VS12637 monitor stopped working
New Monitor worked for 3 days. Now there is just the word: ViewSonic showing on screen momentarily then screen goes black.
Riziel
  • 116 Answers
SOURCE: monitor goes black
Sorry to have to tell you this, but this is common in LCD monitors. The reason that it is going black when it boots is for one of two reasons. You either have a bad power supply that powers your LCD or your LCD's backlight is blown. These can be repaired or you can purchase a new one. But if it goes black 9 times out of 10 is because the backlight is bad. These can be repaired!
Posted on Nov 26, 2007
Fix-4U
  • 293 Answers
SOURCE: monitor stops display
Hi...there,
It's seems your LCD Monitor backlight inverter it burnt out. Need a new inverter. Have a nice day!
Posted on Sep 08, 2008
SOURCE: Monitor is black. Press power on monitor/screen shows for 1 sec
We have the same problem and think that the monitor may be getting too warm with staying on all of the time. Try to turn off the monitor when you arent using it. It might save you some time while you look for another monitor.
Posted on Dec 12, 2008
  • 152 Answers
SOURCE: Gateway Monitor keeps going black
Alicia, Your monitor digital board is OK. The problem is with the power supply/ Inverter board(s) in back of the LCD/LPD Panel that you look at. You will need to question Gateway to see if they have a swapout program where you send them $30-$60 and your old monitor, and they will send you a refurbished (new cold cathode fluorescent tubes w/inverter board installed ) complete monitor. I'll tell you one thing though. Alicia, Don't feel bad abt this monitor of your's failing. You have joined the club with over 2000 others whose CCF tubes and INVERTER boards have with time now fail to light-up their LCD panels. Yes, there are some companys that do repair of these monitors. Try surfing under CCF tubes or FPD repair, or LCD repair. Yes Alicia, you are dealing with a technology similar to the new type of screw-in light bulbs, only the tubes are thinner and laid flat horizontally across the rear of your LCD panel with a reflecting mirror in back of them. Good luck girl in getting it repaired. I'm louie12fix on fixya or lmistyrel @aol .com North of Chicago 40 miles
Posted on Feb 27, 2009
graemevm
  • 519 Answers
SOURCE: ViewSonic 19" flat screen monitor goes black - intermittently
There could be a problem with your display card settings or the display card itself. If you are using Windows operating system, make sure that you have the monitor driver installed for that specific monitor. This is to ensure that Windows only allows settings for which your particular monitor was designed.
Let me know if I can assist you any further regarding this.
Best wishes,
Graemevm
Posted on Jun 12, 2009
Dealing with a Planar PL1700-BK computer monitor. When power is supplied, the "no signal" box flashes, then the screen goes black. When hooked to laptop, screen shows desktop, then goes black.
Planar PL LCD Monitor Fix - MarsBox.com
marsbox.com > Blog > Howtos
Nov 3, 2008 - Planar PL LCD monitor has flashing power led with no image. ... You will know it worked if the monitor diplays "No Signal" message when ...
What is the method to reset the Planar 1910m monitor?
superuser.com/.../what-is-the-method-to-reset-the-planar-1910m-monitor
Apr 6, 2010 - My monitor (a Planar, apparently model number PL1910M) is not working. (It is flashing a green / orange sequence which I believe to be an error code. The sequence, in ... I wasn't even seeing a "no signal" message and I couldn't turn it off using the power button. ... Computer resets when put under load.
ViewSonic VX922 monitor - black screen - green power light flashes ...
www.tomshardware.com > Forum > Displays
Tom's Hardware Guide
Feb 1, 2008 - 50 posts - ‎27 authors
Repair ViewSonic VX924 LCD Monitor Blinking Green power Button ... cant switch back & forth to desktop out of some games without the monitor going .... Nothing else on the board looks bad, the power supply board is dark brown ... to this madness we are unfortunantly dealing with daily with our monitors.Missing: planar ‎pl1700
Jan 05, 2016 | Planar PL1700 17" Flat Panel LCD Monitor
Where can I find the right driver to install a Viewsonic VE710b Flat Panel Monitor? I am running Windows 7, 64-bit **This connects to my VGA port, I already have 36" Samsung conntected via HDMI, and
Search Viewsonic.com. The Windows generic driver usually works. If you have a special video driver for your Samsung, it may be interfering. Multiple monitors have to be set up through your display driver. The viewsonic should be available through the device manager.
Oct 10, 2014 | ViewSonic Computers & Internet
Viewsonic VG2021m Image Vanishes on Start Up
It is the picture picture board on your monitor that is malfunctioning, since the power led or button is on, but the display screen goes blank after a few seconds, it means the picture board of your monitor has developed fault.
The best thing for you to do now is to take the monitor to a local repairer within your vicinity or any service center to help with the replacement of the picture board because the fault is not something you can fix yourself, in order not to complicate issues.
Take care.
May 07, 2010 | ViewSonic Graphic VG2021m LCD Monitor
ViewSonc VX924 LCD Monitor
Check the information at Viewsonic's website regarding their warranty:
http://www.viewsonic.com/support/warranties/limited-warranty/
If you have your proof-of-purchase and it shows the monitor is less than a year old, it would be covered. You would need to follow the procedure on their website to have the unit repaired or replaced, but it would not be your job to try to fix it.
Feb 11, 2009 | ViewSonic VX910 19" LCD Monitor
Dark screen
reset your monitor settings with deafaults with menu.u see some buton on lcd or monitor.
Dec 29, 2008 | ViewSonic VG900 19" Flat Panel LCD Monitor
Monitor stops display
Hi...there,
Sep 06, 2008 | Computers & Internet
Monitor Blanking
Buy a new monitor... It will make your eyes stop watering.
Sep 16, 2006 | ViewSonic VP191b 19" LCD Monitor
Computers & Internet Logo
49 people viewed this question
David Payne
David Payne
