Question about DFI LanParty NFII Ultra B Motherboard
Amd processor Dear Guru, I want to change my AMD processor (barton) which the new one that can handle adobe premier pro (running in sse 2 or 3). What kind of AMD processor that compatible with my motherboard (DFI Lan Party NFII ulrta B-socket A, nvidia ultra 2 400)? I want to thanks in advance for your answer and please help me thx
    Genius:
  • 1,066 Answers
Your motherboard has Socket 462. look for Socket 462 processors when shopping around, and keep in mind that the bus speed of the processor will have to be in between 100 and 200.
Posted on Mar 11, 2009
Can I upgrade my PC with existing A7V8X-MX motherboard with higher processor, Presently I have AMD Atholon XP 2000+
It also supports Socket A for AMD Athlon™XP up to 3200+ processor
Thoroughbred/Barton core support
Nov 17, 2010 | ASUS A7V8X-MX (90-M7A780-G0EAY)...
My AMD 3200+ 400/333 chip has died, what can I replace it with? The motherboard is an Asus A7N8X.
Anything in AMDs Socket A line of processors should work.
The AMD Athlon XP 3200 was one of the best processors that would work in that board. Good luck finding one though.
Oct 10, 2009 | AMD Athlon XP 3200+ 400MHz FSB CPU...
2600+ with ASUS MB A7V266-E/AA
Here is the CPU Support list from Asus Support, for the Asus A7V266-E,
http://support.asus.com/cpusupport/cpusupport.aspx?SLanguage=en-us&model=A7V266-E/AA&product=1&os=17
Scroll down the list. 34th one down, that is listed.
1.Did you get the Athlon XP 2600+ that has a 266MegaHertz, (MHz), Front Side Bus? (FSB)
The AXDA2600DKV3C?
There is an Athlon XP 2600+ that has a 266MHz FSB, and one that has an FSB of 333MHz. <-This one Won't work.
Model number ->AXDA2600DKV3D will Not work.
Both are Thoroughbred A/B Core models.
The AXDA2600DKV3C has a 12.5x multiplier.
Your 1900+ has a 12x multiplier. (AXDA1900DUT3C) They both have an FSB of 133MHz. (Shown as 266MHz because AMD processors are 'Double-Pumped')
A.The AXDC2600DKV3C will not work. It has a 16x multiplier. (Thorton Core)
B.The AXDC2600DKV3D will not work. It has a 333MHz FSB. (Thorton Core)
C.The AXDA2600DKV4C will not work. It has a 15x mulitplier. (Barton Core)
D.The AXDA2600DKV4D will not work. It has a 333MHz FSB. (Barton Core)
E.The AXDA2600DKV4E will not work. It has a 400MHz FSB. (Barton Core)
2.Are the jumper blocks -> CPU RATIO, and SYSCLK, still set in the Jumper Free Mode?
By the factory default settings these jumper blocks, (DIP switches), should already be set to Jumper Free Mode.
The white DIP switches should be in the OFF position. (The white switches will be DOWN, towards the numbers on the jumper block CPU RATIO. They will be UP, away from the numbers, on the jumper block SYSCLK))
The CPU RATIO jumper block is right above the processor. It is a blue rectangular block.
The SYSCLK jumper block is down the motherboard, right below the AGP graphics card expansion slot. (And above the first PCI expansion slot)
If those two jumper blocks are not set to Jumper Free Mode, set the DIP switches in the jumper blocks to this setting.
Now go into BIOS Setup. In the main menu use the Right Side Arrow key on your keyboard, and highlight Advanced.
If -> CPU Speed is set to Auto, you won't have access to set your CPU parameters. If it is set to Manual, you will see them. If it's set to Manual, write down the headings, (CPU:System Frequency Multiple, System/PCI Frequency (MHz), and so on) Write down the numbers to the right of these headings. If something goes wrong, you can go back into BIOS Setup, and change them back.
