Question about Home
Toilet fills up slowly
Hi. I have a Kohler toilet and it is filling up very slowly. It basically just drips out of the top assembly on the fill valve. However, if I turn off the valve to the toilet and then turn it back on again it will fill up quickly until I flush the toilet then it starts to fill up slowly again.
  • Anonymous Mar 31, 2014
    not filling properly
    Sergeant:
    Champion:
  • 239 Answers
Buy a universal fill valve and replace it
Posted on Jan 03, 2009
Water supply to toilet fills up tank too slowly
Valve fully open on inlet going into toilet if it is then fill valve needs to be replaced check water line for any abstructions that might interfere with water going into tank.
Apr 02, 2014 | Kohler Home
The toilet flushes but it won't fill. I can turn the water supply off and then back on, then it fills normally.When the tank is full, I can push the float down and no new water enters. when I flush,...
Hi!please kindly check your fill valve if it is working correctly.I thought the problem is in your fill valve.Kindly adjust the floater of your fill valve.
Aug 24, 2011 | Kohler Home
My Kohler toilet tank is not filling fully, the water that is filling the tank sounds so loud it sounds as if the sink faucet is running instead of the toilet filling and the bowl does not fill fully and...
Change out the ball **** and float assembly and flapper valve to one of the newer types...
Also you can set the level of water in the tank by an adjustment screw located at the top of the ball ****.
The Flapper valve on the bottom of the tank also needs replacement, that is causing the tank not to drain properly.
This is a free answer, please rate me
Oct 13, 2010 | Kohler Home
Just bought and just had installed a Santa Rosa toilet that will not shut off when filling. Found flush valve filling chamber to have a triangular hole close to base of cylinder. when you cover this...
I would say yes....here is the .pdf for your toilet and it has nothing like that in it...your toilet should be a simple fill device and flush mechanisim...
I would return it for a new one...
http://www.us.kohler.com/onlinecatalog/pdf/1066506_2.pdf
heatman101
Aug 05, 2010 | Kohler Santa Rosa K-3323-0 White Compact...
Toilet takes vey long to fill the tank.
More then likely the power valve in your flush master ball valve is out.. Replace flush valve and should fix problem. Home depot sell fluid master for like 7.50
Mar 02, 2010 | Kohler - Toilet - Two-piece - Highline -...
Kohler Highline Class V tech toilet. Bowl does not fill. Why? What can I do to fix it?
Check tank for fill line running from fill valve to overflow tube. It will be a 1/4 " line that allows the tank and bowl to fill. It should be connected from fill valve and connected at the top of overflow by a clip or hanger.
Check out the water level in tank to make sure it is filling to line on overflow or within 5/8" to top of overflow pipe.
Feb 06, 2010 | Kohler - Toilet - Two-piece - Highline -...
I have 2 K3466 model Kohler toilets and just had a
There is a volume control screw on the valves usually a plastic thumbscrew on side of valve turn clockwise until they quiet up the plumber should have adjusted that these are very tempermental toilets but when adjusted properly are excellent toilets I have 2 in my own home
Oct 26, 2009 | Kohler K-3466-95 San Raphael one-piece...
Toilet will not flush
It sound like you have debris caught in the fill valve. Remove the top where the washer is and put your hand over it and slowly turn the water on to flush the fill valve. Replace the washer with a new one and then replace the top.
If you have the old ball and **** style, replaceing the diaphram is harder so I would recommend replacing it with a fluidmaster fill valve. Hope this helps.
Apr 06, 2009 | Kohler K-3422 - Wellworth Elongated...
Valve adjustment
You need to replace the flapper and you will need to purchase one specifically for the Kohler toilet. I have the same toilet and tried using a generic flapper and from experiance, it didn't work until I bought the correct one and I'm a plumber! Have a great night.
Apr 01, 2009 | Kohler 3386-6 Rialto Skylight Round Front...
Toilet tank fill valve sprays water towards lid
Hi bpmorr1,
It may be that the fill tube has come disconnected . It runs from the top of the fill valve to the overflow. The overflow is the tube that runs up the middle of the tank. The fill tube runs from the top of the fill valve to the top of the overflow tube. Kohler has a little clip that can sometimes come undone and cause spraying.
If that doesn't do it, turn the water off to the toilet and take off the tank lid. Partially open valve ( Slowly). Locate where spray is coming from. If it is in the area on top of the fill valve then yes, buy anew one. ( Fluidmaster )
Please rate this response and good luck, Phil
Dec 26, 2008 | Kohler K-3360-G Revival One-Piece Toilet...
Home Logo
1,172 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
