Since you neglected to specify the model of your Uniden cordless system I can only suggest you select it from the list beginning here to download a copy of the manual.
SOURCE: new Uniden DECT2080 answering system not holding messages
How can I check the answering machine when I am away from home.
SOURCE: I lost manual to 6.0. I have answering machine set
Here is the link to Dect 6.0 manuals. Select model and download.
http://www.uniden.com/index/manuals_results.cfm?cat=59
Hope it helps.
SOURCE: I wonder how do I
You can learn how to set the answering machine on the link below page 34.
To answer the calles go to page 15
http://www.uniden.com/pdf/EXAI2980om.pdf
SOURCE: Can i set up voice?Does my uniden have an
Yes it does all you need to do is setting it to voicemail for it to keep your mesagesand calls for you when you are not around
SOURCE: DECT 6.0'
did it just start.. i would think you are having more of a hardware problem than software given that sound you are getting. if simple reset has failed to rectify that, then unit has to be physically inspected for damage.. call for service.