1.CPU:System Frequency Multiple should be
12.5X
2.System/PCI Frequency (MHz) should be
133/33
3.System/DRAM Frequency Ratio should be
(Auto)
4.CPU Vcore should be (1.750)
5.CPU Level 1 cache, and Level 2 cache should be (Enabled)
6.CPU Level 2 cache ECC Check should be (Disabled)
7.BIOS Update should be (Enabled)
8.PS/2 Mouse Function Control (Auto)
9.USB Legacy Support (Auto)
10.OS/2 Onboard Memory >64M (Disabled)
Leave the rest alone.
The AXDA2600DKV3C uses 1.65 volts, has a 12.5 clock multiplier, and a 266MHz FSB. (You will see 133MHz, and set all your settings to 133MHz. AMD processors are 'Double-Pumped'. Intel processors are 'Quad-Pumped')
Aug 10, 2009 | ASUS A7V266-E (A7V266-E AA/PA/WOR)...
Have a SV266M MOBO. w/amd Athlon XP 1700 CPU. I want to upgrade
i could only fins thease specs for you
AMD Athlon up to 2400+
AMD Athlon XP up to 2600+
AMD Duron up to 1.8GHz
Jun 29, 2009 | Syntax SV266M Motherboard
I have AMD Athlon XP 2200+ m7vit bravo m-b
All current 333 MHz capable Socket A chipsets (VIA KT333, KT400, nVIDIA nForce2, SiS 746FX) should be compatible with Barton based processors although you may need to flash the BIOS for the processor to recognized properly
your board has a 333mhz front side bus so should be capable of running them
You must ensure that the cpu is for 333 mhz and not more and that it fits socket A which your board is
Please post rating thanks
Aug 01, 2008 | Biostar M7VIT Pro KT400 ATX Motherboard
How to upgrade
Here is the list of compatible processors for your motherboard:
AMD Athlon 650, 700, 750, 800, 850, 900, 950, 1.0G, 1.1G, 1.2G, 1.3G, 1.33G, 1.4G (Thunderbird)
AMD Athlon MP 1.0G, 1.2G, 1500+, 1600+, 1800+, 1900+, 2000+, 2100+ (Palomino)
AMD Athlon MP 2000+, 2200+, 2400+, 2600+ (Thoroughbred)
AMD Athlon MP 2800+ (Barton)
AMD Athlon XP 1500+, 1600+, 1700+, 1800+, 1900+, 2000+, 2100+ (Palomino)
AMD Athlon XP 1600+, 1700+, 1800+, 1900+, 2000+, 2100+, 2200+, 2400+, 2600+, 2700+, 2800+ (Thoroughbred)
AMD Athlon XP 2500+, 2600+, 2800+, 3000+, 3200+ (Barton)
AMD Athlon XP 2000+, 2200+, 2400+ (Thorton)
AMD Sempron 2200+, 2300+, 2400+, 2500+, 2600+, 2800+ (Thoroughbred)
AMD Sempron 2200+, 2400+, 2500+, 2600+, 2800+ (Thorton)
AMD Sempron 3000+ (Barton)
AMD Duron 600, 650, 700, 750, 800, 850, 900, 950 (Spitfire)
AMD Duron 1.0G, 1.1G, 1.2G, 1.3G (Morgan)
AMD Duron 1.4G, 1.6G, 1.8G (Applebred)
You motherboard uses a "Socket A" CPU and therefore has limits to how high you can go.. I would recommend the XP 2200 or 2400+ as a good choice, but you can make your own choice.
Apr 03, 2008 | AMD Duron , 750 MHz Processor
DFI LanParty NFII Ultra B Motherboard Logo
100 people viewed this question
Top DFI Computers & Internet Experts
mukhtar21 shaikh
mukhtar21 shaikh
Tony
Steve Frost
Steve Frost
Are you a DFI Computer and Internet Expert? Answer questions, earn points and help others
