Question about Refrigerators
How do i change a switch on a GE Model# JCS968SK4SS stove?
The switch for the front left burner got pushed on and needs to be replaced.
  • 311 Answers
SOURCE: electric start gas range
All burners apark at the same time. If they don't light then electrodes (where the spark jumps off of) are either worn out or cracked or there is dirt in the area of the sparking. Clean thoroughly to diagnose this correctly.
Posted on Nov 28, 2008
  • 338 Answers
SOURCE: changing the surface burner spark electrode for GE stovetop
Schematic -
http://www.searspartsdirect.com/partsdirect/getSubComp.pd?modelNumber=JGP326WEV1WW&productCategoryId=0121050&brandId=0432&modelName=GAS-COOKTOP&diagramPageId=00001&componentDescription=COOKTOP&documentId=10053061&backToLink=Return%20to%20Sub%20Components%20list
Posted on Dec 07, 2008
BNewberry
  • 93 Answers
SOURCE: how do you replace a burner switch on a Frigedaire Glasstop Stove
The repair on this stove will be relatively easy then. All you are going to have to do is pull out the stove from the wall and remove the upper part of the back panel where the burner switches are.
Remove the knob and take out the screws that hold the switch to that front panel. Then from there just match up the wires to the new switch off the old one.
This repair will turn out to be pretty cut and dry for you. If you have anymore questions please ask.
Thanks Again,
Bill
Posted on Jan 10, 2009
  • 360 Answers
SOURCE: kenmore glass top range left front large burner out
check the burner socket, it is likely that contact is being lost where the burner connects to the hardwired portion of the system (the socket). It is not unusual for the socket to "burn up" when there is a poor connection to the burner resulting in the burner being replaced and the new burner not working or working intermittently.
Please take the time to rate this solution
Posted on Jan 29, 2009
SOURCE: Replacement Parts For Vintage Magic Chef stove
You probably have a 1940's model of Magic Chef. Check for the model number under the lid of the cook top on the upper right hand side of the stove. It should have the model number and the serial number, too. You will need both. The Old Applicance Club run by Jack Santoro is the place to go along with a site called "Antique gas stoves"in Georgia. Good luck with the world of vintage stoves.
Posted on Apr 06, 2009
GE stove with defective surface unit
Make sure that the replacement is receiving power. If not U need to trace the wiring that goes to the element for the source of the issue.
Also check the power switch to that burner.
Jun 02, 2016 | GE Microwave Ovens
Kitchenaid superba gas stove left front burner will not operate unless back left burner is turned on at same time
The switch for that particular burner is bad. It turns out that whenever you switch on 1 burner, they all spark - that's a safety feature. Depending on the model, you may just need to replace the 1 switch, but usually, they are part of a switch string, and you have to replaced the whole string of switches..
Nov 19, 2014 | Kitchen Ranges
Light "Burner On" stays on all the time on my electric stove GE model JBS27WH2WW
I have a GE Range Model JBS27W H2WW and the serial# XXXXX that I was cooking on and the back burner starting throwing out sparks and blew a hole in the coil and the drip pan. Now the light Burner on is staying on and I switched the 8 inch burner in the front with this 8 inch burner and still cannot get it to work.
Dec 19, 2013 | Cooktops
Spectra GE model JBP64W0B4WW stove top burner stopped working
Which element is it? Try to switch the infinite switch from another element. This will tell you if it is the element or the switch problem.
Apr 06, 2013 | GE Spectra JBP78 Electric Kitchen Range
I have a GE 4 burner self cleaning range. it was installed new. I have lived here since 2006 and was the first and only occupant. The stove is lightly used and kept very clean. I prefer my microwave and...
Are the burners warm all the time? If so then this is a problem. Perhaps when you had your incedent were you leaning forward and pushing on the front controls? Or was the container pushing on controls on the top? .....Pushing on the controls can case them to get hot.
YES, you need a GE professional to look at this.
Good luck,
Shawn
Jan 30, 2011 | Microwave Ovens
GE Stove. Model: JSP42S K5SS Problem: Left front burner is always on even turn to Off posittion. The burner indicator is on and the surface is alway hot. The stove is only 2 years old and well...
This is most certainly the infinite switch. If you pull the knob off for this eye, the shaft you see is part of that switch. You need to disconnect power to the appliance and replace it.
Nov 04, 2010 | GE JSP42 Electric Kitchen Range
Lg flat surface stove burner
Replace your infinite switch for this (your lf burner switch). Call a parts supplier with your model number, try and get an exact switch, not a generic switch. Do not replace the switch without unpluggin your range first. Good Luck, Appliance Specialists
Jan 28, 2010 | Kitchen Ranges
Burner Igniter will not Spark
No, actually each knob has its own switch and any knob will energize the spark module which sparks at all burners. So, just replace the defective switch which slides over the shaft of the gas valve. Careful! unplug the unit, these are 120 volt switches. Good luck.
Jan 12, 2010 | GE Ovens
Burner will not turn off
I would first check the infinite control switch (#WB24T10029) the part the knob slips onto. The next thing I'd check is the erc (#WB27T10231) control board. Hope that is helpful!
Mar 05, 2008 | GE JBP64 CleanDesign Electric Kitchen...
Refrigerators Logo
48 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
