Question about Hitachi RB24EAP 23.9cc 2 Stroke 170 MPH Gas Powered Handheld Blower
Hitachi RB24EAP engine start but no blow
Engine/motor running but no air coming out from blower. Thanks.
    Habit-Forming:
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 3 Answers
Check the impeller (on the side opposite the pull starter) to see if it is locked to the drive shaft (in the center of the impeller). The shaft could be spinning but, if the impeller is loose on the shaft, it can't spin fast enough to force as much air through the nozzle as it should.
Posted on Mar 21, 2017
My Hitachi leaf blower was smoking after short term use
The engine gets hot, and the smell is likely not anything to worry about.
Oct 06, 2016 | Hitachi RB24EAP 23.9cc 2 Stroke 170 MPH...
1977 Buick blower / fan comes on however NO heat blower / fan also blows very low.
Buick LeSabre Heater - RepairPal
repairpal.com > Problems > Buick > LeSabre
Buick LeSabre Heater blows only cool air...even w/ defroster on. This is a ... Heater fandoesn't come on . ... The blower works but there is no heat coming out.
Blower Motor Problems ' Auto Repair Help - YouTube
? 4:22
https://www.youtube.com/watch?v=2vmfxYg8LoY
Sep 27, 2009 - Uploaded by mgittelman
The blower motor is a common heater/AC repair within the skill level of ... However if the power wire is a single light purple wire and the ... for blower motor and fuel and relay good but no powercoming on both any ideas? ... my o5 seira, when i start the engine with the air switch on it blows my blower fan ...
Car Air Not Blowing, Heat & Air "How to" Test Testing ...
? 6:22
https://www.youtube.com/watch?v=hgar6Q1lV6A
Apr 5, 2013 - Uploaded by Fixbook
Here I show how to determine the problem if your air, or blowermotor is not ... Click here to check out the the "Car Runs on 2 cylinders" series: ... How to Fix Over-Heating engine & No Heat in car - Buick (2000 yr) Park Ave . ... Car fan / AC only works on high - Replacing the Blower Resistor - Duration: 4:24.
Buick Park Avenue Questions - NO HEAT!!! - CarGurus
Jan 30, 2016 | 1977 Buick Electra
Why is my heat or air is not blowing and car is running hot
How hot is the engine running in degrees f? Does the radiator fan run?
With hvac turned on, check voltage and ground at the blower motor. If good voltage and ground, suspect the blower motor is faulty.
Jan 02, 2016 | 1992 Saturn SL
Hitachi rb24eap blower won't stay running
Check your air filter is not clogged. Clean or replace as necessary.
It is a grey sponge ring that is located behind the cover plate near the priming bulb.
May 27, 2014 | Hitachi RB24EAP - 23.9cc 2 Stroke Gas...
It wont start
After heavy use, to restart you must prime the bulb as usual, NOT use the choke (only for cold).
Apr 23, 2014 | Hitachi RB24EAP - 23.9cc 2 Stroke Gas...
No air blowing out of vent
The thermostat only controls how hot the engine gets.
It could be the blower motor, or a blend door under the dash.
You would need to check the blower motor for power and ground, if it is running a door may be stuck closed.
The blend doors direct air thru the heater core and vents.
Jan 11, 2013 | 2003 Chevrolet TrailBlazer
Heater doesnt work
To troubleshoot this types of problem,click the link below :---
Car heater blowing warm, but not hot air?http://schematicsdiagram.blogspot.com/2011/12/car-heater-blowing-warm-but-not-hot-air.html
Engine Overheats and heater blowing cold?
http://howtobyme.blogspot.com/2011/11/engine-overheats-and-heater-blowing.html
Heat blows cold on drivers side and hot on passenger side?
http://schematicsdiagram.blogspot.com/2011/12/heat-blows-cold-on-drivers-side-and-hot.html
No heat on car? http://technoanswers.blogspot.in/2012/02/no-heat-on-oldsmobile-silhouette.html
Heater blows intermittently and temp gauge goes erratic?
http://technoanswers.blogspot.com/2012/01/heater-blows-intermittently-and-temp.html
Heater blows cold?
http://schematicsdiagram.blogspot.in/2012/02/heater-blows-cold.html
Heater/AC blower motor not working?
http://technoanswers.blogspot.in/2012/02/heaterac-blower-motor-not-working-on.html
A/C, heater, defroster fan, not working? http://technoanswers.blogspot.in/2012/02/ac-heater-defroster-fan-not-working.html Heater problem?
http://technoanswers.blogspot.in/2012/02/heater-problem-on-isuzu-trooper.html
This will help.Thanks.
Mar 27, 2012 | 1994 Volvo 960
The steps please to remove the heater blower motor on a 1995 Park Ave. The check engine light comes on readily when driving or idling. The numerical external temperature/heater temperature setting...
  • Disconnect the negative battery cable.
  • Disconnect the blower motor lead connector from the wiring harness connector.
  • Remove the blower motor cooling tube from the blower motor.
  • Remove the four retaining screws.
  • Turn the motor and the wheel assembly slightly to the right so that the bottom edge of the mounting plate follows the contour of the wheel well splash panel.
  • Lift up on the blower and remove it from the blower housing.
  • Installation the new blower motor by reversing the removal steps.
  • Connect the negative battery cable.
  • Jan 02, 2011 | 1995 Buick Park Avenue
    Blower Motor Works but receives no power
    It's either your blower motor switch or you have a short in the wiring from your switch to the motor or you have a bad relay.
    Jun 10, 2009 | 2002 Nissan Maxima
    Hitachi RB24EAP 23.9cc 2 Stroke 170 MPH Gas Powered Handheld Blower Logo
    62 people viewed this question
    Top Hitachi Garden Experts
    Phil Walker
    Phil Walker
    Are you a Hitachi Garden Expert? Answer questions, earn points and help others
