Question about Emission System for Volvo 960
Oxygen sensors locations for 96 volvo 960 2.9L
  • Volvo Master
  • 14,363 Answers
Http://wiki.answers.com/Q/How_do_you_replace_an_oxygen_sensor_in_a_1996_Volvo_960
Posted on Oct 29, 2012
  • Keven Deas Oct 29, 2012
    Thanks for the info, will check air filter.
Location rear oxygen sensor, bank 2, volvo xc90 t6, 2.9 biturbo,2003
Passenger side exhaust is bank 1 driver side is bank 2. Second sensor downstream of the cat is sensor #2
Apr 07, 2015 | 2003 Volvo XC90
Code po133 o2 sensor 96 volvo 850 wagon
Front oxygen sensor code. Check the vacuum line to the fuel pressure regulator and make sure it is ok before you replace the sensor. Any vacuum leak can also cause the code.
Jan 15, 2014 | 1996 Volvo 850
Oxygen Sensor location
The oxygen sensors are on the exhaust pipes in front and behind the catalytic converter(s).
Bank two is the side with cylinder number 2, and sensor one is in front of the cat.
Dec 13, 2012 | Volvo Cars & Trucks
Where is the bank 1, sensor 2 oxygen sensor located on a 2005 volvo s40 2.4l
that is the sensor behind (past) the catalytic converter-there is only one.
Jun 06, 2011 | 2005 Volvo S40
O2 sensor front Volvo s60t5. Where is it located? A check engine is illuminated
Follow the exhaust manifold down to the tailpipe. The Oxygen sensor is located on the exhaust manifold or exhaust pipe. There will be wires going to it.
Good luck on finding the O2 sensor.
Nov 05, 2010 | 2002 Volvo S60
Where is the oxygen sensor located on a lincoln town car 96
My 96 has 4 cat converters, 2 (upstream and down stream) on each side. There are 2 oxygen sensors on each side, before upstream converter and after upstream converter. But make sure they are bad before you replace them (4 of them will cost you about $200), and my 1996 with 175K has 3 original still running. Other sensors (air flow, coolant temp) might be the problem as well.
Sep 27, 2010 | 1996 Lincoln Town Car
Location of the map and oxygen sensors?
MAP is normally on the throttle body. O2 sensors are always on the exhaust pipe, one near where the pipe attaches to the exhaust manifold the other back near the catalytic converter.
Jul 29, 2010 | 1998 Jeep Grand Cherokee
Where is the oxygen sensor, bank 1 sensor 1, located on a 2000 Toyota Solara? What is the best one to purchase for replacement?
B1S1 means first (upstream) , closest sensor to cyl. head , usualy at exhaust manifold.Bank 1 is cyl. head with cyl.#1 if you have V6 engine.
Best choice for brand - Denso.
Apr 27, 2010 | 2000 Toyota Camry Solara
Where exactly is the front O2 sensor on a 1999 S70?
For 1998 Volvo V70 2.4L MFI DOHC 5cyl the Oxygen Sensor is located under vehicle, center, below front seating area, mounted in top of exhaust pipe.
The oxygen sensor produces a voltage within 0 and 1 volt. When there is a large amount of oxygen present (lean mixture), the sensor produces a low voltage (less than 0.4v). When there is a lesser amount present (rich mixture) it produces a higher voltage (0.6-1.0v).The stoichiometric or correct fuel to air ratio will read between 0.4 and 0.6v. By monitoring the oxygen content and converting it to electrical voltage, the sensor acts as a rich-lean switch. The voltage is transmitted to the engine controller. The controller signals the power module to trigger the fuel injector.
Hope this helped (remmeber comment and rated this).
Apr 06, 2010 | 1998 Volvo V70
Emission System for Volvo 960 Logo
104 people viewed this question
Top Volvo Vehicle Parts & Accessories Experts
xxxxxx xxx
Thomas Perkins
Thomas Perkins
bosy1
Are you a Volvo Vehicle Part and Accessory Expert? Answer questions, earn points and help others
