers
I would check my reversal valve and make sure the knob is on the number 5 on both sides first and check my air inlet for trash. Other then that I would tear it down and inspect the tool for any broken parts or grooved front and rear plates in the air motor. If it all looks good I would order a tune up kit with bearings and replace everything that they give you in the kit.
IR 231-TK3
Posted on Nov 13, 2012
Activa MD460 shredder misaligned?
they are not made to shred credit cards .
Jan 10, 2016 | Shredder Office Equipment & Supplies
Embassy shredder keeps running after it's done shredding. It won't stop running.
Hi Brenda:
My shredder, different make, occasionally has the same problem, especially when I try to put too many sheets of paper through at one time.
It happens because the paper jams in the cutter wheels and holds
a switch lever in the on position.
Step 1) Use the reverse switch (mine has one) to back the paper up a bit, then switch it to forward. Repeat this a few times and it might clear itself.
Step 2) If step 1 did not work, unplug the machine and use needle nose pliers, a small swrew driver, or any other handy tool, and remove all of the paper bits from the cutter assemble. Once this is done, it should work fine.
Jun 28, 2015 | Shredder Office Equipment & Supplies
What could the problem be with 1999 villager wont go forward or reverse?
I forget the name, but it could be the shift connecttion. It the connection point behind the shifter in the car and the transmission. The port disconnected mine in my car cause they couldn't figure out how to shift it. It basically put the car into nuetral. No forward no reverse. But engine runs fine.
May 20, 2014 | 1999 Mercury Villager
Anyone have any idea?
97 GC
i cant noodle this. my guess is the A/T fails in reverse only?
did you use an OBD2 scan tool and scan it for A/T errors?
if not, why not?
sounds like the shift cable bad too.
inspect it.
Feb 25, 2014 | 1997 Jeep Grand Cherokee
My alero with a 2.4 cylinder wont go forward but go in reverse
You have a failed transmission, have it taken to a transmission shop for repair.
Jun 15, 2012 | Oldsmobile Alero Cars & Trucks
How to replace a rear transmission seal
Hi Friend: My name is David i'll be Assissting you today.
#1) First get you a Drain Pan put underneath truck where the Tail Shaft is located you'll loose some fluid when you remove the Rear Transmission Seal.
#2) You might need to Jack up thr rear of your Truck to give you more work space.And Secure your Truck with good jack stands and Also Put some Wheel Chucks (Blocks in Front of your front Wheels to prevent it from rolling forward on you.
#3) Next you'll need to remove your Drive Shaft, There are Four (4) Nuts on the Rear of the Drive line where it connects to your Rear End on the Front Side of 3rd Member.
#4) The (4) Nuts are Hold 2-U-Clamps 2- Nuts per Clamp, Take off the 4 nuts Tap the drive line with a Plastic Mallet this will loosen up the U-Bolts Save all your Nuts ,you'll need them to put back on the U-Bolts to get Drive line back in and Tight.
#5) You might have to use a small pry bar to FREE Up the Drive line Universal Joints and push the Drive line Forward just enough to get Drive line away from the Rear End.NOTE: becareful not to let the 4-Universal Caps come off the Universal Joint.Take some Black Tape and Just Wrap it Around ALL 4-Of the Caps to hold in place until your ready to put back in.
#6) Now Pull back on the Whole Drive Line Slowly and it will Come out of the Rear of your transmission.Thats where your Rear Seal is Located.
#7) Get the Proper Tool to Remove the Rear Seal from the Tail housing, (Seal Remover) and remove it from the transmission.
#8) Now Using a Seal In-Staller You'll line your new seal up to the Tail of your Transmission.Evenly And Tap your New Seal in ,it must be Tapped all the way in until its flush with the Tail Housing.
#9) Now you just Reverse the Removal Instructions( take Off the Tape) and put your Drive line back in. Just put your truck in Neutral so you can get the Rear Cups to line back up in the rear end.
#10) Make Sure you are lined up now put your U-Bolts back in.
And the Nuts on and Tighten up good and Tight.
Don't forget to put back the Transmission Fluid Lost.and after Starting Check and Make sure your Transmission Fluid is up to the FULL line.
This will get you back on the Road Sir.Thank You for Using FixYa Please let me know how my solution has helped you by Voting Thanks Again. From: d_hubbs
Aug 21, 2010 | 2004 Chevrolet Silverado
Reverse issues
i believe that your reverse gear is a kit. Now they are not gear driven, they actually run the motor in reverse to back you up, anyways, if you look down from your reverse lever, you will see a adjuster nut or guide bolt. try adjusting that some. you definitely don't want to keep grinding those gears!! reverse kits are around 500 bucks. Good luck
Jan 23, 2009 | Polaris New Genuine Polaris Snowmobile...
How do I remove the old broken lawn mower blade. I can't seem to keep the bolt and nut from moving together when I try to loosen the bold. thanks in advance
i uses impact gun with 3/4 " socket.run it in reverse or you have to remove the stationary parts of the motor.mark them so u will know how to put them back together & somebody has to hold the armature will u r turning the nut on the blade.
Jul 27, 2008 | Black & Decker 19" Electric Lawnhog...
Ingersoll Rand  1/2" Super Duty Air Impact Wrench Logo
358 people viewed this question
Top Ingersoll Rand Air Tools & Compressors Experts
elunsford
Joe Garcia
Joe Garcia
John Trevino
Are you an Ingersoll Rand Air Tool and Compressor Expert? Answer questions, earn points and help others
