Question about Vizio VP322 32 in. Plasma TV
How to remove capacitors C233, C234, and C236 on vizio vp322
4 Suggested Answers
  • 8457 Answers
SOURCE: vizio 32 vp322
Power board is dead.Must be replaced,to get power back.Tries Shopjimmy.com,Ebay.com for the power board part.
Posted on Jan 23, 2010
budmrtn
  • 11361 Answers
SOURCE: this Vizio VP322 continues to
Did you use the correct type of the electrolytic caps, not general purpose electrolytic type, should be 105c low ESR type. also check to see if the dc voltage is exceeding the cap voltage rating.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Parts: www.interliquidparts.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com, just make sure to use caps with low ESR, 105c, high ripple current and long life rating such as PANASONIC FM or FC series.
Posted on Sep 01, 2011
  • 96 Answers
SOURCE: I have the Vizio vp322
Hello, might need a Main Unit or Power Supply by the sounds of it. Try out a company named ShopJimmy.com for parts. I have used them with great success in the past. I included a link to their site from your model page. Hope that helps!
TeeVeeMan2@gmail.com
http://www.shopjimmy.com/catalogsearch/result/?q=vp322
Posted on Sep 06, 2011
32" vizio won't turn on
Hello; I am John at J D Electronics in Poland, Maine. I have now repaired 81 of this same model in my shop or PCB mail in's. The set may be dead always or work intermittently. There are 2 versions of this piece of junk, but I have only seen this one. They all have 2 to 7 capacitors that fail on the power supply board that are just above that red chopper transformer. The are labeled C233 and C234 and others. These first 2 are 3300 ufd at 10 volts and 105 C temp rating. You can buy these for about $1 each from Digi-Key Electronics plus $12 shipping. There are some cautions worth mentioning. Make sure the set has been unplugged for a day or more before starting the disassembling. It is VERY important to keep the set face down on a soft surface when doing ANY work on the set. This crappy designed set has a glass faceplate that will fall down if you don't have it face down when all the back screws are removed and it is very hard to put it back into position if it falls. The bottom plastic speaker strip has a million screws to remove both from the bottom edge. Then take out all the screws for the metal back and unplug the speakers. The connector wires to the speakers will not just pull off without you pressing on a side release pin for each of the 4 wire- Stupid design again!. If you are not able to solder or test these caps , you can send the board to me with $46.00 to replace and/or test up to 7 caps this includes USPS Parcel Post return shipping. I accept only cash or USA postal MO. There is NO Warranty on this repair. It is a better than 80% chance this will fix your set. You must call me first at 207 998 5687 EST 9-5 only. Good Luck! John
Sep 13, 2011 | Vizio VP322 32 in. Plasma TV
I got a vizio vp322 hdtv10a from a friend and it does not have the power cord....we bought the ac adapter piece but need to know how to hook it up and wire it. is there a diagram somewhere or something we...
Hello; This set uses just a standard 3 pin power cord used on PC's an a lot of other things No AC adapter is used on this model. If your set doesn't work, there is a very common failure. This is from my other post
Hello; I am John at J D Electronics in Poland, Maine. I have now repaired 81 of this same model in my shop or PCB mail in's. The set may be dead always or work intermittently. There are 2 versions of this piece of junk, but I have only seen this one. They all have 2 to 7 capacitors that fail on the power supply board that are just above that red chopper transformer. The are labeled C233 and C234 and others. These first 2 are 3300 ufd at 10 volts and 105 C temp rating. You can buy these for about $1 each from Digi-Key Electronics plus $12 shipping. There are some cautions worth mentioning. Make sure the set has been unplugged for a day or more before starting the disassembling. It is VERY important to keep the set face down on a soft surface when doing ANY work on the set. This crappy designed set has a glass faceplate that will fall down if you don't have it face down when all the back screws are removed and it is very hard to put it back into position if it falls. The bottom plastic speaker strip has a million screws to remove both from the bottom edge. Then take out all the screws for the metal back and unplug the speakers. The connector wires to the speakers will not just pull off without you pressing on a side release pin for each of the 4 wire- Stupid design again!. If you are not able to solder or test these caps , you can send the board to me with $44.00 to replace and/or test up to 7 caps this includes USPS Parcel Post return shipping. I accept only cash or USA postal MO. There is NO Warranty on this repair. It is a better than 80% chance this will fix your set. You must call me first at 207 998 5687 EST 9-5 only. Good Luck! John
Apr 14, 2011 | Vizio VP322 32 in. Plasma TV
My 32" Vizio started having problems before it
Hello; I am John at J D Electronics in Poland, Maine. I have now repaired 9 of this same model in my shop. The set may be dead always or work intermittently. There are 2 versions of this piece of junk, but I have only seen this one. They all have 2 capacitors that fail on the power supply board just above that red chopper transformer. The are labeled C233 and C234. These are 3300 ufd at 10 volts and 105 C temp rating. You can buy these for about $1 each from Digi-Key Electronics plus shipping. There are some cautions worth mentioning. Make sure the set has been unplugged for a day or more before starting the disassembling. It is VERY important to keep the set face down on a soft surface when doing ANY work on the set. This crappy designed set has a glass faceplate that will fall down if you don't have it face down when all the back screws are removed and it is very hard to put it back into position if it falls. The bottom plastic speaker strip has a million screws to remove both from the bottom edge. Then take out all the screws for the metal back and unplug the speakers. The connector wires to the speakers will not just pull off without you pressing on a side release pin for each of the 4 wire- Stupid design again!. If you are not able to solder these parts in , you can send the board to me for $25 labor plus $10 return shipping and $4 for the parts ( or send your own). We accept only cash or USA postal MO. There is NO Warranty on this repair. It is a better than 80% chance this will fix your set. Call me at 207 998 5687 Good Luck! John
Nov 23, 2010 | Vizio VP322 32 in. Plasma TV
32 plasma Vizio VP322HDTV10A . TV power up and shut down,, for several week. I did not turn off for several days and it shutdown and will not come back on ..no life, not light and will not power on. TV...
