Question about Cyberhome CH-DVD 300 DVD Player
Door won;t open
Tried reset slot to open and the goor opemed buttray wants to stay like it is in bind
  • Aidan Butler
    Aidan Butler Oct 30, 2012
    what kind of door are you trying to open? and perhaps english that's understandable would be nice
I have a yellow light .on the front, and the disc tray won't
open. I have a cyberhome DVD player,CH-DVD 300.
Posted on Jan 12, 2013
My 2003 s40 drivers door key does not open the door lock all the way. It hangs up and the door stays locked. Is there an easy fix?
You can try spraying some oil in the keyhole, but you will probably need to remove the inner panel to see why it's binding.
Aug 04, 2017 | Cars & Trucks
My stanley mod6500 1/2 hp lightmaker sometimes opens and when open to set distanve it kicks out to "reset mode" ( have to switch manually from operate to vacation then back to operate ) to reset and then...
You could have a problem with the door which is causing the opener to kick into a safety mode. Release the door from the opener, run it by hand several times. If you feel it bind, figure out where it's binding and resolve that issue. Then reset your opener again and it should be fixed. If it is not binding, then most likely you have a board problem and will either need to replace the board or replace the opener. Stanley's are known for these type of board issues. I would stick to a liftmaster if you replace it.
Feb 20, 2015 | Building Materials
Hitachi ax-m71 cd door won't stay closed. Unable
if it opens back up when you close it the drawer mechanism is probably out of alignment. Most players have a slot on the bottom of the drawer that a pin must slide in. Look under the drawer and see if there is a pin sticking up that maybe should be in that slot.
Jul 09, 2013 | Audio Players & Recorders
Door won't engage and stay closed
Possible that the lock was broken and so the door opened. You can remove the front panel and check for broken plastic or nylon pieces which can be glued using instant adhesive.
Reset the lock and switch and the door must lock in correctly
Jan 21, 2013 | Microwave Ovens
Samsung microwave #SMH1611B door won't close
If it has the "double hook" type latch on the door,see if the hooks slide up and down.They should be spring loaded,if not,the spring attachment point inside the door may have broken off(my Sharp Carousel did this).I pryed the plastic door trim loose,and reattached the spring by using one of the slots inside to hold a metal wire clip(modified with needle-nose pliers) to hook the spring onto.Your door's design may be a little different,but a similar solution will probably be apparent after you get in there.
Dec 18, 2012 | Microwave Ovens
Central locking on a 1.6 w reg ford focus not working and the key fab and boot open button.... front passenger side goor not locking at all all other doors i can manually lock except the front door...
(door lock actuator)all doors have one in them, they weeken, and sometimes work to open, and some times to lock, or not at all. only fix is to replace each of them as they go out, usually cost abt 20 to 40 bucks a piece
Aug 26, 2012 | 2001 Ford Focus
My right passenger side sliding door won't open all the way as the left side one. It just opens 2/3, any idea why?
Your door may be binding in the guide tracks. Check when the door opens. You could try spray lithum grease if you find that the door does bind.
Jul 05, 2011 | Toyota Previa Cars & Trucks
Garage door opener won't open garage door
did you use the manual release to unlatch the door from the opener? You may have a problem with the door binding and opening it manually will confirm that. You may also have misaligned the sensors at the base of the door so check that too.
Feb 06, 2009 | Sears Craftsman LiftMaster Chamberlain...
Cyberhome CH-DVD 300 DVD Player Logo
187 people viewed this question
Top Cyberhome Televison & Video Experts
zappal
Electro Med Services...
Are you a Cyberhome Televison and Video Expert? Answer questions, earn points and help others
