Question about Octane Fitness Q47ci Elliptical Trainer
Err code 22 on octane q-47
Switched out left stride motor and cable, but still get err code of 22. What else can I do?
Err 5
Error 5 No Slack on Cybex and Tectrix Steppers Climbmax 2000 3000 700S 800S
Error 5, No Slack, Cybex/Tectrix Climbmax 2000/3000, 700S and 800S Steppers Probable Cause An error 5 on the Tectrix Climbmax models 2000 and 3000 as well as Cybex stepper models 700S and 800S indicates the following:
a) Test switch is in test mode.
b) Possible cut in display cable.
Corrective Action a) Adjust slack switch.
b) Inspect display cable; Replace cable if necessary.
Replacement Parts for Fitness Exercise Equipment at SPORTSMITH
Feb 22, 2014 | RTO Tectrix Personal Stair Climber
Codigo de error
List of Error Codes for Precor Fitness Equipment
Error Code List for Precor Fitness Equipment
Feb 05, 2014 | Precor Exercise & Fitness
Error 20 on Q47 Octane Eliptical
Sounds like it needs to be fixed. It will need a new left motor and cord most likely, less likely a lower board.
Apr 14, 2013 | Octane Fitness Octane Q47 Elliptical...
I have a commercial cardiozone elliptical cg3 500 with automatic stride adjust. The elliptical is giving an err 2 message when we try to use it. Restarting the machine does not fix the issue. How do we...
Removethe bolts or screws securing the console to the upright assembly. Lift theconsole and confirm that the cable connections are secure. Remove the coverfrom the console's battery bay and install a fresh set of batteries. Replacethe battery cover.2
Detachthe ends of the pedals from the crank axles. Remove the left and right discshields and side shields. Inspect the interior of the base unit and locate theflywheel.3
Inspectthe flywheel as it turns. Locate the magnet installed on the flywheel. Turn theflywheel until the magnet passes in front of the nearby reed switch. Loosen thescrew securing the switch in place. Rotate the switch to reduce the gap betweenit and the magnet. Tighten the screw.4
Replacethe left and right disc shields and side shields. Reattach the ends of thepedals to the crank axles.
Good luck, sincerely.
Aug 24, 2011 | Cardiozone Supersport Hr Club Commercial...
Cannot get license, because server returns error code:-47 NComputing Error
Nov 18, 2010 | NComputing X550 PCI CARD W/ VSPACE F/LG...
Codes for telewest eurovox since 24th december.
ntl. 00--7F CD 76 82 BB 22 0A C5.-------TELEPEST.00--F2 D5 38 B1 DF AF CF 48 01---B8 4A BD 38 4B 27 47 A2 CODES FOR 24TH DECEMBER.
Dec 24, 2008 | StarTech.com StarView SV211K 2-port KVM...
Code for501a area
LATEST KEYS ALL AREAS
EX C&W KEYS -- KEYROLL 30/11/2008
PROVIDER CODE: 5C 01
KEY 00 = 2F 1E 90 1B EA 7F A0 26
KEY 01 = 60 1F 48 73 19 D6 CA 99
TELEWEST KEYS -- KEYROLL 30/11/2008
PROVIDER CODE: 5A 01
KEY 00 = 3F 32 37 03 D0 73 84 84
KEY 01 = C6 64 1D EF 47 5A 0E EF
PURE NTL KEYS (UK) -- KEYROLL 30/11/2008
PROVIDER CODE: 54 01
KEY 00 = 5A 35 D6 3B 4D A0 75 EC
KEY 01 = 28 98 21 38 22 BC B9 EF
IRELAND CHORUS KEYS -- KEYROLL 29/06/2008
PROVIDER CODE: 5E 01
KEY 00 = 51 0F 32 A7 D9 34 BE 3E
KEY 01 = 8D A3 88 1B 4E 32 C5 8F
Nov 30, 2008 | StarTech.com StarView SV211K 2-port KVM...
54 01 Starview Codes????
codes at 18:32 for euro vox t/w
Codes for eurovox telewest
00=28 8b 84 9c bf e2 71 15
01=1e df 47 38 4f fb 0b ed
Oct 22, 2008 | StarTech.com StarView SV211K 2-port KVM...
Same Problem Again - Mega Raid.... Unknown Error
Hi
The title of your post suggests that you have "Maga RAID" errors. Maga RAID messages would be in line with issues on the LSI PERC sub-system.
However, the extract posted in your suggests network problems.
Any number of physical to driver and configuration issues can result in network problems.
Try the basic checks;
1. Change or try a known patch cable
2. Run "ping" test to a known good system connected to same network switch or direct connect with a "cross-over" cable and check for dropped connections.
3. Is the NIC and switch set to Auto-Negotiation or static at 10, 100 or 1000Mbps speed
4. Can you try another switch
5. Check and load correct or latest manufacture's drivers
Reply with more info.
Mike
Jan 23, 2008 | Dell PowerEdge 1800 Server
Octane Fitness Q47ci Elliptical Trainer Logo
Top Octane Fitness Exercise & Fitness Experts
Electro Med Services...
Sportsmith LLC
Sportsmith LLC
Tom Chichester
Are you an Octane Fitness Exercise and Fitnes Expert? Answer questions, earn points and help others
