Question about Quad 47 cc / 49 cc Pocket Mini Bike Scooter Atv Pull Start
49cc atv will not idle just drives
Have to put rear end up on blocks to have tires off the ground to start it and then it just wants to keep turning the tires when it is started when brake is applied it stalls out
    Problem Solver:
  • 8 Answers
There should be an idler screw on the side of the carb. its has a spring behind it loosen the screw and see if that helps and dont loosen it too much its best to do this with it running
Posted on Oct 28, 2012
  • james diehl Oct 29, 2012
    pulled the housing off the clutch and discovered two of the three springs ground to pieces pretty sure that is my problem
Switch quad to awd and it starts to idle rough, and wont drive. Put it back to 2wd and it rides perfect, what could be the issue?
ATV Answerman on ATV amp UTV Tech Questions: Off ...
www.off-road.com/atv/atv-answerman-on-atv-utv-tech-questions-53357....
Nov 30, 2011 - I have got a 2005 arctic cat 650v twin starts very good at idle good but when ... Each year varies and although some machines never change it would be ... A flooded ATV will be rough at idle and have a telltale smokey exhaust. .... with and without the 4x4 engaged it seems to be stuck in awd but the front left ..
ATV won't stay running - ATVs & Snowmobiles ' In-Depth Outdoors
www.in-depthoutdoors.com > ... > ATVs & Snowmobiles
Jan 19, 2011 - 27 posts - ‎18 authors
I know, this isn't the ATV forum, but I'm hoping maybe one of the mechanical ... it is a bear , but when she starts I have to keep the throttle pressed.If I turn up the idle so she Idle's about 20 seconds later the Idle Is at about 2000 ...Missing: awd
Dec 25, 2015 | Cars & Trucks
I have a quibo 49cc pocket bike it runs good but will not idle
you need to open the screw on the carberator prolly a 1/4 turn
Jun 30, 2014 | Quad 47 cc / 49 cc Pocket Mini Bike...
I have a 1989 Jeep Cherokee, I lifted it in the back with blocks and i have yet to balance my tires. When i start to accelerate, the back side of my jeep vibrates, BADLY. I have gone through 6 U-Joint
You have answered your own question. Take the blocks out and see if every thing returns to normal. You appear to have an extreme angle on the drive shaft. You are putting stress on the entire drive train.
Apr 05, 2013 | 1989 Jeep Cherokee
Does the coil have to grounded to the engine block or just the engine bolted to frame ok for 47 cc pocket bike
coil needs to be grounded and make sure theres no paint at mounting points of motor to frame
Feb 22, 2011 | RTO 47cc / 49cc Pocket Dirt Bike Atv...
My 2000 model mazda protege makes a clunk when making sharp turns, accelerating or shifting from 1st to 2nd gear?
Sounds like a bad cv joint. Easy way to check is to raise the front of the vehicle so both front tires are off the ground. Use jack stands under the vehicle and block the rear tires. Start the engine and put the tranny in drive. Let the front wheels rotate while the engine is idling and turn the steering wheel slowly in both directions. Listen for the clunking noise. You may have to speed the engine up a little to make it work.
Jan 12, 2011 | 2000 Mazda Protege
How to fix a 49cc pocketbike forks?
some times its better to get new forks, as they can be stressed when straightening them, you dont need them snapping off while your riding
Apr 12, 2010 | Quad 47 cc / 49 cc Pocket Mini Bike...
I have a Polaris 300 4x4 and the front axle will not engage when you push the button. The "AWD" light comes on, but front tires will not pull. Any thoughts?
I have the same atv.it has a "demand 4" awd.Which means the rear tires have to spin without traction before the front wheels will engage.A good way to test it is lift the rear end up on a block of wood to suspend the tires.Put it in awd mode and gas it.The front tires should pull the atv off the wood.
Aug 17, 2009 | Polaris ATV
Noise from driveshaft .sound like a atv tires whine on highway,but i dont have atv tires ,u-joints and rear end ok???
The rear end and the transmission are possible to blame. The rear end jacked up and on jack stands with both or all wheels off the ground . $ wheel drive needs all wheels to be up on alevel hard surface in a quite place. With a driver in the truck driving at the speed the noise is loudest listen to each partt with a broom handle pipe Ect. the rear ends are most likly and the noise changes from slowdown or speedup. Lack of lubercanrt would be nice or jast a bad wheel bearing ( grab the stopped wheel and try to move it up and down ) No play should be found and turn smooth, in and out a little is normal and the brakes on or off shouldn't changany thing or they are suspect. Driveshafts click pops and ring not wine. Trannys get bad bearings if they do you may have noticed other trans related problems as well. When trannys whine they do bad things are are getting ready to. Somr driveshafts have a carrier bearing are two piece and have a U joint in the middle. Listen to the sounding rod while running touched to this part and it will be a for sure if its bad
Aug 11, 2009 | 1998 Chevrolet K1500
91 Honda fourtrax 300 back tires don't spin
bad trans, bad drive shaft, bad rear end. See what is not spinning.
Jul 13, 2009 | 2002 Honda XR 200
Quad 47 cc / 49 cc Pocket Mini Bike Scooter  Atv Pull Start Logo
165 people viewed this question
Top Quad Cycling Experts
shaun taylor
Eric Hidle
Level 1 Expert
Are you a Quad Cycling Expert? Answer questions, earn points and help others
