Question about Sony KP-51WS500 51" Rear Projection Television
Sony tv 4-097-091-ps wont turn on - Sony KP-51WS500 51" Rear Projection Television
My sony kv-40xbr800 blinks 6 times, no video no audio, it wont turn on, whats going on?
The problem is on the 'A' circuit board. It is the IC504.Or, it is a low voltage drop or a short. Replace the "A" board. It is the front board on your right when you are at the rear of the set when you remove the cover. Look it up on the net. PS Don't touch the chassis while it is on...HIGH VOLTAGE !!!
Aug 02, 2010 | Sony FD Trinitron WEGA XBRKV-40XBR800 40"...
Tip
Problem solving
if your ps vita is so wet that you cant even turn it on and the blue ps light wont turn on, it would be best to put it in a bag of rice
on Mar 01, 2016 | Sony PS Vita - Vita System Wi-Fi
My ps3 will turn on but wont show a picture on the tv or give sound
Reset the video settings by turning on the ps with only the power cable plugged in, when turning on continue to hold the power button until you hear a second set of beeps then turn off the console.
Boot up the ps and plug in your av/hdmi cable and you should have picture and sound.
Jun 12, 2010 | Sony Playstation 3 (PS3) Console
I cannot turn on my Sony Wega any more?
please check the power supply of your tv and also the electric board.after that if it is not turn on then see the smps whics is on your tv cainet.check the diodes of ps.
Feb 03, 2010 | Sony FD Trinitron WEGA KV-32FS120 32" TV
I turn on my playstation and it works but i got no picture or sound. Recently i took my playstation to a mates place. my tv is standard def. my mates is high def 1080p. when i connected my sony to my mates...
sometimes ps has this problem as i m also havin a ps2 n ps3 n i play them on my standard definition tv ....i also hav to restart again n again till 10 to 12 times then finally it starts this may be a plate problem go show it to ur nearest service center.......hope it works
Jan 17, 2010 | Sony Playstation 3 (PS3) Console
It wont turn on
UR PS IS FIRED IT COST 160 TO SEND IT BACK TO SONY AND THEY WILL SHIP YOU A NEW ONE I HAD SAME PROB ..
Mar 02, 2009 | Sony Playstation 3 (PS3) Console
Tv wont turn on -- stand by light just keeps blinking
This is very common problem for sony. Blinking light is power supply problem need to replace two voltage reulators in supply and caps and sometime horz output.
Sometimes if you adjust screen voltage adustment on flyback just slightly it will fix it.
cost if ps is 225.00
screen is 95.00
Thanks doctor video
May 17, 2008 | Sony KV-35S45 35" TV
HDMI output not working
when the ps3 is off and the red light is on hold the power button down for 5-10 sec youl hear a second beep then let off wait just a moment and it should find your components
Apr 13, 2008 | Sony Playstation 3 (PS3) Console
Picture on tv isn't appearing and controller not connecting
The only easy fix i know is to turn the console off and then press the power button until you hear a second beep. Hope this helps.
Mar 15, 2008 | Sony Playstation 3 (PS3) Console
Sony KP-51WS500 51" Rear Projection Television Logo
213 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
