Question about Coleman Powermate Powermate 5000W Generator
I have a Coleman Pro Gen 5000 Generator purchased new in 1999. I have not run the generator until today, 10/28/2012. I put oil and gas in the unit, started it and ran it for about 10 minutes. It ran very well. When I shut it off, I noticed gas running from the bottom of the carb. The gas appeared to be filling the carb at the top and running down. I shut off the gas at the cutoff valve, and then opened it again. It began to run out again so I shut it off again.
SOURCE: coleman 5500 (MZ300)
If the oil is dirty, it will not pump properly. I recently had this problem, once I changed the oil it was good to go.
Posted on Sep 02, 2008
  • 67 Answers
SOURCE: Not a 6250W but a 6500W Coleman Powermate Black Max.
Call Pramac Co. at 770-218-5430. I get parts from them every week. A service center left holding the bag when Coleman/Powermate went out. Ken's Repair
Posted on Sep 23, 2008
CarlGehrke
  • 169 Answers
SOURCE: What type of oil for a Coleman 5000 Generator?
You need a quart of regular old SAE 5W30 motor oil with detergent.
The engines on these generators are more or less the same as a lawn mower.
Don't forget to service/change the air cleaner when you change the oil, that should keep your generator producing full power.
Regards,
Carl
Posted on Dec 15, 2008
  • 63 Answers
SOURCE: generator hard to start and backfiring
Sound like you've done things in the correct order, tecumseh's are notorious for carb problems if you let as sit in them. Backfiring is timing related (flywheel key) or valve problems. I would take a closer look at the exhaust valve I don't believe it is closing all the way.
Posted on Mar 16, 2009
  • 57 Answers
SOURCE: Generator with Briggs & Stratton,no gas is getting in carburetor
The needle valve may be stuck which would not let gas into the carb. I don;t think rebuild kits are too expensive. Pull the carb and take it to a lawnmower repair shop and they should have the parts. Before that though pull the bowl and make sure it has gas in it. If no then remove the fuel line and make sure gas flows from it. If no then could be the fuel shutoff valve is not operating properly or junk in the gas tank is obstructing the line.
Posted on Jul 31, 2009
I have a Coleman Pro-Gen 5000 with a Briggs and Stratton motor in it, I was wondering what kind of oil to use in it and what size sparkplugs I need
30W OIL, take old plug to store customer service will match. Parts: http://www.ereplacementparts.com/powermate-generator-parts-c-117046_130613.html?gclid=COe1kb_yi80CFZGJaQodXvYMXg Info: look on valve cover "DOHC" marked. On the side is the model number for the engine. Search on that model number for engine parts.
Jun 02, 2016 | Coleman Electrical Supplies
Power cord does not retract immediately
Coleman Powermate Generator 5000 Watts / 6250 Watts ...
? 3:27
https://www.youtube.com/watch?v=IROa5QfPqkU
Nov 8, 2012 - Uploaded by Carlos Roman
This 5000 watt generator is great for backup power at home or forpower ... Coleman Powermate Generator 5000 Watts / 6250 Watts ... This feature is not available right now. ... folding handle, 1 quart, of oil, and 25ft generator convenience cord. ... How to convert a generator recoil starter to an electric starter!
pull cord won t retract Power Generators Questions ... - Fixya
www.fixya.com > Forum > Tags > pull cord won t retract
Power Generators pull cord won t retract questions and answers. Ask your pull cordwon t ... Question about Powermate Powermate 5000W Generator. 2 Answers ยท I was running my coleman powermate 6250 gen power ... cord 6250 trips out ... The pullcord does not rewind onto the pulley when pulled. At first I thought it was ...
Best Portable Generator Reviews
Feb 03, 2016 | Coleman Powermate Powermate 5000W...
The generator hasn't, been used in a while and is not cranking. Gas is getting to the spark plug and the plug is clean. What could be the issue?
Coleman starter not cranking Power Generators Questions ...
www.fixya.com > Forum > Tags > starter not cranking > Power Generators
Coleman power generators starter not cranking related questions and answers. Ask your ... Ad. Question about Powermate Powermate 5000W Generator.
Powermate coleman 5000 gen. with subaru engine ... - faqqq
www.faqqq.com/.../powermate-coleman-5000-gen-with-subaru-engine-col...
