Question about Honda 20 HP Engine - GX630RQXF6
Honda 20 HP will not start - Honda 20 HP Engine - GX630RQXF6
    Scholar:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 35 Answers
Normally there is a whole series of questions as to it's last use, storage, and any specific's of "not starting that you are experiencing.
Assuming that it is turning over adequately by electric start, I would suggest that you look at the plugs. If they are dry, then you have a problem with fuel delivery. Spraying starting fluid into the carb intake should get a pop and a few turns out of the motor. If not, you likely have a spark or compression problem. Check for proper oil fill level. These motors won't start when low on oil. Each possibility has a long chain of test and repair procedures. If you can chase down a liikely cause I may be able to help you further.
Posted on Oct 29, 2012
What would cause the 20 amp fuse for the electric start in a 20 hp Honda outboard motor to continually blow when trying to start?
Your fuse may not be rated correctly or you have a short somewhere. Visually check all the wires for breaks. Good luck!
Mar 29, 2017 | Honda Cars & Trucks
I have a new, first s ason and broken in 20'hp honda outboard. Full choke fine starts first pull. After warm up and leaving at dock for 20 minutes it restarts hard with and without choke
Hi Ira:
Honda's are notoriously reliable, so, since it is a new engine, I'd be heading straight for the shop where I purchased it.
From personal experience, every one of the different pieces of equipment that I own has slightly different starting characteristics.
Once you determine the "routine" for your outboard, it should work the same way, every time.
Jul 15, 2016 | Honda 20 HP Engine - GX630RQXF6
1996 honda 160i luxline remote imobilzer programing
reset immobiliser I HAVE A HONDA CIVIC 1.6 LUXLINE ...
www.fixya.com/cars/t23058317-reset_immobiliser
Jan 22, 2014 - reset immobiliser I HAVE A HONDA CIVIC 1.6 LUXLINE 1998. I NEED TO BYPASS THE IMMOBILSER TO START THE CAR WITHOUT IT ... Press any button on remote one time within 20 seconds. .... How can i fix my honda 160i luxline92 model starting difficulty? Jul 20 ... Jun 09, 2012 ' 1996 Honda Civic.
Sep 27, 2015 | Honda Cars & Trucks
B&S one start pull take numerous pull to start
If it is system I am thinking about it does have an automated choke system and that it is out of adjustment
Jun 03, 2015 | Briggs & Stratton Lawn-Boy 10640 20-Inch...
Honda v twine 20hphonda diagrams wining
tell me what are you trying to do key switch maybe??i know this motor inside and out 30 years experienced.
Aug 25, 2014 | Honda Horizontal Engine 20 HP 12V ES 20...
What would cause crankcase pressure buildup in 20 hp honda engine
Worn piston rings would be my first guess. If so then the engine needs a rebuild.
Dec 12, 2012 | VTwin Horizontal OHV Engine with Electric...
Im looking for a workshop manual for a 1995 Honda 90 HP outboard motor any ideas Im working on the gearbox at present
We bought the Clymer Honda outboard shop manual (B757) which covers Honda 2-130 HP from 1979 to 1999.
It was $20 and worth every penny.
Hope this is helpful.
-Steve
Aug 03, 2012 | Light Outboard Motor Boat Bass Fishing...
What weight oil does the honda 5.5 engine require?
Your Honda 5.5 hp engine specifically calls for SAE 5W30 engine oil. Use a good quality oil in the engine, and change it every 50 hours of run time. The pump will take 30weight non-detergent oil.
Using non-detergent oil in the engine will probably void your warranty, and will certainly shorten the life of the engine. Non-detergent oils have not been recommend by engine manufacturers in nearly 20 years.
Oil is cheap, go ahead and spend $4 - 5 on a quart of high quality oil. Your engine uses about 20 ounces per change.
Oct 01, 2010 | Honda 2500 PSI Gas Pressure Washer
Honda engine pressure washer won't start
Remove the sparkplug spray isoproxyl (rubbing) alchohol in the cylinder and on the sparkplug this will "dry out the engine" reassemble and, start the engine.
It should start as a "wet with gasoline" sparkplug can not spark nor, will liquid gasoline ignite
May 23, 2010 | Honda 8 HP Engine
Weak spark and no start (16.5 honda)
check ign coil , check air gap between coil and flywheel,
Mar 12, 2010 | Craftsman 20 Hp 42" Deck Lawn Tractor
Honda 20 HP Engine - GX630RQXF6 Logo
226 people viewed this question
Top Honda Garden Experts
John Trevino
JOHN LAPIER
Are you a Honda Garden Expert? Answer questions, earn points and help others
