Question about Memorex Ultra Traveldrive - 160GB USB Hard Drive
Memorex 160gb external hd
Was working fine. No all computers dont reconise it?
Please help[
  • Anonymous Jan 27, 2009
    i have the same problem my ultra traveldrive not reconized by any computer thats all
  • raulderoa Jan 31, 2009
    EL PC NO RECONOCE EL DISCO DURO EXTERNO. ME DICE QUE NO TIENE FORMATO. HA ESTADO FUNCIONANDO BIEN HASTA ESTO.
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Sorry to be bringing you the bad news, but chances are, the Memorex is a goner. You could still of course try removing the actual/internal hard drive, connect it to an IDE/SATA to USB adapter and see if that in turn would be recognized by any of the computers. If yes, then it is the electronic/data interface of the Memorex that is defective. If likewise not also, then the actual hard drive is faulty. If the hard drive still spins and makes no mechanical noises, there is a slim chance that the contents could be recovered using file recovery software such as GetDataBack.
Good luck and Thank you for using FixYa.
Posted on Jan 03, 2009
Good day. I have a memorex ultratravel drive USB 2.0 160GB. Everytime I connect to any computer I get the message:The pc does not recognize the USB device code 43. Please let me know what i can do. thanks...
Code 43 is the death code - the pc simply cannot communicate with the attached device because the device is not working. This means that the Memorex is dead . Since the electronics board inside it cannot be repaired or replaced it means that yo must buy a new one.
Apr 09, 2011 | Memorex Ultra Traveldrive - 160GB USB Hard...
I have a Memorex Ultra Drive connected via USB to a Windows XP machine. It shows up in My Computer as a folder but then disappears again. It does this repeatedly. The drive is formated as a FAT32. How...
As you have described that your Memorex Ultra Traveldrive re-appears repeatedly, indicates that the communication between your computer and your external hard drive is intermittent. The FAT32 format does not produce these types of issues. What we can do first is identify what causes the problem.
Assuming that the hard drive in your Memorex Ultra Traveldrive is in good shape:
Troubleshooting Method #1. Try connecting your Memorex Ultra Traveldrive into another USB port. If the problem persists, use another USB cable for your external hard drive. If the problem still persists, you will have to replace the external casing of your external hard drive. If your external hard drive works with the other USB port perfectly, most likely, the USB port where you originally plug into of your Windows XP machine needs to be checked. That USB port might need some repairing.
Troubleshooting Method #2. Try connecting the external hard drive into another computer and perform the same troubleshooting as Method #1. If your external hard drive works with other computers perfectly, most likely, the USB port where you originally plug into of your Windows XP machine needs to be checked. The USB port might need some repairing.
If the problem only occurs with your Windows XP machine, assuming all USB ports are in good shape, your Windows XP needs to be checked for some software issues.
I hope this works for you. Kindly reply/comment for further assistance. Good Luck!
Thanks for using Fixya!
Mongkey
DELL Tech ID #456563
TIPS: Is your computer slow? This might help
http://www.fixya.com/support/r8158906-diy_manual_pc_tune_up
(for Windows only)
Apr 06, 2011 | Memorex Ultra Traveldrive - 160GB USB Hard...
External memorex does a cling cling sound continuously and cannot be detected on the laptop
The external harddrive has a processing unit to compile and store data. A noice is expected as usually functionaily though much more noise is indication of porcessing of data into backup media files. Allow the computer some time soon after usage to achieve processes without powering off. Durign whihc time backup is attained.
Jan 29, 2011 | Memorex Ultra Traveldrive - 160GB USB Hard...
I haven't used my hard drive in just a couple of days and when i use it again my computer doesn't recognize it. I've tried all the usb port in my pc and adaptors/usb cables but it does not work at all as...
You have a couple of options:
1. Take your USB HD to your friends computer and it your friend can read it.
2. If you feel confident, remove the HD from the USB case and place it inside your computer and see if the HD works.
Oct 06, 2010 | Memorex Ultra Traveldrive - 160GB USB Hard...
Computer Not Detecting External Hard Drive
Try a new cable this may work if not it sounds like the HDD has failed you can try placing the drive in a zip lock bag and but it in the fridge overnight then try again if this fails then its U/S.
Mar 08, 2010 | Memorex Ultra Traveldrive - 160GB USB Hard...
I have WD 160GB external hard drive. when i plug in to the computer.it shows on the taskbar as USB storage device but without an assined letter . on my computer window shows nothing about the external hard...
Attach your external HD with some other computer, that will definitely appear normal, the problem is due to a virus in ur HD. Your computer's antivirus software stops it to appear. Back up your data on the other computer, format ur external HD, remove un-necessary files and run a virus scan to the files u copied from HD, Hope this will solve the problem, if not, let me know and tell me what would be the response on the other compuer
Sep 20, 2009 | Western Digital 160GB 7200RPM HDD WD1600BB...
I have down loaded all my memory from my old computer on to a wd external hard drive.I now want to put all i have on the HD on to my new computer.but the computer dont reconise the hd when i connect...
it is may be due to the usb device driver problem. go to the device manager and see that the usb mass storage driver is installed in ur system . if not then install it from ur motherboard cd and then plug it and certainly it will work.
Sep 05, 2009 | Computers & Internet
My HD dont Work anymore
hey! i was having the same problem, but it all seemed to be fine after i opened the case up... what you see inside is a hard drive connected to a small circuit board used to make that hard drive interface with the computer. basically what happened with mine, and probably yours was that the hard drive slipped out of the socket on that circuit board- the drop it took was probably JUST enough to make that happen, given that there's some room inside the case for it to slide a little.
if you don't mind potentially voiding your warranty, i'd suggest you do what i did:
- keep the drive unplugged from everything
- peel off the sticker underneath to access the screws
- slide the hard drive back into the socket on the little green board where the USB sockets are
- close it back up and test it out.
this worked just fine for me, and i hope it works for you too! it also saved what might have been ****-loads of money taking it to a recovery specialist :D
good luck!
- chip
Jan 16, 2009 | SimpleTech Signature Mini 160GB External...
Using the 160GB passportHard drive
are there any errors that popped up while copying the music files? if not, then it probably works fine. the files are now stored on the harddrive.
if you want to safely unplug and carry the HD over to another computer, you can., the files should be accessible... that's all a harddive does.
Dec 29, 2008 | Western Digital Passport 160GB External...
New 200GB HD on my LG P1 Express Dual
i have p1 express dual, i have put windows 7 ,2 gb ram , and upgrade HD to 250 7200rpm, i only have to run a cd so i update the bios. my email is m4rios@hotmail.com it took me many hours of searching to find it, i ll send it to anybody i dont believe that even lg company has that bios, is from ''phoenix''
Mar 17, 2008 | HP Pavilion dv6000z Notebook
Memorex Ultra Traveldrive - 160GB USB Hard Drive Logo
443 people viewed this question
Top Memorex Computers & Internet Experts
Gareth Cockram
Gareth Cockram
Piyal Perera
Piyal Perera
Jax Planet
Jax Planet
Are you a Memorex Computer and Internet Expert? Answer questions, earn points and help others
