Question about HP Pavilion 110-1030NR Notebook
Replaced hard drive now dont know what to do
This is the error message I am getting: Check cable connection..! PXE-E63: Error while initializing the NIC PXE-M0F: Exiting Intel PXE ROM Reboot and select proprer boot device or insert Boot Media in selected Boot device and press a key
    Sergeant:
    Champion:
  • HP Expert
  • 427 Answers
This is because the new HDD does not have an operating system on it and the computer tryes to boot using LAN. You will have to install WINDOWS from CD/DVD or USB. Ask here for directions please
Posted on Apr 18, 2013
  • 916 Answers
SOURCE: System failure to boot
Check you hard disk drive and make sure it is connected correctly. Is there a new hard drive in the device? If so you will need to install windows onto it. Otherwise as Ekse has said run the recovery console from your windows cd.
Posted on Feb 04, 2009
SOURCE: HP 1000 mini-netbook bootmgr compressed--no cd/dvd hard drive--
Why all these clueless suggestions? I came here looking for help, but it appears I'll be solving my own problem and lend a hand. First attach something bootable via USB like you already know. Change boot order and boot from some kind of XP install disk. That's where I'm at right now. I'm now in the recovery console which gives me a command line. I had JUST READ somewhere the comand line commands to restore the boot manager that we just compressed.
Hold on....OK ! Problem fixed.
Step by step:
1)Get external CD reader and plug into USB
2)Boot Mini hit F10 or F12, whatever it says to change boot order
3)Reboot and you'll see you now have option to change boot order on bootup.
4)Boot to some kind of XP start disk(stupid me never even looked at HP's recovery disk yet - I didn't want to go there!)
5)Let the startup program run til it stops asking you to select an option, and hit R for recovery console
6)You'll want option 1 for c:/windows and type your password when asked
6)type fixboot then enter
7)It will happily inform you that your boot record is repaired
There may be some warnings or statements in between. You're desperate - agree to whatever they say! ;-)
8)reboot
9)Don't worry, be happy
If you can't stand that you now have that message booting up every time and it looks weird, RIGHT click my computer, properties, advanced, startup and recovery settings, and edit ....change default operating system from ** to Microsoft Windows XPHome etc."
click edit and for good measure delete where it has WINDOWS="" as an operating system. Don't mess with this if you're not sure.
10)Now be happy!
Posted on Sep 05, 2009
parrotheadpc
  • 2600 Answers
SOURCE: Computer does not boot up
Sounds like the computer cannot find your hard drive and is looking for other means to boot the machine. It first is looking for a network hard drive, then it is looking at the DVD. When that fails it is asking you to check the computer for hardware errors. Check to make sure the hard drive is seated in it's compartment. The DV6000 has an adapter that fits on the end of its SATA drive and sometimes that adapter can wiggle loose from the contacts. Just take the hard drive out and then re-seat it to the connector. In most cases it is either a loose connection or the hard drive has suffered a failure.
Posted on May 19, 2010
engineerayo
  • 169 Answers
SOURCE: my hp mini is showing
Insert a Bootable Opearating system CD
Reload Your Operating System if Problem persist change your hard disk
Load the Operating System
Posted on Dec 21, 2010
bronk50
  • 27725 Answers
SOURCE: Reboot and select proper boot
During the boot process you will see on the screen to press a certain key to enter setup
Press and hold that key during the boot up process to enter BIOS the scroll down to advanced bios features press enter change your first boot device to ......,press escape then press f10 to save to cmos to restart
The BIOS is AMI. Under ADVANCED SETUP:
The options listed for 1st,2nd ,3rd Boot device include:
IDE-0 means Pri master ?
IDE-1 means Pri slave ?
IDE-2 means Sec master ?
IDE-3 means Sec slave ?
?????????????????? hope this helps
Posted on Dec 27, 2010
Pxe-E63 : error while initializing the NIC
Check the boot sequence. For a normal boot, it should be set to hard disk as first item, not the network.
Jul 01, 2012 | Acer Computers & Internet
Check cable connection..! PXE-E63: Error while initializing the NIC PXE-MOF: Exiting Intel PXE ROM No bootable device -- insert boot disk and press any key
Hard drive is not detected. Change the Boot sequence in BIOS
1. To access the BIOS you must tap F2 or delete key upon turning the computer on
2. Try to look for the Hard drive if it is detected by BIOS if not got to step 6
3. Look for Boot Sequence or anything that is associated Boot
4. The Order boot of must be 1st: DVD Drive, 2nd: Hard drive, 3rd: Network etc.
5. Save the changes and Restart
6. If you still get the same message I suggest that you take out the hard drive and put it back in until it is detected in BIOS
7. If Step 6 did not work I think you need to replace the Hard drive
Thanks for Choosing
Jun 16, 2011 | Acer Computers & Internet
CHECK CABLE CONNECTION..! PXE-E63 ERROR WHILE INITIALIZING THE NIC PXE-MOF EXITING INTEL PXE ROM NO BOOTABLE DEVICE---INSERT BOOT DISK AND PRESS AND KEY
Welcome to Fixya. Can you please try to go to Bios Page, On the Boot option make sure that the First Boot Priority is the Hard Drive. After that can you please save the settings and check if you will be able to boot to windows.
