Question about Air Tools & Compressors
Craftsman Air Compressor Model # 921.166380 WONT START
WONT START JUST HUMES A MIN AND THEN KICKS THE BREAKER DO YOU THINK IT IS THE 2 CAPS
  • 1388 Answers
SOURCE: air compressor flips breaker before it will start?
Air compressors tend to draw more power as they age, however, will not trip breaker unless some malfunction. Here are some simple tests. Unplug compressor and turn the pump by hand, you may have to remove a cover to do this. It should turn freely; any resistance could be failing bearing (would make noise) unloader/check valve leaking allowing back pressure to pump, or failed start capacitor/start winding. Easy test for checkvalve. With pressure in tank loosen discharge hose at tank and check for air leak. Check valve should hold pressure in tank. Replace as needed. Failed capacitor/s will cause high amp draw. Remove from circuit and test. UF reading should be within 95% of printed rating. Finally, most air compressor motors have two windings, start and run. Power to windings is controlled by flyball switch inside rear of motor. This switch has contacts that can stick in start position and cause high amp draw. Examine windings for signs of overheating. Copper windings generally have color of new penny. Very dark brown windings bad news. Gook luck
Posted on Jan 06, 2009
  • 1388 Answers
SOURCE: Oil capacity for craftsman air compressor circa 1978 model #106..
I have a 2hp craftsman air compessor with a two cylinder pump, Here is the info from my manual as far as oil capacitity:
Remove oil fill plug and slowly add
a compressor oil until it is even with the
top of the oil fill hole. NOTE: Do not
allow oil to be lower than 3/8"
from the top at any time. When filling
the crankcase, the oil flows very slowly
into the pump. If the oil is added too
quickly, it will overflow and appear to
be full. NOTE: Crankcase oil capacity is
approximately 16 fluid ounces.
I buy my compessor oil from Lowes in the tool department. It comes in 16oz and sells for about $3. I wouldnt worry about how many ounces it holds but rather that the oil level is to top of filler hole. Lowes also sells a synthetic oil for about $7 and is recommended for severe conditions (hot / cold / used all day). Good Luck!
Posted on Apr 26, 2009
  • 68 Answers
SOURCE: i have a electric air compressor craftsman 3.5hp
The pressure switch controls the cut-in and cut-out points for the motor. Some switches have a differential adjustment besides the pressure adjustment. The differential controls the spread between cut-in & cut-out, (say in at 80 PSI, out at100 PSI)
Try looking for these if you didn't get a manual.
Good luck
Posted on Apr 27, 2009
  • 135 Answers
SOURCE: Air compressor that trips my circuit breaker
Most garage curcuits are 15 amp GFI plugs and they won't run most compressors. Drain all of the air out of the tank and see if it runs. If so then you are going to have to add a 20 amp plug for your pump.
Posted on Jan 17, 2010
  • 15 Answers
SOURCE: i have craftsman air compressor model number919-167310
is this new, has it ever run? perhaps the breaker isn't large enough for the units required amperage, maybe the breaker is just bad. Have you tried different recepts? Check the nameplate for the amp requirements and make sure the breaker is big enough
Posted on Mar 19, 2010
Craftsman air compressor model 919.16726 wont build pressure and makes a rattling sound
My compressor runs for about 5 min and shuts off.....does any one knows what could be the problem?
thanks
Aug 20, 2012 | Craftsman Air Tools & Compressors
Breaker trips when you try to start compressor motor spins a little before tripping breaker
Just fixed my compressor. It would start ok when the tank was empty but trip the breaker if it tried to start with pressure. Searched and read about weak caps, or problem with check valve or pressure switch leaving pressure in the pump head, etc. Turned out that the black plastic box which holds the 2 start up caps and is attached to the end of the motor with 2 screws had cracked on the bottom. The black box had tilted out enough that the start up caps switch was not engaging. Pushed on the lower part of the box and it started perfectly. Fixed it for the cost of some 2 part epoxy. Maybe not your fail, but definitely worth checking out first.
May 04, 2012 | Craftsman 33 gal Air Compressor 6 hp...
My Craftsman 15 Gal Air Compressor trips the electric breaker at start up no mater where I plug it in.
Apr 12, 2012 | Craftsman 15 gal Air Compressor 3 hp UMC...
Why does my compressor trip the breaker after filling with air
1 of 2 things #1 the pressure releive valve that lets the pressure of the pump when it kicks off is stuck closed so what is happening is when the compressor kicks back on its under a load and trips braker. #2 your braker is to small for the compressor.
Jan 11, 2012 | Craftsman Air Tools & Compressors
Installed new breaker just for the compressor and it still only runs for a second or two and kicks breaker
You need to find out how much amperage the compressor pulls and make sure the wiring and breaker are sized correctly.
If they are sized correctly then you likely have an issue with the motor or the compressor itself causing the breaker to operate.
Apr 15, 2011 | Craftsman Air Tools & Compressors
Compressor fills air tank and when it cycle to refill tank it kicks a 20 amp dedicated circuit breaker. Sears looked at it twice and said it is OK. Changed breaker with new one because Sears said it...
try this. When compressor shuts off. TURN OFF POWER. then spin the compressor backwards or forwards until it is off the compression stroke. Turn unit back on. If it doesn't blow the breaker, then it is worth looking into the type of compressor (pump) you have. Many have a "reed valve" and that might be failing, holding the compressor itself under load when it shuts off so that on restart it is under heavy load and the motor draws too many amps to get it started hence blowing the breaker anyway hope this helps
Feb 17, 2011 | Craftsman 25 gal Air Compressor 3 12 hp...
I have a 25 gal. craftsman oilless air compressor. Runs for about 1/2 a minute & than kicks the breaker out.
Hello babeaton, several things can cause that, but, the most common thing is the regulator. let it run again and right ofter it kicks off feel the power cord and see if it's warm to the touch, if so it likely is the regulator. Breakers operate based on the amount of heat generated from current running through the cord/wires.
Good luck my friend!
Jan 16, 2011 | Craftsman 25 gal Air Compressor 3 12 hp...
It worked fine last year. This year it throws the breaker on the gen. After 2 or 3 min. The fan works on low and high but it trips on low or high ac its a model 6759c707
If all is the same as when it ran good, such as same power cord (no extension, or properly sized extension ) same generator output voltage etc, then I'd check amp draw when compressor kicks in. Good chance compressor start capacitor may be faulty.
Jun 26, 2010 | Dometic Rooftop RV Air Conditioner
I have a craftsman 1.5 hp/ 2 Gal. air compressor and everytime i go to turn it on it kicks out the breaker. model #921.152100 capacitor ????? plaese help aroberts616@aol.com
Hi there. Plug your compressor in as close to your circuit box as you can on a circuit that is dedicated to that outlet
What is happening is this. You have a 15 amp circuit and a 15 amp draw on your compressor. No wiggle room at all. If you need to get the air a long ways use air hose and never an extension cord. Joe
May 29, 2010 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
Air Tools & Compressors Logo
71 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
JOHN LAPIER
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
