Question about Water Heaters
Dunkirk boiler manuals instructions
Model # PWXL5VNG2
I've got a Worcester Bosch boiler had a leak In the pipe On the landing so a friend emptied the boiler an I fixed the pipe but I don't know how to refill the boiler
Can you get the manual online? You have the Manufacturer info so you probably have the model number too. I found a manual on Manuals.com for my boiler so they may have yours too which will hopefully have some information on filling boiler although I realize each installation is somewhat different but that's why it's difficult to answer you question. Usually there is a manual pressure valve that regulates the water pressure in the boiler which is usually pretty low...like less than 20 lbs. The manual should tell you the pressure as well. But this pressure valve has a flip handle that comes off the cold water line to the boiler to do just what you want to do...refill it with water. When refilling the boiler (if you find the valve, you may have to purge the air out of the lines which there is a whole other process for. But you shouldn't allow cold water into a hot boiler...it could crack it when the cold water hits the hot cast iron. So make sure the boiler is cool when filling it up.
Now go try to find that manual!
Nov 22, 2015 | Bosch Water Heaters
I just bought irect water heater model HL40Sk ,is heater comes with legs it was nothing in corton ?
It most likely is a wall mounted model. Did it come with instructions? That will show you how to install it.
Sep 09, 2014 | Dunkirk HL40SK Hotline Indirect Domestic...
Installed a year-and-a-half ago, problems so far: thermostat replaced on hot water tank within one month of installation, one pump replaced, leaking plug in the front of boiler with Dunkirk rep never
Its probably time for small claims court and a new company to install good equipment. Have a couple different companies/contractors give an estimate and possibly expert advice/witness you would then be able to use in court so you can get reimbursed from a bad company. Hope it all works out.
Apr 20, 2013 | Dunkirk Q90-75 Quantum High Efficiency...
Boiler keeps going out
have you checked that you thermostat on wall is set to a reasonably high temp. if not when room eaches temp setting , then the boiler will switch off,. Other than this obvios one , i would suggest you could google your boiler for the manual /instruction.
Parts For Porsche Cayenne
Jun 11, 2012 | Reliance Water Heaters
The water pressure on my Greenstar 25Si Worcester Bosch combi boiler is so low that the shower won`t heat up. Can someone please tell me how to increaese the water pressure as there doesn`t seem to be an...
The boiler has a filling connection which uses a filling loop to connect the boiler to the mains supply for the initial fill and subsequent fills.
See the link below from the manual you can buy the filling loop connection online or ebay its a simple task to replenish the pressure. Worcester GREENSTAR 25Si Instruction Manual Filling The System
Feb 06, 2018 | Water Heaters
Programming instructions for Vaillant boiler ecoTEC pro timer
You can probably go online to the manufacturers websit to their tech support you will probably find downloadable documents for the unit. I would look them up myself for you but you didn't list the brand or model number. Hope this answers your question.
Mar 20, 2009 | Water Heaters
I want to increase the boiler temp by using the your aquastat
Warning! Can cause electrical shock! Here is the instruction manual
for L7248c
http://customer.honeywell.com/techlit/pdf/PackedLit/68-0281.pdf
Jan 12, 2009 | Water Heaters
Instructions for my Ideal Mexico CF60P Propane boiler
Hi tessajoe,
I'm Harvey, the master plumber. You asked where you can
download instructions/user manual/installation guide for
Ideal Mexico CF60P Water Heaters. I believe this is the correct link:
http://www.chspares.com/partselect.php?test=121
Some Companies will e-mail it, others will respond if you call them on the phone and they will fax it or mail it. Contact info on the link that you requested form me.
I'm happy to help you!
Feel free to contact me.
Harvey the Master Plumber
Sep 07, 2008 | Water Heaters
Water Heaters Logo
24 people viewed this question
Top Water Heaters Experts
Paul Carew
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