The error occurs because it is looking for the drive that your operating system is installed. Can also make sure to remove all removable devices connected to the computer. Let me know what happen so that we can proceed to the next step.
Thanks
May 30, 2011 | Acer Aspire One PC Notebook
Acer aspire will not start. get message check cable connection! PXE-E63 error while initializing the NIC PXE-M0f Exiting Intel PXE ROM No bootable device - insert boot disk and press any key. Netbook has...
1. It seems that the hard drive is not bieng detected by the computer 2. and from the error message that you are getting it seemed like windows is not loading up 3. I would suggest that you take out the hard drive and put it back in 4. the reason for that is the hard drive that connects from the mainboard is
May 29, 2011 | Computers & Internet
I have an emachine em250 and I am recieving an error message saying (check cable connection...!) pxe-e63 error while initializing the nic pxe-mof: exiting intel pxe rom no bootable device--insert boot disk...
This error message is generated when the processor can't detect the presence of a hard disk because either the disk is dead and it will have to be replaced or the southbridge chip on the motherboard (the one that controls the disks) has failed - both severe hardware defects.
If after replacing the hard disk you get the same message then you need a new motherboard.
May 03, 2011 | Acer Aspire One Netbook 8.9" Notebook
I'm running a Windows 7 netbook- acer aspire one. 32 bit Prossesor- Intel Atom BOOTING ERROR- I press power and the ACER logo pops up (normal) and then: For Atheros PCIE Ethernet Controller...
This message means that the computer cannot see the hard drive. Unofrtunately, this is usually caused by a failed Hard Disk drive. However, you could try removing and re-fitting the hard drive to see if this cures the problem.
Full instructions on removing and replacing the hard drive can be found here:
http://www.laptopmag.com/advice/how-to/aspire-one-hdd.aspx
Apr 12, 2011 | Acer Aspire One PC Notebook
Every time I turn on my computer the following message appears: "For PCIE Atheros Ethernet controller v1.0.0.5 Check cable connection ..! pxe-e63: error while initializing the NIC pxe-mof:...
It sounds like the hard disk is faulty, the machine is trying to boot via the network card as it cannot find a bootable disk. You could try removing the hard drive and reseating it but the disk could be dead.
Apr 04, 2011 | Acer Aspire One PC Notebook
It says check cable connection! PXE-E63:Error while initializing the NIC PXE-MOF:Exiting Intel PXE ROM. No bootable device -- insert boot disk and press any key
This could mean a few different things:
1.) Your hard drive is bad.
2.) Your hard drive cable is bad.
3.) The cable that connects to your hard drive is loose.
If you are under warranty, I would advise you to contact the MFG. to have them replace the drive or check it out for you.
Mar 15, 2011 | Computers & Internet
Http://www.fixya.com/support/t3058946-error_when_start_computer
""THERE IS AN ERROR WHEN I START MY COMPUTER, IT TELLS ME PXE-E63 ERROR WHILE INITIALIZING THE NIC, PXE-MOF EXTITING INTEL PXE ROM, AND ADISK READ ERROR OCCURRED, HOW CAN I FIX IT""
Disregard the PXE-E63 Errors. The only one to pay attention to is the "Disk read error occured". Some Acer models always give these errors but as far as I can tell the PXE errors are nothing to worry about and thus have never given me any issues in my career.
Reseat the Hard drive when the machine is switched off and power is unplugged and battery is disconnected.
If you can test the hard drive for bad sectors OR if it picks up in another machine by installing it into a external hard drive casing. This case can either be mini-IDE or SATA.
Also you could get a bootable hard drive tester and test the hard drive on your machine to work-around the above.
As a final suggestion, replace hard drive and send in original hard drive for data recovery if needed.
May 25, 2010 | Acer Aspire 3000 Notebook
When turning the computer on I'm getting an error that states Check Cable Connection PXE-E63: error while initializing the NIC No bootable service insert boot disk and press any key
Go to BIOS setup page and see if the hard drive shows up. It is trying boot of network. Go to boot up sequence and set hard drive to be first device. I have a feeling that the hard is bad.
Nov 04, 2009 | Acer Aspire One Netbook 8.9" Notebook
HP Pavilion 110-1030NR Notebook Logo
112 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
