Question about Whirlpool 17.6 Cu. Ft. Top-Mount Refrigerator - White
GE Oven cuts off as soon as its turned on
Model JSP26G0P1AD - when trying to get oven to work, it will come on for a second and then turns itself off. Haven't used it in a year due to this problem. Heat sensor is operating at 1091 ohms. Is it the controller?
SOURCE: cleaned oven now won't heat
Probably what happened is during cleaning cycle the oven overheated the tco (thermo cut off). This is a thermo-fuse that is located behind the control board. It will need to be replaced.
Posted on Aug 25, 2007
SOURCE: Whirlpool RBS305PDQ11. After self-clean, oven won't heat up.
This seems to be a common problem with these ovens. The oven got too hot and the tco (Thermo cut off)tripped. This will have to be replaced. It is located behind the control board.
Agent Don
  • 310 Answers
SOURCE: Oven and oven light not working
http://www.geeksquad.fixya.com/ThreadView.aspx?prdid=53999&thid=573756
Posted by Tvaclav on May 05, 2008
I have a Whirlpool oven model number SB130PER-0 the oven will not heat up also when i turn the oven on the indicator light does not come on. Any suggestions? Thanks
I would advise you to ALWAYS to FIRST UNPLUG YOUR APPLIANCE before beginning any service procedure.
You may have an bad heating element that would needs replacing because that is the heat source for the oven and on the oven light issue you nay have a bad sending unit , switch or just a burnt out bulb or light. Check with your local Whirlpool appliance dealer – sometimes they can be of some help. So if you need further assistance, please feel free to contact your local appliance dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://whirlpool.com/home.jsp
Contact Us
Hours: M-F 8am–8pm Local Market Time
S 8:30am–5pm Local Market Time
- Get shopping help
- Order parts and accessories
Call 1-866-698-2538
Thanks, Don – The Appliance Man
Go Ahead. Use Us.
Posted on May 05, 2008
SOURCE: Whirlpool Oven Model # RS675PVGB10 will not heat
All i can say last time i work with a stove it was loose wiring . how ever could be the burner . just a suggestion. http://www.fixya.com/support/t356355-jenn_air_jds9860aap_control_panel__.aspx
Posted on Sep 15, 2008
jcarlton214
  • 105 Answers
SOURCE: Circuitry may have gotten tripped during clean cycle. Oven will open and electronics work but neither element will heat.
baked control module for heating elements. if you have a volt meter, check for power when oven on, if no juice its the control element, if you do get juice then its the elements
Posted on May 28, 2009
The oven has had 24hrs to cool down & the oven door is still locked. How do I release it
Not sure the make or model that you have but with a GE Profile, I have had success by turning off the circuit breaker for 30 seconds to a minute. The oven then resets itself and releases the door lock.
Oct 06, 2014 | Ovens
GE Monogram 30" built-in oven turns itself off after a few seconds.
Likely you need a thermal cutoff replaced near where your heating elements are. It senses the fault and shuts down. You can but an after market thermal cutoff from most any electronic parts supply, and maybe even from an appliance parts supply.
Nov 12, 2013 | GE JTP20 Electric Single Oven
Ge stove oven get a f4 fault
Open or shorted oven temperature sensor (RTD)
Check sensor harness and harness connection between oven sensor and oven control. Replace oven temperature sensor (RTD) if wiring is ok.What is the model number?
Nov 08, 2012 | GE Stove/Range/Oven Oven Control -...
The oven comes on by itself for about 20 seconds
If you have the thermostat shut all the way off and the burner turns on, the thermostat is defective.
Feb 02, 2010 | GE Kitchen Ranges
My Mother has a GE oven which is not working properly. The problem: the oven is turned on to bake,it heats up to the desired temp, works for awhile and then the oven just turns itself off and there is an...
If your electric2_bing.gif oven is not heating then you probably have a bad heating element in your oven. This is not that hard to fix yourself...
Check out this tip that I wrote about the Oven not heating problem..
Oven Problems Electric2_bing.gif Oven is Heating Slowly or Poorly
http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
heatman101
Asker's Testimonial " thanks i will have my husband look into that. " - 2gunsally
Oct 27, 2009 | GE 30" Built-In Single Electric Wall Oven...
OVEN DOES NOT HOLD TEMP SET ON 550 AND 375 WAS
sounds as though one or more of the hearing elements are blown , should be one on each side and a ring type around the fan, these are not always visable
Oct 20, 2009 | GE JSP26 Electric Kitchen Range
Double oven, top oven run by keypad turns off
I have a double oven. The top unit works fine. The bottle unit will turn on to cook or clean. Then after a few seconds it turns itself off.
Oct 12, 2009 | GE Profile JKP56 Electric Double Oven
GE JES1456WFC001 microwave oven turns on by itself
You are correct. The keypad is failing.
If you might want to replace it yourself, I have uploaded a handy guide with pictures showing you what's typically involved.
If you would like to have us do this for you, we do that for $39.95 plus part costs, assuming we can get the part for this Canadian model.
We're happy to help and we appreciate your thoughtful rating of our answer.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Jun 23, 2008 | GE JES1456 Microwave Oven
Whirlpool 17.6 Cu. Ft. Top-Mount Refrigerator - White Logo
22 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
