Question about Leki Super Makalu Cor Tec Pa As Trekking Pole
Separated Leki pole
Pole extension separated
I'm looking for a Nordic walking pole, which one should I get?
The Leki Smart Traveller Alu Nordic Walking Pole is the best Nordic pole you can get today. It is quite expensive in comparison to other Nordic poles but it is totally worth it.
Sep 04, 2012 | Coleman Camping, Backpacking & Hiking
I want a light weight hiking pole can you recommend me which one to pick?
I can only recommend you from my own experience with hiking pole. I've purchase the LEKI Carbon Titanium Speed-Lock. Last year and I'm telling you that I'm very happy with its performances and durability and I strongly recommend you to get one.
When should I use the anti-shock hiking pole?
The best anti shock poles are the Leki Makalu Anti-Shock Trekking Poles. They have an internal spring that absorbs the shock on rough ground. They also have telescopes from 28 to 56 inches for packing and adjusting to users and terrain.
How do I put the saw on the pole
1. Remove battery from chain saw.
2. Separate main handle from chain saw
power head by pressing both release
buttons on main handle and pulling
apart. The release buttons are just in
front of the trigger.
3. Align rib on chain saw power head with
groove in power head adapter on pole.
4. Slide power head into power head
adapter until units "snap" together.
IMPORTANT: Both release
buttons on power head adapter must be
fully engaged.
5. Align rib on handle adapter on pole
with groove in main handle.
6. Slide main handle into handle adapter
IMPORTANT: Both release buttons
on main handle must be fully
engaged.
7. Slide battery onto main handle until
release buttons "snap" together.
Be sure the battery is charged.
To extend the pole:
1. Loosen the clamping
lever. Pole will slide
freely.
2. Pull inner pole section out to desired
length of extension.
3. To lock pole in position, tighten clamping
lever.
Sep 12, 2011 | Remington Cordless 18-Volt 8-Inch Cordless...
Hi, I purchased a pair of new Leki supre makalu cor-tec antishock trekking poles on ebay. One arrived with a strap cut in half and I have had no luck with the seller supplying a replacement, or even...
Hi Lunny, Not quite sure whether you mean "split". It is normal for these straps to have a **** in the unpadded section. If the strap is irreparably damaged that's a different matter. They do have a lifetime guarantee if that is any help. I have just been browsing for details of these poles which I have myself also, and came across your post. I have seen several accessories for them in the US and UK. I'll have another quick shuftie and let you know if I come across any straps that might be able to be sent to you. Best Wishes, Ann, England.
Mar 02, 2011 | Leki Super Makalu Cor Tec Pa As Trekking...
Misassembled black 18" Holmes stand fan with remote (HSF1809R)
Hello cdelune. Glad to see you fixed the problem but Im having the exact same issue with the fan! Not sure what to do with the pole with the frayed ends and how to connect it with the plastic falanges. Ive been at it a while now so do you think you could help me out and post exactly what you did to fix it? Thanks.
Jul 25, 2010 | Holmes Products Dryers
How do u erect a lichfield challenger 5 tent ?
Peg out 2 back pegs of inner tent. Peg out 2 front then side pegs. Place smaller pointed pole through hole at bell end of inner tent from inside, longer pole through hole at front.Fit protective bases to each pole. Top pointed poles with separators. Assemble roof pole, put through loop and over separators. Throw outer tent over from bell end (needs 2 people) then carefully lead towards front til holes in roof match - back hole first. Fit rain hoods front and back. Peg outer tent from bell end first then back corners, front corners then sides. Place porch poles through holes at front of porch, zip door sides down with one person holding poles upright and taut and peg out door. Peg sides all along making sure they do not touch inner tent. Fix guy ropes.
Aug 06, 2009 | Sport & Outdoor - Others
Leki Super Makalu Cor Tec Pa As Trekking Pole Logo
32 people viewed this question
Top Leki Cycling Experts
Michial Gueffroy
Andrew Taylor
Andrew Taylor
Are you a Leki Cycling Expert? Answer questions, earn points and help others
