Question about Familybuilder Family Tree
Www.snoope.com computer is acting up
DHCP Users Go Online Through the S2700, But Cannot Access the Internet. Why?
When a large number of DHCP users go online through the S2700, the S2700 generates a large number of dynamic DHCP snooping binding entries. On the S2700 V1R6C00SPC800, the software provides incorrect priority settings for DHCP snooping binding entries and IP source guard and DAI ACL rules, and the ACL rules have a higher priority than DHCP snooping binding entries. As a result, the software delivers the ACL rules but not DHCP snooping binding entries. User packets cannot be forwarded because no binding entry is available.
Solution: Install S2700SPH006, enable DHCP users to go online again, and reconfigure IP source guard and DAI on the physical interface from which DHCP users go online.
S2700 Switch Thunder link com
Nov 04, 2016 | Computers & Internet
Does MFF Allow Online Users to Retain Online After the Switch Restarts?
In V100R006 and later versions, whenboth MFF and DHCP snooping are enabled, you can use the dhcp snooping user-bind autosave file-name command to back up DHCP snooping binding entries in a specified file. This configuration allows online users to retain online after the switch restarts. Note that the backup file saves only the first gateway address of users.
S5700 Switch Thunder link com
Oct 28, 2016 | Electrical Supplies
How to Configure IGMP Snooping Proxy to Support IGMPv3?
To configure IGMP snooping proxy to support IGMPv3, perform the following configuration: In the system view: igmp-snooping enableIn the VLAN view: igmp-snooping enableigmp-snooping version 3igmp-snooping proxy enableThe preceding configuration implements IGMP snooping proxy for IGMP v1/v2/3. http://www.thunder-link.com/LS-S2309TP-EI-AC_p623.html
Aug 15, 2016 | Computers & Internet
How to stop user privately setting up a static IP address?
Huawei S2300/3300/5300 series switch although no H3C switches am user-bind command, but through the DHCP Snooping function can also be realized IP+MAC+ port binding to prevent users set up a static IP address. For example, if the request port Ethernet0/0/1 in addition to the static IP address for the 1.1.1.2, MAC address for the 001c-2309-9aa7 corresponding to the user, all other static IP users can not access the internet. Configuration is as follows:
Configure the device DHCP Snooping
# enable the global DHCP Snooping function.
[Quidway] DHCP snooping enable
# configure user side interface of VLAN.
[Quidway] VLAN 100
[Quidway-vlan100] quit
[Quidway] interface Ethernet 0/0/1
[Quidway-Ethernet0/0/1] port default VLAN 100
[Quidway-Ethernet0/0/1] quit
# enable VLAN DHCP Snooping function.
[Quidway] VLAN 100
[Quidway-vlan100] DHCP snooping enable
# configuration interface for packet inspection at the user side
[Quidway-Ethernet0/0/1] DHCP snooping check ARP enable
[Quidway-Ethernet0/0/1] DHCP snooping check IP enable
# configuration static binding table entry
[Quidway] VLAN 100
[Quidway-vlan100] DHCP snooping bind-table static IP-address 1.1.1.2 mac-address 001c-2309-9aa7 interface Ethernet 0/0/1
Aug 06, 2015 | Huawei Boxed Ls-s2318tp-ei-ac Quidway...
How would i monitor my girlfriend's yahoo chat (real time) because im afraid whenever she's online for about half a day without talking to someone (thats what she said) and shes never been in an...
Chat or email is protected communication. I would not recommend this as there as ethical and legal implications on hacking into another person's communication.
There are packet sniffing programs like sharkwire which allows administrators to "sniff" traffic across a wireless or ethernet network connection. Even this is kind of a grey area for what you are describing. I think a straightforward approach will provide the best results, and withe the lease legal repercussions.
Mar 14, 2011 | IM Monitor Software Yahoo Messenger...
I need a bios update for a Gateway ML3108b.
So you are a tech so so Hello
I am also a tech here arre the things you should allways do before you attempt to slay the dragon man (IM THE DRAGON) lets get you fitted for the job
Ok Bio's man I hate firmware Let me snoop
brb
Here are some I think snoop around
http://bios-download.net/
You might surf a little more i have a system cd refernce on my machine you might try
it is: http://www.user-guides.co.uk/asp/search.asp?keywords=ML3108B&recor=1
Oct 19, 2009 | Computers & Internet
I want each vlan member to get different ip address scope.
I believe it is possible to do this, judging from briefly looking at the reference documentation, although I'm not entirely certain.
Here is a link to the documentation.
http://www.cisco.com/en/US/products/hw/switches/ps5528/prod_command_reference_list.html
ip dhcp snooping
ip dhcp snooping binding
Apr 01, 2009 | Computers & Internet
Familybuilder Family Tree Logo
77 people viewed this question
Top Familybuilder Facebook Apps Experts
David Payne
David Payne
Bill Boyd
ray gallant
Are you a Familybuilder Facebook App Expert? Answer questions, earn points and help others
