Question about Garden
Hello, have a Craftsman walk-behind mower with Honda GCV 160cc engine. It starts on full choke only, and dies as the choke opens. If I hold the choke 3/4 closed it will run fairly well, but the engine then knocks when loaded in tall grass. I went through the carb and cleaned out some gray smutz in the carb bowl but it was not up to the level of the jet, so I don't think it was a problem. I removed and cleaned the jet with a small wire, and blew out all the passages with compressed air. Somehow as the choke opens, it seems fuel is reduced and cut off. But the severe knocking under load makes me wonder if there is ignition control as well as the throttle control on the governor. I haven't had the plastic engine cover off (yet) to see about ignition control. Suggestions?
#1 Taper
  • 1041 Answers
SOURCE: Engine only runs with choke full on. Dies when off full choke.
Hi Dave, it sounds crazy, but try this. Check your gas cap. It could be clogged, causing a vacuum to occur in the tank, and therefore not allowing the carb. to take on gas. It usually take 10-15 min. for this to occur. The next time you run the mower and it starts to stall out, loosen the gas cap and see if it begins to run again. If it does, then you know that the gas cap is clogged.
Jim
Posted on Jun 05, 2009
  • 22 Answers
SOURCE: 13.5 OHV B&S won't stay running, blows gas out carb.
Sounds like you have a blown valve. I'm assuming this is a 4 stroke motor, if it was 2 stroke then it would be the reed valves. But either way it's the valves.... unfortunately that will require a mechanic :(
Posted on Jul 19, 2009
  • 57 Answers
SOURCE: Engine won't run unless the choke is on - Deere 14SB Push Mower
It's starving for fuel. When you push the throttle all the way forward it closes the choke. You took it apart but you probably didn;t get all the junk out of it. Easy fix is to put some SeaFoam into the tank and run it. This cleans all deposits and debris from the jets. I have used this stuff and put it in the tank and start the engine and sit back and let it run. After about 5 minutes the engine will smooth out and run fine.
Posted on Jul 30, 2009
SOURCE: Troy Bilt model 542(11a-542-q711)has Honda 160cc
I need Gaskets for caboretor
Posted on Sep 08, 2009
  • 10865 Answers
SOURCE: Honda 160cc mower engine starts and dies.
Your carbeurator is crudded up. Get a can of aerosol carbeurator cleaner at any auto parts store. Remove the air filter and spray two squirts of cleaner into the air intake. Start the engine and keep it running by squirting more carb. cleaner into the air intake. WIth a little patience you will clean your carb. and solve your problem.
Posted on Sep 14, 2009
How do I replace top crank seal honda GCV 160 engine
its not going to matter if the seal is leaking damage alreay done to it run it till it stops or lockes up
Aug 18, 2014 | Husqvarna 7021 21Inch 160cc Honda GCV Gas...
Manual for MZ6128
Call jack small engine 877 737 2787 have make, model,serial number ready
Jul 05, 2014 | Husqvarna 7021 21Inch 160cc Honda GCV Gas...
Need diagram of a MTD walk behind mower with honda 160cc engine with ARCS option
Remove air filter cover. Remove air filter. Remove the 3 10mm screws mounting the air filter housing assembly and carb to motor. You will need new gaskets to install the new carb. Gaskets: 16221-883-800 2ea., 16212-ZL8-000, 16228-ZL8-000, and the gasket for the back of the air cleaner mount 17228-ZMO-000. You can buy the carb for these on line for about $14, 16100-Z0L-023. Most take a NGK PLUG BPR6ES.
Apr 02, 2014 | Garden
Adjusting the automatic choke on my Honda GCV 160
you move it in very small moves and be sure to mark the starting place
Jan 25, 2018 | Garden
Where do i get parts??????
Go to your nearest Husky Dealer or SMALL ENGINE REPAIR. You can also get parts on EBAY.
Apr 12, 2013 | Husqvarna 7021 21Inch 160cc Honda GCV Gas...
Not Staying Started
I can't tell you how many pieces of small equipment I have been given for free because it "just won't start" or "won't stay running". Start by draining the tank and cleaning it out - use a good carb cleaner. It only takes a grain of sand to create a problem. You may have to take the carb apart and clean that out too.
Aug 01, 2012 | Husqvarna 7021 21Inch 160cc Honda GCV Gas...
My lawnmower, husqvarna 7021p will not start,after checkin oil and gas, almost started when i did the choke but still wouldn't start
I would try to clean out the carburetor and replace diaphragm if your carb has one. Easy way to tell is put a little bit of carb cleaner in the spark plug hole then try to start it. I it fires up and then dies then the carb is not getting the gas to the engine. Hope this helps!
Jun 10, 2012 | Husqvarna 7021 21Inch 160cc Honda GCV Gas...
Yard works mower wont start
check the fuel filter if not you need to clean your carburator
May 02, 2012 | Yard Man 12A-569Q001 21-Inch 160cc Honda...
How to replace the primer bulb?
What do you mean by a primer bulb? Do you need instructions?
Thanks,
Jul 06, 2011 | Husqvarna 7021 21Inch 160cc Honda GCV Gas...
Lawn mower husqvarna problem
I have an XT721F self-propelled, auto choke Husqvarna mower. The first time I used it this season it ran for a short time and then just quit on me. I have since emptied out all of the gas and have replaced it with high octane 91, and have also added Seafoam to clean out any other issues. I mowed two weeks ago with no problems and went to mow again today and only made it through 2/3 of my back yard and the mower stalled out on me again. What's going on?
Jul 29, 2010 | Husqvarna 7021 21Inch 160cc Honda GCV Gas...
Garden Logo
145 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
