How can I personalize the voice mail?
Since you neglected to specify the model of your Uniden DECT 6.0 system I can only suggest you select it from the list beginning here to download a copy of the manual.
SOURCE: Can i set up voice?Does my uniden have an
Yes it does all you need to do is setting it to voicemail for it to keep your mesagesand calls for you when you are not around
SOURCE: Problem with the Uniden DECT
You can download the manual from the manufacturer's web site at
http://www.uniden.com/content/ebiz/uniden/resources/ownersmanuals/DECT1363om.pdf
SOURCE: DECT 6.0'
did it just start.. i would think you are having more of a hardware problem than software given that sound you are getting. if simple reset has failed to rectify that, then unit has to be physically inspected for damage.. call for service.
SOURCE: how do I change the answering machine's voice. cannot download manuals.
You may download a copy of the manual here.
Press and hold the "1" key to call into your AT&T voice mail.
Enter the default passcode (your seven-digit telephone number--not including the area code) using your keypad.
Press "4" to access the "Personal Options" menu. Press "2" to enter the "Administrative" menu, and then press "1" to change your passcode. Enter the default passcode, and then enter your desired passcode. Listen to the playback for verification.
Wait until you are returned to the main menu. Press "4" for "Personal Options," and then press "3" to change your greeting.
Press "1" to change your "No Answer/Busy" greeting, or press "2" to change your "Extended Absence" greeting. Follow the voice prompts to record your personal greeting (this replaces the standard "answering machine" recording).
