Question about Poulan Wild Thing 2375 18" Gas Chain Saw 2.5 Cuin
Engine pulls over good, without spark plug in , but very hard to
Very hard and jerky with plug in. I tore completly down and found no problem. Acts like too much compression. piston ring bearings all look good. Is it possible the rod could have stretched due to improper oil mixture.
  • Anonymous Jan 21, 2009
    same as above, but never torn down farther than cleaning filter and wood chips.
  • 181 Answers
Nope the rod will not stretch.did you put the piston on backwards.ring openings go to the intake side of piston
Posted on Jan 07, 2009
Why does my briggs and straten model 313-707 hard start then dies after a few seconds when it is running it acts like it's starving for fuel replaced fuel filter fuel cap and cleaned carb
Try replacing the plug.could also be a spark problem from the coil .you can purchase a spark tester which you can fit between the plug and lead .pull start mower and watch if spark is good.if ok then get a can of carby clean start mower and spray carby clean spareingly while running and if it keeps going the fuel is the problem
Aug 14, 2014 | Garden
Rope hard to pull
if there is an auto shut off adjust the cable its not pulling all the way open
Mar 08, 2014 | Karcher 2500 PSI Pressure Washer
Car is very jerky
What kind of car? Without much detail it's really hard to diagnose this. Make, Model, Year, and a description of when it's jerky would help (braking, accelerating, coasting, etc.) Are there any other symptoms/sounds related to the jerkyness? Could be anything from a bad spark plug to a bad transmission to a out of balance tire.
Aug 06, 2013 | Cars & Trucks
What is causing my 2005 Mazda 6 sport wagon to run jerky and not accelerate smoothly.
If it started only 3 days ago, go to your auto parts store and the next time you fill up, add a can of Sea Foam. If there is a gas station near you which sells gasahol-free gas, fill it up with that, then take it out on the interstate and kick it into passing gear several times (I hope you don't get a speeding ticket).
Nov 09, 2017 | 2005 Mazda 6
My stihl 041 saw very old made in germany farmboss but very low hours on it. will pop and smoke a little but not start. When I pull on the starter and it almost starts it gets very hard to pull on rope -...
Answer to 2 year old question about hard starting saw.There is a seal that goes bad and leaks chain oil into the crankcase.This will make it very hard or impossible to pull the starter rope. To start the saw,pull the spark plug, stand the saw on it's end so the bar is pointed up and pull the rope 10-15 times. Replace the spark plug and start.It will smoke for a while.To stop this from happening, always store the saw with the bar pointed straight down.
Jun 29, 2010 | Garden
Ryobi rcs3535.pull start operates easily when plug removed.when plug is replaced the pull start has so much resistance that turning the engine over requires too much effort and it is extremley jerky.
Remove the spark plug, ignition off, and open the choke and throttle. Turn the saw upside down and pull the starter through vigorously to see if the engine expels any fuel. Replace the plug and see if there is any change. Does the engine have a compression release? If so, it may be plugged with carbon--remove and clean or replace it. Modern saws seem to have more compression than earlier saws. I have a new, small Husky saw that is equally hard to pull and no compression release. The cure is to sell this one and find a saw with a compression release, or one that is otherwise not so hard to pull through. Good luck!
Jun 05, 2010 | Garden
Valve replacement,one of my pistons isn't firing, the spark plugs are good, and my timing belt just tore so i'm thinking it may be the valve but i don't know how to replace it.
pull the head and send it to a machine shop . have them c/k all the valves . this will keep you from doing it twice . do a compesion test on the engine before you tear it down . you should have 120 psi in a good cyl . if less then that you have a problem
Jan 28, 2010 | 1992 Honda Accord
McCulloch 3200 takes many pulls to start, runs good when does.
I don't think I can help, but normal starting procedure for me is to put choke on, pull on recoil until it kicks over once. shut off choke and restart. Sounds like you have fixed almost everything & adjusted mag right. Rick
Mar 17, 2009 | McCulloch 16 In 4.5 Hp Electric Chainsaw...
Husqvarna Chain Saw Rope Pulls Very Hard, what is the cause?????????
Has it always done this or has it developed?
Some saws have a decompression button to make it easier to pull over.
Oct 03, 2008 | Garden
Poulan Wild Thing 2375 18" Gas Chain Saw 2.5 Cuin Logo
227 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