Question Product: Coleman Powermate Powermate 5000W Generator Question ... it would crank for a second, then i open the choke, it would die, would not stay ...
Fixing Electrical Problems in Coleman Powermate Generators
www.alpharubicon.com/altenergy/colemanpenwu.htm
*Fixing Electrical Problems in Coleman Powermate Generators* By: Penwu 29 April 2006. All of Coleman's portable Powermate line of generators use brushes ...
Coleman 5000 watt generator cold start - YouTube
? 4:35
https://www.youtube.com/watch?v=pcT989l0rm0
Nov 3, 2011 - Uploaded by stevenpturcheck
well im starting to cycle though my equipment before winter so more cold ... How To Change Oil On Coleman Powermate Generator / Yearly ...
Jan 21, 2016 | Coleman Powermate Powermate 5000W...
Power mate 6250. Starts and runs fine until I take the choke off, then why does it die?
Coleman engine starts runs short time quits Power ... - Fixya
www.fixya.com > ... > Power Generators
Coleman Powermate 6250 only runs with choke closed/air restricted ...starts and runswith full choke, but dies with choke off. ... some gas in the cilinder through the plug hole)and start the engine until it runs constantly. bestregards ... Ad ... I use a fuel stabilizer ... ...engine runs fine but produces no power at all to the breaker.
Coleman car starts but will not stay running Power ... - Fixya
Question about Powermate Premium Plus 6250W Portable Generator ... squirt a little gas in the carb it will run until gas is gone doesnt seem to get gas from . ... ...starts and runs fine for about a minute, then dies as though starved for fuel. ... load up on fullchoke and stay running around 3/4 choke HI, Turn off the gas and take ...
Generator runs then shuts off - YouTube
? 8:17
https://www.youtube.com/watch?v=6esHkPyygWw
Sep 6, 2011 - Uploaded by mainblind
How to make Generac generator run bypassing the low oil sensor and ... Remove all; Disconnect .... My ...
Jan 13, 2016 | Coleman Electrical Supplies
My generator will start but is not getting enough power to turn on appliances in the house what could be the problem? Its a coleman pro gen 5000 with a 5 gallon gas tank.
Just what kind of appliances are you trying to run with that little generator?
Check the wattage each appliance is rated for, check how many other things you might be powering, add it all up and that is what you will have to power it with, plus a few thousand watts for a cushion. Most likely you have exceeded the output of your generator. Turn off everything and then see what it can power simultaneously.
Sep 30, 2012 | Electrical Supplies
Is there a gas filter on coleman 5000? runs until hot then shuts off
There is somewhat of a filter inside the tank, however your issue could be air lock or faulty oil sensor. Try running the generator with gas cap loose to allow more air into the tank. If cap is fault try to clean cap vent ports with carb cleaner or just replace the cap. If not fuel lock, remove wire from oil sensor and test again.
Nov 04, 2010 | Coleman Powermate Powermate 5000W...
New gen no power out!
I had a very similar problem with my Powermate generator. The repair was fairly simple. I purchased a new capacitor from http://www.jackssmallengines.com/do_it_home.html. The part was less than $10.00 plus shipping. I just put the part number in from the owner's manual. to replace the part you remove the power end of the generator (four long bolts 7/16), Unplug the wiring harness and then remove the three screws which hold the clear plastic shield in place. All you have to do is pull the wires off of the blue capacitor and put the new one in. When you pull the end off you should also look at the diods to see if they look burned. If they do you can get these from Jack's as well. I hope this fixes your problem
Good luck!!
Feb 05, 2009 | Coleman Powermate Powermate 5000W...
Need to know about this generator. Coleman Powermate 6250 Gen power 305 5000 running watts Model PM0545008 Serial # E06601199B
To find a manual for this generator go to powermate.com and search your model and serial number. Good luck!
Dec 05, 2008 | Coleman Powermate Premium Plus 6250W...
Coleman Powermate Powermate 5000W Generator Logo
208 people viewed this question
Top Coleman Electrical Supplies Experts
John Trevino
Shawn DuRee
Phil Walker
Phil Walker
Are you a Coleman Electrical Supply Expert? Answer questions, earn points and help others
