Question about Acer Aspire 5600 Series 5630-6951 Laptop
My Acer TravelMate 2400's display is not showing BLACK colour.
5 Suggested Answers
SOURCE: Acer Travelmate 2400
Have you tried a dongle? Also, do you have the software installed correctly (check in the control panel/system/device manager). It maybe either or both of these. You may have a damaged bluetooth connection so if you have all the drivers correctly installed then a dongle would be the only other option as far as i'm aware
Posted on Mar 10, 2008
mediarich
  • 188 Answers
SOURCE: my acer travelmate has coloured lines all over
I suggest you post your problem on the following forum. It appears they have active participants and they'd be more apt to have heard or had this problem before.
http://forum.notebookreview.com/forumdisplay.php?f=22
Posted on Sep 25, 2008
cyberguru4u
  • 90 Answers
SOURCE: ACer Laptop SOund problem...
http://support.acer-euro.com/drivers/notebook/tm_2400.html
here u can download drivers...
Posted on Feb 25, 2009
Geekman
  • 32281 Answers
SOURCE: acer travelmate 2440 theres power only the screen its pure black.
Try reseating the RAM modules first. The RAM may be faulty or reseating to make proper electrical connection. Get the RAM tested in another laptop or at your friendly computer shop.
Can you get into the BIOS configuration?
Did you power up the monitor first then the laptop? This method will divert the video information to the external video port first automatically.
If you don't get an image on the monitor and the hard drive doesn't appear to be spinning, then you could have a faulty motherboard.
Posted on Jun 21, 2009
SOURCE: I own an acer travelmate 290, and getting no display on monitor.
First check to see if your PC has a built in factory restore, or system recovery, usually available using CTRL & F12, F10, etc. Check your manual, if you don't then, OK try this, Startup PC, press F8 at instant of turn on... choose Safe Mode. when you are asked if you want safe desktop or system restore choose restore, when you get to the restore menu, choose a date BEFORE you had problems there may only be one or two to choose from. just follow the instructions and you should be back to working with all that behind you. If that doesn't work, boot up on your Windows DVD and do a "Repair Install", If thats doesn't work do a format and a reinstall.
Posted on Feb 12, 2010
Dose eny one know what motherboard are the same as the acer travelmate 2400 thanks
Motherboard you have LB.TA902.001, LBTA902001
CPU (Processor) support: Intel Celeron M processor 370, 1MB L2 cache
acer 3210/3220 motherboard are same as acer 2400
Jul 21, 2010 | Acer Aspire 5100-5022 Notebook
How do I uninstall a program from a acer travelmate 2400?
Utilize the "control panel" "unistall a program or add & remove" option
Dec 15, 2009 | Acer TravelMate 2480-2153 Notebook
My laptop is only using 75% of the screen space
Check your screen resolution. Since you've updated to the latest driver, make sure the resolution is set to the highest it can go. Also, make sure it is showing an LCD display that cooresponds to what you have.
Dec 30, 2008 | Acer TravelMate 4230-6499 Notebook
My acer travelmate has coloured lines all over
Sep 25, 2008 | Acer TravelMate 290 Notebook
Acer Travelmate 2410 with display probs
Could be the screen is running with the wrong colour depth and resolution - reset the settings by right clicking on the screen selecting properties and then adjust on the settings tab.
Mar 10, 2008 | Acer TravelMate 2300 Notebook
Mar 05, 2008 | Acer TravelMate 2300 Notebook
Acer Aspire 5600 Series 5630-6951 Laptop Logo
32 people viewed this question
Brian Sullivan
Brian Sullivan
joecoolvette
joecoolvette
