Question about Kitchen Ranges
Display not working on IKEA FRAMTID Slide-in Range with Gas Cooktop
  • 833 Answers
SOURCE: My Frigidaire range display has gone out and the oven doesn't work.
sun, first test is to power the unit down. Find the pair of breakers which are generally 40 or more amperes. Turn them both off and back on. If this doesn't fix it, you will probably need a circuit board.
Posted on Dec 13, 2007
philbran
  • 242 Answers
SOURCE: Where is the fuse panel
I can help , The fuse panel/control board is located behind the digital display in the front of the unit. Some drop in ranges are tricky getting into so be carefull when removing the face , there are screws under the display when opening the oven door look up and there may be a few more on the top side corners reveled when you pull the unit out 12" or so. there is a small glass fuse in the board some of these are not removable so if there is no digital display on your oven and your sure you have 240V to control board you will need to replace the entire control board. Hope this gets you there. Good luck let me know if you have anymore problems.
Phil
Posted on Dec 31, 2008
SOURCE: GE profile gas range: Gas burners don't work
Used toothpick to unclock gas output and worked great.
Posted on Jan 23, 2009
alandc
  • 25 Answers
SOURCE: Don't know if the oven part of range is gas or electric
The model number can usually be found just inside the door or drawer (on the range itself).
All the Jenn-Air convection ovens I'm familiar with are electric even if the cook top is gas.
Posted on Jan 31, 2009
EllaWatson25
  • 725 Answers
SOURCE: electronic control touch pad not working
This is your electronic control board that needs to be repalced on this unit. GE Profile is a great brand and it is easy to repair, also.
We provide part removal/installation instructions for our customers when you purchase your parts from us.We also ship parts overnight to assure that you get your oven repaired right away.
Please contact us at:
http://www.fixya.com/repair/d499389-accurate_appliance_repair_service
from 7 AM until 9 PM CST. We look forward to getting you cooking again soon.
Thanks, Ella
Posted on Nov 17, 2009
How do i remove the cooktop and control panel to replace yhe ignitor wiring harness on a GE JSG968 slide in gas range
Call the service people, not sure if by law you are allowed to do that with a gas range.
Dec 02, 2017 | GE Kitchen Ranges
I need to know the btu input for a ge cooktop (gas) model gejgp975sekss
I see if I can find a diagram, ensure you posted right model number here.
Aug 29, 2008 | GE Kitchen Ranges
ELECTRONIG IGNITION DOES NOT WORK TO IGNITE THE COOKTOP I HAVE TO USE MATCHES TO IGNITE THE GAS
Here is a tip that I wrote to give details about why your cooktop will notspark to light the burners..
Cooktop Range Stove spark ignition does not work
heatman101
Apr 04, 2011 | Bosch 30 in. NGP74 Gas Cooktop
Hi my framtid 0v10 oven from ikea has ref F11 on screen it no longer works. I used the pyro setting for the first time
I've had the same problem. The manual said the F11 errorcode indicates that the meat probe hasn't been inserted properly. Ofcourse I do not use the meatprobe for the pyro cleaning, but I decided to insert it anyway. After insterting it I first took it out and turned the oven on. No effect. Then I turned it off, inserted the meatprobe again and turned it on again WITH the meatprobe inserted and PRESTO! everything worked again!
Jan 20, 2011 | Ovens
My Amana gas range spark modules won work, none of them four
heatman101
Oct 10, 2010 | Amana ARGS7650SS Gas Kitchen Range
Gas range top igniton not clicking, gas come on when lit with a match
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Here is a tip that I wrote to give details about why your cooktop will not spark to light the burners..
heatman101
Sep 13, 2010 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
Profile JGP636 Gas Cooktop: my ignition for the gas cooktop is not clicking...
Here is a tip that I wrote to help people troubleshoot problems with their cooktops not igniting.
http://www.fixya.com/support/r5649407-cooktop_range_stove_spark_ignition_not
heatman101
May 17, 2010 | GE Profile JGP636 Gas Cooktop
Gas oven won't heat up but the cooktop is working.
Likely this has been since fixed but here is the solution is anyone else has this problem. I just ran into this on a brand new unit and it was because it was in a Store Demo mode. You know this because there is an "SD" then the time displayed. the repair is as follows: KILL POWER APPROX 15 SEC, ON POWER UP WITH IN 1 MIN PRESS CANCEL AND THEN PRESS OVEN LIGHT AND TOP TIMER BUTTON TOGETHER AND HOLD FOR A COUPLE SECONDS. SHOULD FIX SD CODE.
Dec 25, 2009 | Electrolux EW30GS65GS 30" Slide-in Gas...
Need to unlock the controls of my Whirlpool gas oven
To Lock Or Unlock Cooktop
1. Turn all control knobs to OFF.
2. Press and hold the Cooktop Lockout icon keypad for 3 seconds. A single tone will
sound, and “Loc On” and a cooktop icon will appear on the display. After 3 sec-
onds the clock display will reappear.
3. Repeat steps 1 and 2 to unlock cooktop. “Loc OFF” will appear on the display for
3 seconds, and the cooktop icon will disappear from the display.
Feb 13, 2008 | Whirlpool SF367 Gas Kitchen Range
Kitchen Ranges Logo
170 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