Describe your Vizio VP322 32 in. Plasma TV Problem
Nov 10, 2010 | Vizio VP322 32 in. Plasma TV
My 32" vizio plasma tv will not power on
Hello; I am John at J D Electronics in Poland, Maine. I have now repaired 4 of this same model in my shop. The set may be dead always or work intermittently. There are 2 versions of this piece of junk, but I have only seen this one. They all have 2 capacitors that fail on the power supply board just above that red chopper transformer. The are labeled C233 and C234. These are 3300 ufd at 10 volts and 105 C temp rating. You can buy these for about $1 each from Digi-Key Electronics. Make sure they have the Panasonic brand. There are some cautions worth mentioning. Make sure the set has been unplugged for a day or more before starting the disassembling. It is VERY important to keep the set face down on a soft surface when doing ANY work on the set. This crappy designed set has a glass faceplate that will fall down if you don't have it face down when all the back screws are removed and it is very hard to put it back into position if it falls. The bottom plastic speaker strip has a million screws to remove both from the bottom edge and the back. then take out all the screws for the metal back and unplug the speakers. The connector wires to the speakers will not just pull off without you pressing on a side release pin for each of the 4 wire- Stupid design again!. Good Luck! John
Oct 05, 2010 | Vizio VP322 32 in. Plasma TV
WENT TO TURN ON MY 32 INCH VIZIO PLASMA TONITE HAD ORANGE LIGHT AND WHEN I HIT POWER BUTTON IT WENT BLACK WHERE VIZIO LIGHTS UP AND WONT COME ON ANYMORE ? IM PARALYZED AND ON A FIXED INCOME AND SAVED A...
Aug 18, 2010 | Vizio VP322 32 in. Plasma TV
I have a VP322 32" Plasma TV with bad capacitors
Temp is not the problem you need to replace with higher voltage rating this is a 12v board how many 10v caps u gots?
May 30, 2010 | Vizio VP322 32 in. Plasma TV
I think I need a new power module for my Vizio vp322 hdtv10a tv. How do I open the TV to expose this module? There are about 10 million screws on the back of the set.
Remove the 4 screws holding the stand. Remove all the perimeter screws. Remove all the screws from the bottom speaker panel and the rest of the perimeter screws and the ground wire screws at each speaker. remove the screws on the surface of the back panel and you are in. The power supply is the large board in the middle. The bad capacitors are in the secondary and were C233, C234, and C236. I replaced these 3 capacitors and fixed this problem. They were 1-10v 1000uF and 2- 10v 3300uF electrolitic board mount capacitors. Easy to spot on the power board, the tops were bulged up. $5.54 later it works perfectly now.
Dec 18, 2009 | Vizio VP322 32 in. Plasma TV
Would power on and off when I would try to turn it
I removed all the screws from the back cover. Upon visual inspection of the power supply board, model # PSPU-J707A, I found electrolytic capacitors C233 and C234 to have bulging tops. Both caps are 10V 3300uf. I'm going to replace them and post the results.
Sep 30, 2009 | Vizio P2 42 in. HD-Ready Plasma Television
After about an hour picture gets a blue distortion. YOu have to turn off TV and let cool off. Once it cools off it works until it gets hot again.
replace these electrolytic caps in the power supply,
C233,C234 3300mf/16volt
C241,C238 470mf/35volt
C236 1000mf/25volt
you can also go to shopjimmy.com enter model number scroll down to find power supply if they dont have it in stock write down the part number to find it on the web,it would be cheaper for you to replace the bad caps.
Sep 24, 2009 | Vizio VP322 32 in. Plasma TV
Vizio VP322 32 in. Plasma TV Logo
196 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
